Front End Bump noises
Discussion in '1st Gen Tundras (2000-2006)' started by tgroves526, May 13, 2021.
  1. May 13, 2021 at 5:34 AM
    tgroves526
    tgroves526 [OP] New Member
    Ted
    2000 Tundra SR5
    Hello All,
    I have 1st Gen 4x4 SR5, 200K miles and it seems I'm going down the path of Squeaks and ringing (loose hardware) noises as I'm driving this pickup daily. I need to get complete bushing kit for this front end as its driving me crazy. Its defiantly the front end as the noise is heard as same time.
    I replace coil over shocks and bushings
    Checked all exhaust heat shields
    removed the skid plate (for noise testing)
    Original Arms and bushings
    Replaced upper and lower ball joints (original parts)
    Thank you for any help and part numbers
    Ted Littleton,CO
  2. May 13, 2021 at 11:59 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Welcome Ted! There's a lot of places that can make noise. Can you hear it from any particular spot? And any specific noises?
  3. May 13, 2021 at 12:05 PM
    tgroves526
    Ted
    2000 Tundra SR5
    Thanks for the reply, the noise is only when front axle hits road bumps. This is a 4X4 and Its almost like a ring sound. Tonight I'm going to remove the Sway bar hardware and drive. thanks Ted
    des2mtn likes this.
  4. May 13, 2021 at 12:40 PM
    des2mtn
    des2mtn On the scenery looking at the road
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Sway bar links would be a good start; I've experienced noises when they're loose.
  5. May 14, 2021 at 6:42 PM
    tgroves526
    Ted
    2000 Tundra SR5
  6. May 14, 2021 at 7:00 PM
    SouthWestGA
    SouthWestGA New Member
    Had a recent alignment done? Lower control arm Cam bolts loose? Upper control arm thru bolts loose? Have you tried soaking stuff down with lubricant to see if the noise goes away?
    That’s all i can think of now off the top of my head
  7. May 14, 2021 at 7:29 PM
    tgroves526
    Ted
    2000 Tundra SR5
    Thanks for reply. No alignment and control arms are original, cam bolts are tight. Great idea to shoot lubricant 1 place at a time. Checked all front end frame welds and frame to body bushings.
    Parts replaced: up/low ball joints, struts
    1 thing important. I don’t hear front end noise when braking
  8. May 15, 2021 at 4:39 AM
    Check your brakes then. Pads could be missing the springs that hold tension on them. Loose caliper or dust shield bolt.
    SouthWestGA and tgroves526[OP] like this.
  9. May 15, 2021 at 1:18 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    That's a pretty good knocking sound.
    If all the bushings are ok and you have new ball joints...
    Are the shocks new? Swap sides and see if one is bad internally. Also check to see if the coil is flexing and touching the shock body or chassis (typically caused by incorrect top hat position).
  10. May 15, 2021 at 1:59 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Sounds like what a loose brake backing plate or exhaust heat shield noise would make....not saying necessarily either, simply loose thin sheet of aluminum or steel.
  11. May 15, 2021 at 4:06 PM
    SouthWestGA
    Bad cv axle that only makes noise when pivoting?
  12. May 16, 2021 at 7:09 PM
    tgroves526
    Ted
    2000 Tundra SR5
    Thanks for the great suggestions, Both cv axles don't have slop when I pull/push up down and when I turn hardover to each side, no strange sounds. I agree and about thin metal and I did find a heat shield clamp broken, replaced but still noises. Im going to take dust shield off on this right side, check both Pads for broken holder or caliper issues. Both Shocks/struts are new.
    As I stated earlier- Driving 20mph no brakes applied hear jingle sound when tires hit pothole. Light brakes applied with gas still on don't hear noise when pothole.
    I have been thinking, with Brakes applied I bet the control arms have force which also might be important . Pickup has 200k and these are stock Control arm bushings.
    Thanks Ted
  13. May 17, 2021 at 1:09 PM
    Did you have 13WE pads in 13WL calipers?
  14. May 17, 2021 at 4:04 PM
    tgroves526
    Ted
    2000 Tundra SR5
    Akebono pads. Yes they Fit the calipers correct
  15. May 22, 2021 at 2:04 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Any play or leaks in the shock rods (shafts)?
  16. May 22, 2021 at 4:18 PM
    tgroves526
    Ted
    2000 Tundra SR5
    No they are brand new. Been slowly diagnose the sound. It’s on front right with no brakes on. Took the caliper off and dust shield off. Nothing odd. Im thinking of replacing upper and lower control arm bushings next , no play up or down or side to side. Thanks for replying
  17. May 22, 2021 at 8:00 PM
    alb1k
    Left Coast
    It's good
    And you removed the skid and the anti sway. No chance it’s actually in the engine bay on that side? I really doubt it, but it just found a rattle in my dash that has plagued me forever. I thought it was around the driver, turns out it was the AC control under the stereo
  18. May 24, 2021 at 4:37 AM
    tgroves526
    Ted
    2000 Tundra SR5
    Thanks to all who replied, yesterday took the complete front end apart. After removing sway bar and struts Found the lower control arm on passenger side had no rubber on rear, and the control arm was jiggling up/down or metal to metal when suspension hit the rubber Bumpstops. Will get all new control arm bushings this week and hopefully not a clunk on a bump! . 200K 21 years young and still going! thanks Ted
    bmf4069, KNABORES and Geo4x4 like this.
  19. Mar 4, 2022 at 1:50 PM
    az chip
    az chip New Member
    Craig
    Arizona
    2003 Tundra TRD
    I am going through this now on my '03 AC. When braking, bumps or any turn. Squeaks in the front.
  20. Mar 4, 2022 at 1:58 PM
    alb1k
    Left Coast
    It's good
    Aftermarket upper control arms?
  21. Mar 4, 2022 at 2:01 PM
    az chip
    az chip New Member
    Craig
    Arizona
    2003 Tundra TRD
    Don't think so. I never installed any. The PO never did a thing to this truck.
  22. Mar 4, 2022 at 2:02 PM
    des2mtn
    SW
    Tonto cover
    This sounds a lot like lower control arm bushings.
    alb1k likes this.
  23. Mar 4, 2022 at 2:05 PM
    alb1k
    Left Coast
    It's good
    So many things that can make noises up there. Once I let someone else change my oil and they didn't torque the skid plate. Start by checking all your bolt torques, including shocks.
    des2mtn likes this.
  24. Mar 4, 2022 at 2:05 PM
    alb1k
    Left Coast
    It's good
    and this!
    des2mtn[QUOTED] likes this.
  25. Mar 4, 2022 at 2:06 PM
    az chip
    az chip New Member
    Craig
    Arizona
    2003 Tundra TRD
    Good idea. Will do
  26. Mar 4, 2022 at 2:12 PM
    des2mtn
    SW
    Tonto cover
    What they described was exactly the symptoms I experienced when mine were bad. But yes, a lot of things up there that can make noise!
    For the bushings you should be able to crawl underneath and see if the rubber is worn away like the OP @tgroves506 did, or if they're cracked. My guess they are if they're original and the truck is in a dry environment.
