Front and rear brake torque spec
Discussion in '3rd Gen Tundras (2022+)' started by Dancarp8, Oct 30, 2023.
  1. Oct 30, 2023 at 3:51 PM
    Dancarp8
    Dancarp8 [OP] New Member
    2022 Tundra
    Hi,
    I am looking for the front and rear brake torque specification, caliper pin and mounting bolt. Thank you
  2. Oct 30, 2023 at 4:48 PM
    Dancarp8
    2022 Tundra
    Thank you for the information
    ryanwgregg likes this.
  3. Feb 27, 2024 at 12:02 PM
    Fedtime
    Fedtime New Member
    Hi Ryan:
    Is that 41 ft lb for the caliper pin bolt, or the rear caliper mounting bolt?
    That seems really low for the mounting bolt, and I note that 2.5 gens used around 68 ft lb for the rear caliper mounting bolt.
    Thanks!
  4. Feb 27, 2024 at 12:47 PM
    Fedtime
    Fedtime New Member
    Thanks!
  5. Apr 22, 2025 at 9:27 PM
    Nazn
    Nazn New Member
    Tuesday
    2016 Tundra Crewmax
    KING 3.0 Front and Rear KING 2.0 Bump stops ICON RXT Stage 3 Leaf ICON Delta UCA RSI Topper Prinsu cab rack/RSI Topper Rack BAJA lights throughout DEMELLO bumpers with 12.5k Winch
    Hey guys, I did rotors and brakes all around the other night and used the 151ft lb caliper torque spec for the front mounting bolts. The reason why is I saw this post and immediately assumed it was correct since my driver side broke two of my half inch impacts trying to get the bolts out, but then upon doing the passenger side, they came off easy like any other caliper bolt I'm used to. Long story short, it had me digging into checking for torque specs and I mainly see 70-80 ft lb which is what I used to mount the rear caliper bolts. Is this 151 ft lb spec accurate or is this misleading as I'm now starting to believe? Fwiw all my front caliper bolts are in fact torqued to 151 and my rear caliper bolts at 70 as I write this. Just looking for some confidence and verification before getting new bolts and re torque to say 80 ish in the front. 150 had me thinking that I easily stretched the threads.
  6. Apr 23, 2025 at 12:27 PM
    sudobash
    sudobash New Member
    100% correct.
  7. Apr 23, 2025 at 12:32 PM
    Nazn
    Nazn New Member
    Tuesday
    2016 Tundra Crewmax
    100 percent correct as in the 151 ft lb is incorrect?
  8. Apr 23, 2025 at 12:33 PM
    sudobash
    sudobash New Member
    151 is correct.
  9. Apr 23, 2025 at 12:35 PM
    Nazn
    Nazn New Member
    Tuesday
    2016 Tundra Crewmax
    Is the 70-80 ft lb correct for the rears? Ps appreciate the replies!
  10. Apr 23, 2025 at 12:46 PM
    sudobash
    sudobash New Member
    FRONT
    Caliper Bolt - 151 ft. lb.
    Hose - 11 ft. lb.
    You also need to align the match marks on the disc and front axle hub sub-assembly.
    REAR
    Caliper Bolt - 41 ft. lb.
  11. Apr 23, 2025 at 12:53 PM
    Nazn
    Nazn New Member
    Tuesday
    2016 Tundra Crewmax
    What are the match marks? Excuse my ignorance, I just threw the fronts on and called it good. The rears i matched the hole to adjust parking brake. Other than left and right hand side disks i didnt know there was a specific rotation
