Front only body lift
Discussion in 'Suspension' started by TundraTRD08, Feb 2, 2023.
  1. Feb 2, 2023 at 8:30 AM
    TundraTRD08
    TundraTRD08 [OP] Somehow I fit 37s on a level
    Wesley
    08 Super White TRD Off-Road on 37s
    3.5' RC lifted struts with RC UCA Alcan rear leaf spring upgrade with 300lbs added weight+1" lift built in. Adjustable Alcan Shackles set to add an extra inch which equals to a 2" lift in the rear. 37” Maxxis RAZR M/Ts with 1.5” spacers 8” BAMuffler Tuned by Bully Dog Tuner
    I have 3.5” up front and 2” in the back. I have adjustable shackles in the back that I’ve tried lowering but I don’t like them that low, I have quite a bit of nose dive, maybe more than factory. Is there like a 1” body lift kit that only goes on the front of the truck, or would that strain the rear cab mounts?
  2. Feb 2, 2023 at 8:34 AM
    Couldn't recommend that as the fix. The body mounts would have to have progressively smaller spacers from front to back and would look, well goofy. Like when you backsplash and cabinets are not even with each other, but one of them is level and you can't tell which one. Changing out the rear shackles or getting a new leaf pack is probably the way to go here.
  3. Feb 2, 2023 at 8:37 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  4. Feb 2, 2023 at 8:39 AM
    TundraTRD08
    Wesley
    My shackles adjust a half inch down to make it a 1.5”. I have Alcan Springs that provide an inch by themselves and in my opinion have the perfect ride height, it’s just that the front is maxed out in terms of height without cutting the frame. Oh well:notsure:
  5. Feb 2, 2023 at 8:39 AM
    TundraTRD08
    Wesley
  6. Feb 2, 2023 at 8:42 AM
    TundraTRD08
    Wesley
  7. Feb 2, 2023 at 8:43 AM
    4.5" of lift up front is gonna be extreme for the suspension geometry. Can't imagine you'll have any down travel left.
    TundraTRD08[OP] likes this.
  8. Feb 2, 2023 at 8:44 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Plus, if you just raise the front of the cab you’ll probably end up with the top edge of the bed hitting the back of cab.
    Maybe long or mid travel front suspension with longer coil overs and drive shafts???
    Going back to stock rear shackles??
  9. Feb 2, 2023 at 8:44 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Which shackles are you running? Alcan makes some that adjust as well. Maybe theirs will set your back end lower but not to the point you're uncomfortable with it.
  10. Feb 2, 2023 at 8:45 AM
    TundraTRD08
    Wesley
    That’s what I thought. Coachbuilder also sells this but in .25 increments to correct driver side lean that I was wanting to do. You stack two of these on the driver side and one on the passenger side and they say it equals.5” of lift. Do you think that the stock LCA would have enough down travel for that? It has a little more than you may think, but it’s obviously not infinite
  11. Feb 2, 2023 at 8:46 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    CB also has a .5" shim.
  12. Feb 2, 2023 at 8:47 AM
    TundraTRD08
    Wesley
    I have the adjustable ones, but I really just can’t make myself think it looks good. I tried to run it a few days and just thought it was too low. Just my opinion in that area tho:notsure:
  13. Feb 2, 2023 at 8:48 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Lower your front end to accommodate?
  14. Feb 2, 2023 at 8:48 AM
    TundraTRD08
    Wesley
    Im gonna go measure in a bit without my wheel jacked up, then jack it up and see how much droop I have, then I get back
  15. Feb 2, 2023 at 8:50 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Whatever you do I wouldn't shove a 1" spacer between the front body and frame and not make the rest of the mounts equal.
  16. Feb 2, 2023 at 8:52 AM
    TundraTRD08
    Wesley
    Sorry if I wasn’t clear, I’m typing this kinda fast haha. The front end is the short end and kinda has more rake than factory. Im trying to get it level but would like a half inch more up front. I was just wondering if it’d be safe to add another half inch to what most people sell as max on stock suspension. I do go off-road as this is a farm truck, but I’m also in the process of making it look a lil better with some 17”s and 37s hopefully in the near future.
  17. Feb 2, 2023 at 8:53 AM
    TundraTRD08
    Wesley
    Kinda thought that the rest of the mounts would be strained… hopefully I can figure something in the front without breaking the bank, as well as make the truck useless
  18. Feb 2, 2023 at 8:54 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I meant maybe lower your front end to match what you've got in the back now.
  19. Feb 2, 2023 at 8:59 AM
    TundraTRD08
    Wesley
    Im sorry if this comes across bad, or maybe it’s me not understanding haha. It’s the other way around here. The back is higher than the front, so I would like it to have more in the front to be level, but keep my same height in the rear. If I were to lower the front it would be counter active because I would have even less than what I already have
  20. Feb 2, 2023 at 9:12 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Again....lower the rear. Lower the front to match.
    You've maxed out your suspension height unless you upgrade to a higher lift setup. What's your current setup now giving you the lift you have?
  21. Feb 2, 2023 at 9:17 AM
    TundraTRD08
    Wesley
    I think I get what you’re saying now haha. My rear setup is rear alcan leaf springs that provide 1” of lift, plus some adjustable shackles that provide .5” or 1”. The front is about to be changed from rough country 3.5” lifted struts to some bilstein 5100s at the middle setting with blocks to get back to 3.5” at least. The only reason I haven’t done that is because I need some factory front spring for them, but I may soon. I have rc uca’s and all the dropping equipment I need of course.
  22. Feb 2, 2023 at 9:22 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I believe top setting 5100s will give you 2.5". Someone can confirm or deny. You can add a 1" CB shim to get to 3.5". If your tire is a max of 35", 2.5" is all you really need.
  23. Feb 2, 2023 at 7:54 PM
    TundraTRD08
    Wesley
    I plan on setting them at the middle setting because others on here say that the ride quality is nowhere near as good at the top as it is the middle and bottom. Then of course a block to get back to 3.5, then I think I’m going to get the driver side lean corrected and be at 4”
  24. Feb 11, 2023 at 9:43 PM
    ryanallaire
    ryanallaire New Member
    Ryan
    2010 CM 5.7
    3" RC leveling kit, S&B intake, custom DIY exhaust, tuned for 91 octane, morimoto headlights, all LED interior lighting.
    I put 3" 'leveling' spacers from rough country and I still have 3/4" of rake, drives me crazy..
  25. Feb 15, 2023 at 1:58 PM
    ryanallaire
    Ryan
    2010 CM 5.7
    From what i've read 3" in the front with stock uca's is about all you should go before getting new uca's. When I installed my 3" front strut spacers it took a lot to get the uca's down enough to bolt onto the knuckles...
  26. Feb 26, 2023 at 4:19 PM
    TundraTRD08
    Wesley
    I’m about 80% sure that my rough country’s used to be taller, but have sunk down, so it looks goofy. I’ll get back when I get the 5100s on
  27. Feb 26, 2023 at 4:20 PM
    TundraTRD08
    Wesley
    Yeah, I have rc uca’s. Idk how good they are but they haven’t broke in the big bumps and levees in our rice fields yet, so I guess that’s something haha
  28. Feb 26, 2023 at 6:12 PM
    ryanallaire
    Ryan
    2010 CM 5.7
    Haha yeah the leveling kit is level sometimes and other times it's not..
