Front(4WD) driveshaft spinning in 2WD
Discussion in '1st Gen Tundras (2000-2006)' started by Voss, Jun 3, 2021.
  1. Jun 3, 2021 at 11:55 AM
    Voss
    Voss [OP] Dust in the wind
    Valod
    2003 AC TRD 4x4
    Have a strange thing going on, been hearing a slight gear rotating sound along with a very soft high pitch sound the past few days. While checking under the truck for anything out of the ordinary I noticed my front driveshaft has been rotating while in 2wd. Not sure why this is happening, my front driveshaft wouldn't spin before while in 2WD. I know it's rotating because the Zerk fittings have been in a different spot every time I've check.
    Anyone thoughts on why this is happening?
    Thanks
    Tundra2 likes this.
  2. Jun 3, 2021 at 11:59 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Sounds like your xfer case isn't disengaging. Maybe that little actuator on there isn't letting go?
    15whtrd and Voss[OP] like this.
  3. Jun 3, 2021 at 12:02 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Just because it's in 2wd doesn't mean that the driveshaft won't spin.
    Drag from the wheels rotating will make it move.
    Elduder, Diablo169 and Voss[OP] like this.
  4. Jun 3, 2021 at 12:05 PM
    Professional Hand Model
    Hand Protectors
    Go out to some dirt/gravel and gas it in 2wd. Check the ruts for rear only digs.
  5. Jun 3, 2021 at 12:05 PM
    Voss
    Valod
    2003 AC TRD 4x4
    What could cause drag from the wheels?
  6. Jun 3, 2021 at 12:07 PM
    Voss
    Valod
    2003 AC TRD 4x4
    As in try to spin the tires and see if the front spin as well?
  7. Jun 3, 2021 at 12:08 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Oil in the diff, air movement.
  8. Jun 3, 2021 at 12:11 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Thanks
  9. Jun 3, 2021 at 12:13 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I know on bikes up on stands, they'll still turn the rear wheel in neutral due to the crankcase, clutch, and trans all being in the same fluid. Same thing on the front driveshaft I'm guessing.
    Voss[OP], Darkness and Wynnded like this.
  10. Jun 3, 2021 at 12:14 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    You should be able to rotate the front drive shaft by hand, if you can do that then the T-case is not engaged.
  11. Jun 3, 2021 at 12:18 PM
    Voss
    Valod
    2003 AC TRD 4x4
    I'll give that a try today. Thanks
  12. Jun 3, 2021 at 1:20 PM
    Voss
    Valod
    2003 AC TRD 4x4
    The front driveshaft spins freely. Popped it in n out of 4wd drive a few times and I could hear the actuator engaging/disengaging.
    that slight gear sound I hear is only in the morn when I’m reversing out of an incline driveway.
    I remember a time I would just drive this truck and if new sound came along, I’d just drive it till it went away lol. Maybe that’s my best course of action
  13. Jun 3, 2021 at 1:42 PM
    Hand Protectors
    I’ll never forget the day in 2012 when my right side sway bar link snapped going out of the driveway. I though, she’ll be alright. :rofl:
  14. Jun 3, 2021 at 6:05 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    if it's engaging/disengaging correctly and you don't have a blinking 4hi or 4lo light on the dash, chances are it's working as designed. Given the fact that you can spin the forward drive shaft by hand, I would say it's operating normally.
  15. Jun 3, 2021 at 10:50 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    There is drag in the whole front end even when in 2wd. Everything slightly spins even with no load applied.
    If the transfer case or ADD didn’t disconnect you would be getting a flashy beeby light on your dash.
    Voss[OP] likes this.
  16. Jun 4, 2021 at 12:13 AM
    737fixer
    737fixer New Member
    Completely normal. Our 4wd is an off/on switch, no in between. Not only the light but the first 100yrds of driving will let you know your in 4wd. Put it in 4wd on pavement and try to turn, the lights won't need to tell you something is wrong.
  17. Jun 4, 2021 at 3:37 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Pics of beeby light, plz.
    Voss[OP], 15whtrd and bmf4069 like this.
  18. Jun 5, 2021 at 3:20 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Think I may have found the problem. My transfer case is leaking. Guess I hit something on the trail.
  19. Jun 5, 2021 at 3:36 PM
    Sunnier
    Sunny
    San Diego, CA
    My transfer case seal started leaking, looked like that. The discoloration above could be blowback from that little leak that accumulates and drips from the lowest point. I was freaked out— because I worry every time I face some new truck thing I haven’t done before— but I did some research, then fixed it in my driveway. It wasn’t too hard. I did buy 2 special tools for uncrimping and crimping the nut (staking tool and unstaking tool; I’ll post a pic of the tool when I get home) but guys have completed the job using alternate tools. The most challenging part for me, since I’m not super strong physically, especially working overhead, was pulling/ holding the drive shaft away from the transfer case. I used a ratchet strap and it worked great.
    Anyway, I hope that’s your problem (that you didn’t break something). to check, wipe all that off... use break-free or something, then let it sit and when you check back, you’ll see where it’s leaking from. If it’s that seam, it’s the seal.
    des2mtn and Voss[QUOTED][OP] like this.
  20. Jun 5, 2021 at 3:56 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Thanks, pretty sure it’s a seal/gasket leak. I can see where the oil is somewhat fresh along the side.
    Sunnier[QUOTED] likes this.
  21. Jun 6, 2021 at 11:06 AM
    Sunnier
    Sunny
    San Diego, CA
    Voss[QUOTED][OP] likes this.
