Front axle leak/front diff
Discussion in '1st Gen Tundras (2000-2006)' started by Voss, Nov 1, 2021.
  1. Nov 1, 2021 at 1:00 PM
    Voss
    Voss [OP] Dust in the wind
    Valod
    2003 AC TRD 4x4
    Hi all, do we have seals that need replacing where our axels connect to the front differential? Have a leak, not sure how to go about fixing this…
  2. Nov 1, 2021 at 1:07 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Each side has a seal you can buy from Toyota. What kind of shape are your axles in? Could replace both at the same time. If axles are fine, just pull them out and replace the seals. The passenger side is easy to screw up if you drive it in too far. Good time to swap fluid also. It would also be a great time to replace the needle bearing if you haven't already.
    They sell the axle seals too-verify the part #
    https://eastcoastgearsupply.com/i-1...amshell-bushingeliminates-needle-bearing.html
    Good info in here.
    https://www.tundras.com/threads/ecgs-bushing-tool.59664/
    metalpete, bmf4069 and Voss[OP] like this.
  3. Nov 1, 2021 at 1:10 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Thanks!
  4. Nov 2, 2021 at 6:00 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    So that's just the drivers side? What about the passenger side?
  5. Nov 2, 2021 at 8:01 AM
    Voss
    Valod
    2003 AC TRD 4x4
    Mine is on the passenger side. There’s a gasket you can replace and a bearing(may need replacing as well).
    That being said, called a differential shop and the guy said our axels can pop out and back in if we have a lift which causes some oil to drip out. Told me to wipe off the oil and see if it leaks again.
  6. Dec 11, 2021 at 9:56 AM
    Voss
    Valod
    2003 AC TRD 4x4
    So definitely have a leak and have the parts ready for todays repair. Also got the bearing but wasn’t able to find any how to vids on the YouTube.
    Any tips on how to change the bearing?
    Jack McCarthy likes this.
  7. Dec 11, 2021 at 10:11 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    hmm, I don't remember any bearing on the passenger side and the driver side uses a needle bearing unlike the one you have in the picture.
    Voss[OP] likes this.
  8. Dec 11, 2021 at 10:21 AM
    Mr Badwrench
    Mr Badwrench New Member
    Unless you are getting vibration or a faint roar, leave the bearings along, personal advice. Which bearing did you purchase, I guess I don't recognize it in the picture?
    Get a micrometer and measure the depth of the original oil seals and try to get the new ones seated at the same depth or thereabouts. Get a seal installation tool and get the seals as concentric as you can. Also, look at the CV shafts where they interface with the seals, if there is a groove, you can either replace the CV shaft (extreme measure) or seat the seal at a different depth so it doesn't ride in the same groove (that's what I would do).
    They are kind of a pain in the ass to replace and if you don't get them right on the first shot, you have to pull everything apart again. Attention to detail and taking your time will really help you out here.
    dinosaur and Voss[OP] like this.
  9. Dec 11, 2021 at 10:41 AM
    Voss
    Valod
    2003 AC TRD 4x4
    Stop it you’re scaring me lol. Appreciate the tips bud! It’s the bearing for the passenger side, sits behind the seal. I think it’s held in place with those C clamp-washer type thingamajigs that squeeze together to remove.
    The axel went bad a while back that would cause a vibration. Not really noticing a vibration since replacing the axel but feel it would be better off with a new bearing.
  10. Dec 11, 2021 at 10:47 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The vibration people experience is typically the needle bearing and the way you test is putting it in 4WD. If the vibration goes away while in 4WD it's a bad needle bearing. I agree with them that I wouldn't touch that other bearing. There is a YouTube video for the needle bearing. Most people swap it for the east coast gear supply bushing.
    @empty_lord may know how to swap the other bearing you purchased.
  11. Dec 11, 2021 at 10:56 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I agree with @FirstGenVol to diagnose the vibration but if you're in there to replace the seal and already have the axle out it's only a matter of time before the needle bearing goes kaput especially if you're lifted at all. Just spend the $70 and replace it while you're there. It's not hard, just take a little finesse. Also the seals have natural lips where they should be driven to, just take note of the old seal and how far it was driven in.
    ECGS bushing to replace the needle bearing:
    You will need a puller either from them as well:
    https://eastcoastgearsupply.com/i-14472913-toyota-7-5-clamshell-bushingremoval-tool.html
    or rent it from...crap, I ALWAYS get you guys mixed up on here...but rent it from one on this board. Someone smarted will let you know who has it and now I think two people have the tool to lend out.
    Also, I see you have a red boot on your CV axle...is that the CVJ one??
    dinosaur, Voss[OP] and FirstGenVol like this.
  12. Dec 11, 2021 at 11:14 AM
    Voss
    Valod
    2003 AC TRD 4x4
    It’s the off-road solutions high angle cv boot.
    Already have the bearing but my leak is on the passenger side. Believe the needle bearing is on Driver’s side. To replace the bearing on PS, I feel like I need to remove the tube section that’s between the diff and and axel.
    If I’m not mistaken, @FrenchToasty made the puller.
    FrenchToasty likes this.
  13. Dec 11, 2021 at 11:18 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The passenger side bearing shouldn’t need to be replaced… that’s not a fun job.
    bmf4069, dinosaur and Voss[OP] like this.
  14. Dec 11, 2021 at 11:22 AM
    Voss
    Valod
    2003 AC TRD 4x4
    Alright, I’m following the general consensus on the bearing. As long as it looks like it’s in good shape, I’ll leave it be.
    thanks fellas! That should save me enough time to tackle a couple other small projects on my list.
    dinosaur, CodyP and Punk1974 like this.
  15. Dec 11, 2021 at 5:21 PM
    Chevy9124
    Chevy9124 New Member
    Will
    06 DC SR5 4x4
    Bilstein 5100/OME 2885 combo, JBA UCA’s, 285/70/R17
    I just replaced my passenger side seal. There’s a small lip about 5mm in from the outer edge of the differential that the seal should align with. I learned the hard way and put the seal too far in and had to pull it out for a second try. One tip is to use a piece of pipe that fits over the protruding ring of the seal to tap it in evenly and square. It can easily get off kilter. I used a ball joint receiver sleeve since I already had a ball joint press kit on hand. But ive heard others use pvc pipe.
    Just take your time with it and tap lightly and constantly check its position/alignment
    And check youtube for videos. I think Timmy the Toolman has one
    Punk1974, dinosaur and Voss[OP] like this.
  16. Dec 11, 2021 at 5:46 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    Yeah, no need to replace the bearing on the passenger side. That’s a big project. The bearing everyone is talking about is the needle bearing on the drivers side. When lifted, it can cause vibration, like a grumbling feeling due to the excessive wear.
    I’d throw a new seal on it and call it good.
    You should be able to pull the CV by drooping out the suspension, removing the caliper and unbolting the lower ball joint and swinging the knuckle out.
    des2mtn and Voss[OP] like this.
  17. Dec 11, 2021 at 5:48 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Exactly what I used along with a seal driver set that fit perfectly on the ball joint press. It still went in a little uneven but was able to tap it even. Got it right around the spot it’s supposed to sit. Hopefully no more leak.
    bmf4069 and Chevy9124[QUOTED] like this.
  18. Dec 11, 2021 at 5:50 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Yeah bearing looked good so left it in there. Disconnected the tie rod and the 4 bolts connecting the wheel hub to the ball joint(didn’t remove ball joint). Worked well
  19. Dec 12, 2021 at 1:07 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Went on a decent test drive and so far so good. No leak
  20. Dec 28, 2021 at 8:17 PM
    Chevy9124
    Will
    06 DC SR5 4x4
    @Voss mind sharing an update? Has the leak stopped? I noticed mine’s back again but I’m pretty sure I installed the seal perfectly.
  21. Dec 29, 2021 at 8:35 AM
    Voss
    Valod
    2003 AC TRD 4x4
    That sucks. No leaking yet on mine
  22. Dec 29, 2021 at 9:27 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    what side is still leaking?
  23. Dec 29, 2021 at 4:17 PM
    Chevy9124
    Will
    06 DC SR5 4x4
    passenger side. it was good for a few weeks but now I’m seeing the drip again with a spot on the driveway. Any ideas of what it could be?
    I checked the diff breather tube plug valves and one wont twist freely. and based on what others say on the forum seems like that could be the culprit? I ordered a few that ill replace this week and see if that does anything.
  24. Dec 29, 2021 at 4:32 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    that sucks. I suppose that could be the culprit, and at least it's something that needs fixed so I would start there.
    Aerindel likes this.
  25. Dec 31, 2021 at 9:13 AM
    Chevy9124
    Will
    06 DC SR5 4x4
    I got under the truck today to investigate the seal and noticed the passenger side axle has in/out play in it, where it meets the diff. I can push/pull it with my hand about 1/16" in/out. Is that normal? It's an aftermarket axle btw.
  26. Dec 31, 2021 at 2:05 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Normal c-clip play for a cv axle.
    metalpete and Aerindel like this.
  27. Jan 1, 2022 at 12:27 PM
    Chevy9124
    Will
    06 DC SR5 4x4
    awesome, thanks
  28. Jan 1, 2022 at 1:59 PM
    Aerindel
    Aerindel New Member
    Montana
    Oil seals are magic as far as I am concerned....it seems they leak, or not based on some kind of magic humans cannot comprehend....
    Something I do know, it doesn't take much of a scratch on the shaft to make a seal leak. Learned that the hardway with a subaru cam seal.
    If you do find a scratch, the good news is you can buy shaft repair sleeves, which are just a really thin stainless steel sleeve that you press over the shaft and gives you a new polished surface over the seal area. They are so thin, the slip inside the normal sized seal without a problem.
    metalpete likes this.
  29. Jan 1, 2022 at 2:36 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Was it an oem seal?
  30. Jan 1, 2022 at 7:49 PM
    Chevy9124
    Will
    06 DC SR5 4x4
    interesting. Thanks for that info, when you say press the sleeve on does it require an actual press or can it be done with basic tools? And where would be a good place to buy one?
    Yep, sure was.
    I replaced both breather tube plugs and drove a good bit yesterday so I’ll check tomorrow to see if its still leaking
    CodyP[QUOTED] likes this.
