Freedom Offroad coilovers installed
Discussion in 'Suspension' started by kylers2k, Nov 29, 2022.
  1. Nov 29, 2022 at 9:58 AM
    kylers2k
    kylers2k [OP] New Member
    KWS
    Troutman, North Carolina
    Back again..
    Okay so I removed the 2" levelling kit (spacer) I had and installed the Freedom Offroad coilovers, UCAs and shackle lift for the rear.
    Easy install, the same as swapping any strut.
    Not sure what exactly its "set" to, but I do have room to raise it higher if needed. I have my shackles set to 2" and the front is a touch lower still, so I would estimate about 3.5" of lift in the front.
    It rides amazing, much better than the spacer lift and so far zero issues or concerns. I would recommend these based on my experience so far. I snagged the coils from extremeterrain for $330.
  2. Nov 29, 2022 at 8:39 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    It looks to me like you have way to much preload on the spring, and the spring will bind against itself during compression long before the shock reaches the end of its compression stroke. But I'm just going by what I see, and I could be completely wrong.
    kylers2k[OP] likes this.
  3. Nov 30, 2022 at 4:23 AM
    kylers2k
    KWS
    Could be, haven’t felt anything through day to day driving to indicate that as of yet though. I can see how it looks that way, I’ll update the post if I need to adjust the coils and add a spacer to reduce pre-load. Hoping to not have to.
    Sumo91[QUOTED] likes this.
  4. Dec 8, 2022 at 9:06 AM
    Chucksmith07
    Chucksmith07 New Member
    Chuck
    I installed their UCA with the Eibach stage 2 coil overs. Their arms are really nice and made well.
  5. Dec 9, 2022 at 7:15 AM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    El Cajon, CA
    Without knowing the spring rate (weight rating and length) you cannot tell how much preload is on that spring, especially not by just glancing at it. Thread showing does not equal preload
    15SR5CM likes this.
  6. Dec 9, 2022 at 6:14 PM
    Sumo91
    TN
    I was just going by how the spring looked. Do you think you could stick your finger in the gap of that spring? It looks way too compressed.
    But as you said, it could just be how that spring is made, and it could be completely incorrect for that application. But I don't see that spring being able to compress more than a few inches before it sandwiches onto itself.
  7. Dec 12, 2022 at 6:59 AM
    AccuTune Offroad
    El Cajon, CA
    Still cant make an accurate recommendation without knowing the facts. I would hate for the OP to second guess their setup based on looks. There is a lot more to it.
    Mfanatic22 likes this.
  8. Jun 8, 2023 at 5:28 PM
    Rockstar72
    Rockstar72 New Hampshire in the house
    Kris
    Manchester, NH
    2020 Army Green Toyota Tundra TRD Pro Crewmax
    I just had the Freedom coilovers put in my truck. My mechanic said to drive it for a week then adjust the height. Are they easy to adjust the height on?
  9. Jun 11, 2023 at 5:06 PM
    Jack_A_Lope
    Jack_A_Lope New Member
    Aaron
    Santa Barbara County, CA.
    2019 Tundra 4X4 SR5 TRD Sport
    Pro Comp Lift, Tires & Wheels, Steel front bumper with LED lighting, Cross bed tool box, bed rails, custom aftermarket sound system
    Are these any good? I need to replace my front struts as my stock ones are leaking. I have a Pro Comp stage 1, 4" bracket lift that retained the the stock coil overs and employed a spacer. Since I will be getting new struts I figured that I would take this opportunity to possibly upgrade by getting a coil over that would eliminate the spacer all together. My initial thought was to get the Bilstein 6112 but it was suggested to me if I wanted to get rid of the spacers I should go with ICON's 58751-CB 2.5" remote reservoir coil overs at almost $2,000.00. That is a little much. So I was wondering how these Freedom coil overs are for the price.
  10. Jun 13, 2023 at 4:49 AM
    Rockstar72
    Kris
    Manchester, NH
    I just had the Freedom struts put in my Tundra about a week ago along with new Bilstein shocks in the back. My mechanic said they looked really good and was impressed at the price. They ride great. My mechanic recommended I drive it for a week or so, then adjust the height.
