Front Brake Dust Shields
Discussion in '1st Gen Tundras (2000-2006)' started by baltimorebirds2, Nov 27, 2021.
  1. Nov 27, 2021 at 4:03 PM
    baltimorebirds2
    baltimorebirds2 [OP] New Member
    2004 Tundra Access Cab LTD 4x4 Salsa Red (TOTALED)
    Hey all, wanted to ask a quick question regarding the front brake dust shields on my truck. So I've had my '04 Tundra Access Cab for around a year now and it's been great. It needs front pads and rotors, so I ordered the pads and rotors and will put em on once they come in. However, I noticed that my front dust shields have rust holes (I live in the rust belt), and wondered if I could replace them without completely taking the hub off. I was thinking that if it's possible to replace them with the rotors off, then I would do that. If not, then I won't bother with them until my hub/axles need replacing. Can someone clarify how the dust shields are mounted, since I've never had the brakes/hub/axles apart yet. Thanks in advance!
  2. Nov 27, 2021 at 4:38 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Most definitely you have to have the hubs off
  3. Nov 27, 2021 at 7:08 PM
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    man i’ve been looking all over at rust belt specials i thing i’ll raid japanesedismantle for some decent spindles dor cheap and do a rework instead of fanagling with a mess on one of these rust bucets front ends.
  4. Nov 29, 2021 at 6:00 AM
    baltimorebirds2
    Thanks. It almost looks as if it would work, but my guess is that you can’t remove the shield because once the bolts are backed all the way out, it looks like they will contact the back side of the hub. I feel like they could’ve easier to get off haha
    Punk1974 likes this.
  5. Nov 29, 2021 at 6:09 AM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    Why replace them? I took mine off off my Tacoma a few years ago and I never had issues. One less thing that will rust.
    irhunter likes this.
  6. Nov 29, 2021 at 7:07 AM
    w666
    Maryland
    I pondered this, but ultimately came away with the notion that Toyota put them there for a reason (after all, if the factory could save a dollar on each car, why would they not?). They're not dust shields in my estimation, but rather grease shields. A torn CV boot could throw a lot of grease on the rotor causing all kinds of problems. I had the hub off anyway to change the bearing, so it made sense to do it then. It doesn't make sense to do it otherwise. The same reason I haven't changed the rusty rear shields yet.
    BTW, Dorman makes a two piece shield that doesn't require removal of the hub (or axle). Although they don't offer a version for our truck, it would be fairly easy to split a factory shield for the same result (at least for the front).
  7. Nov 29, 2021 at 10:46 AM
    Strangebird22
    Strangebird22 New Member
    Terry
    Ohio
    2000 Tundra AC 4.7 4X4 SR5
    Mine both rusted away shortly after I bought it in 2018. Haven't had any adverse affects from them being gone. As a bonus I didn't have to trim them when I did the brake upgrade:bananadance:
  8. Nov 29, 2021 at 10:52 AM
    baltimorebirds2
    I can’t imagine not having them would cause any harm… Besides maybe getting dust on some front end parts but that’s not really a big deal at all. I’ll probably just leave them be until they completely rust away
  9. Dec 30, 2021 at 2:00 PM
    nickrick78
    nickrick78 New Member
    Nick
    Pittsburgh PA
    2004 DC
    Break the rotted shields off while the brakes are apart, leaving them off will not hurt anything
    irhunter and Svengalicanada like this.
  10. Dec 30, 2021 at 3:27 PM
    Richid
    Richid New Member
    Mine rusted off long ago. I would replace them if it were easier but it doesn't affect the brakes at all. Maybe the life is a little shorter with the extra dirt in there but my driving style probably shortens the life of them more.
    Svengalicanada likes this.
  11. Aug 17, 2022 at 2:30 PM
    Svengalicanada
    Svengalicanada New Member
    2010 rcsb 4x4 4.6l
    I was just gonna crawl under neath and see if I could break them off without removing wheel or brakes.
    Do you have to do it when its part or will it just be easier ?
    N84434 likes this.
  12. Aug 17, 2022 at 2:51 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Put some good heavy gloves on, crawl under there and start pulling and bending. If they're as bad as mine were, they'll come apart pretty easily. If you have tin snips or sheet metal shears, that will help getting the remnants out of there.
  13. Aug 18, 2022 at 9:54 AM
    Svengalicanada
    2010 rcsb 4x4 4.6l
    If the rim spokes were shaped like fan blades, they would blow the brake dust out of your rims plus you'd have brake cooling,the faster you go the cooler your brakes...
  14. Aug 18, 2022 at 2:45 PM
    HAL69000
    HAL69000 New Member
    2004 Double Cab 4WD
    Do these count?
    bmf4069 likes this.
  15. Aug 18, 2022 at 2:47 PM
    bobbpreston
    bobbpreston New Member
    Robert
    2010 tundra sr5
    Jba long tube headers, flowmaster cat back exhaust, s&bc/a intake
    Hubs off mi amigo
    HAL69000 and bmf4069 like this.
  16. Aug 18, 2022 at 2:55 PM
    Svengalicanada
    2010 rcsb 4x4 4.6l
    Yup !, I have heard before if you think you thought up something new..10 other people have already applied for a patent on the same thing !
  17. Aug 18, 2022 at 3:10 PM
    Yup. Learned the hard way on that one with the MegaPenetrator I designed.
  18. Aug 19, 2022 at 4:25 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Starfish sans hubs is the only way to go. I still have my dust shields though.
    HAL69000[QUOTED] likes this.
  19. Aug 19, 2022 at 5:54 AM
    HAL69000
    HAL69000 New Member
    2004 Double Cab 4WD
    Mine came with 17" FJ cruiser wheels on it, which definitely have a look to them.
    But I sourced some 16" starfish (for <$100!) pretty quickly. Unfortunately they've been sitting in storage waiting to be cleaned up and have tires put on them for much longer.
  20. Oct 5, 2023 at 7:47 PM
    SteveT
    SteveT New Member
    LugNutz
    2002 Tundra SR5 Access Cab
    None yet. Just good ole maintenance
    I was also wondering if having dust shields removed from disc brakes is a yearly inspection concern or not? I live in PA.
  21. Oct 6, 2023 at 6:08 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I've never heard of that being an inspection safety issue here but I don't know of anyone who runs without them.
  22. Dec 13, 2023 at 11:16 PM
    JaniceVista
    JaniceVista New Member
    Janice
    2002 SR5 TUNDRA
    My shields are rusted off. Truck passed inspection PA this year.
  23. Dec 14, 2023 at 5:15 AM
    bmf4069 likes this.
