Front grille emblem?
Discussion in '2.5 Gen Tundras (2014-2021)' started by frostybrew4me, Jul 11, 2022.
  1. Jul 11, 2022 at 6:56 PM
    frostybrew4me
    frostybrew4me [OP] New Member
    Jack
    2018 Tundra SR5 Doublecab 4x4
    TRD exhaust,TRD CAI, TRD Sway Bar
    Have a 2018 Tundra that I would like to replace the front grille emblem.( current one is weathered) I know the radar stuff is behind the grille. I’ve heard that the backside of the emblem has 2 star washers on each side besides the tabs. Will I have to remove the grille completely just to replace the emblem or will it come off from the front using plastic trim tools? Or could I use a headlight restoration kit to clean up the plastic a little?
    thanks for any advice.
  2. Jul 11, 2022 at 7:59 PM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    Wrap it with VVivid smoke tint and it will look nice and not impair the radar (and get rid of the chrome).
    Randydw and Saltyhero13 like this.
  3. Jul 11, 2022 at 8:04 PM
    It will not just pop out. There is a screw in the back of it along with the tabs. The emblem is glass and just over $300. As mentioned, your best and cheapest option would be to put a light tint over it.
    https://www.sparksparts.com/oem-par...0dW5kcmEmeT0yMDE4JnQ9c3I1JmU9NS03bC12OC1nYXM=
    French Avocado likes this.
  4. Jul 11, 2022 at 8:15 PM
    frostybrew4me
    Jack
    Looks there’s 2 like star washers LF/RT clipped on 2 plastic tabs. Looks like I’ll have to remove the front grille to get access to remove the 2 star washers before the emblem will come out.
  5. Jul 11, 2022 at 8:17 PM
    frostybrew4me
    Jack
    Is the sensor for the radar located top right under the little black cover?
  6. Jul 11, 2022 at 8:18 PM
    frostybrew4me
    Jack
  7. Jul 11, 2022 at 8:26 PM
    Are you talking about the removable cover on the top.of the grill towards the battery? That is the connector that has to be unplugged before you remove the grill. The sensor itself is a box that is screwed onto the grill behind the emblem.
  8. Jul 11, 2022 at 8:27 PM
    frostybrew4me
    Jack
    I actually have a gentleman across the street from me that does window tinting out of his like 5 car garage. Would I be able to just use the VVid tint around the emblem with out removing it and it won’t effect the TSS radar?
  9. Jul 11, 2022 at 8:27 PM
    frostybrew4me
    Jack
    Yes sir
  10. Jul 11, 2022 at 8:31 PM
    Yes, you should be able to tint it without removing it.
    User170512 likes this.
  11. Jul 11, 2022 at 8:35 PM
    frostybrew4me
    Jack
    I truly appreciate the reply and your idea
    thank you
  12. Jul 11, 2022 at 8:36 PM
    frostybrew4me
    Jack
    No issue with the tint interfering with the radar?
  13. Jul 11, 2022 at 8:37 PM
    This is what the sensor behind the emblem looks like. The connector is the one that is right under the panel on the grill.
  14. Jul 11, 2022 at 8:39 PM
    frostybrew4me
    Jack
    Thank you
  15. Jul 11, 2022 at 8:41 PM
    frostybrew4me
    Jack
    It’s where the dealership ( Recall ) put the big sticky looking bandaid on to weather proof it.
  16. Jul 11, 2022 at 8:43 PM
    You could do a light smoke or you could do a medium smoke like Michelle did on hers. No issues at all with the sensor.
  17. Jul 11, 2022 at 9:02 PM
    frostybrew4me
    Jack
    Looks good….. thank you to all that chimed in.. looks like tinting the emblem is cheaper way, all the scratches on the emblem and harsh AZ summers was bugging me, didn’t wanna spend $300 + for one at the dealership.
  18. Jul 11, 2022 at 9:17 PM
    French Avocado
    Utah / Wyo
    zero problems for me with the tint. C03B3B42-C9AD-41E3-8BE3-4CE29E811AEB.jpg
  19. Jul 28, 2024 at 10:39 AM
    elcortesano
    elcortesano New Member
    Hello, can someone offer me some advice please?
    2018 Tundra Limited.
    Faded/scratched front emblem.
    I removed the grill, removed the emblem.
    Wet sanded with a 12V drill attachment pad, 1000 then 3000, then 5000 grit.
    Used V32 and then V38 with a drill attachment buffing pad.
    Emblem looked brand new when wet with V38 polish.
    As soon as I re-installed and the polish "dried" it still looks like this.
    It looks better than it did originally, but I doesn't look perfectly clear like it did when it was first polished in my garage.
    Thank you!
  20. Jul 28, 2024 at 11:19 AM
    Ace96
    Ace96 New Member
    Western KY
    2021 Voodoo Blue TRD Sport
    you still have scratches in it. You are going to have to do more polishing from what the pictures show.
    Not sure how much damage you did with drill and wet sanding. In my opinion, I would have wet sanded by hand and not used a drill.
  21. Jul 28, 2024 at 11:45 AM
    elcortesano
    Oh shoot, I didn't think of that; I thought the drill would be better, but I'll bet you are right, I should have hand sanded it instead.
    Thank you!
  22. Jul 28, 2024 at 12:44 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    I wrapped mine with no issues.
