Front Tie Down Ideas for Canoe
Discussion in '3rd Gen Tundras (2022+)' started by MJH, Mar 24, 2024.
  1. Mar 24, 2024 at 9:09 PM
    MJH
    MJH [OP] New Member
    2024 Tundra SR5
    Hey there....new to the forum. Trying to get ideas on how/where to connect the front tie down for my canoe since there are no tow hooks on the 3rd gen tundras. On my 2016 I simply connected the front tie down hook to the tow hook. Any ideas? Short of an aftermarket tow hook install? Looks like mostly plastic under there....nothing solid enough to hook on to. Thanks!
  2. Mar 24, 2024 at 10:29 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Not too much to support a tie down on the front. Even wrapping around the grille to a tow hook will do some free modifications to the plastic parts.
    Perhaps a substantial roof rack or bed rack where you don't need a front tie down.
    I carry 2 x 50 lbs 12' kayaks on my rack and they are solid up there.
  3. Mar 25, 2024 at 7:07 AM
    MJH
    MJH [OP] New Member
    2024 Tundra SR5
    Thanks PBNB. It's a Thule rack system. It has cross straps as well so it's pretty solid that way. The front tie down is more for extra stability I guess? It came with the kit so I never tried without it. I never had any damage on the 2016 tundra connecting it to the tow hooks. I wonder if the 2024 grill, etc. is less substantial.
  4. Mar 25, 2024 at 7:23 AM
    tinman831
    tinman831 New Member
    DFW
    2023 Windchill Pearl 1794
    Can’t you just tie down the front of the kayak to the roof rack as well?
  5. Mar 25, 2024 at 7:26 AM
    MJH
    MJH [OP] New Member
    2024 Tundra SR5
    Not sure if that would work. Canoe extends maybe 5 or so feet beyond the front crossbar. I will try and see if that makes it more stable or not. Thanks!
  6. Mar 25, 2024 at 7:29 AM
  7. Mar 25, 2024 at 7:30 AM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    Front of canoe to each forward corner of rack could work. Then each side stops the other from moving as they are pushed side to side.
    MJH[OP] likes this.
  8. Mar 25, 2024 at 7:55 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    The front of these trucks are a bunch of plastic clipped together. Even with a tow hook underneath, your strap would be wrapping around the plastic.
    One thought would be a custom steel mount that connects to the aluminum front bumper rail behind the plastic and extends out just above the front license plate. This would provide enough support to tie down the canoe without damaging the plastic.
    MJH[OP] likes this.
  9. Mar 25, 2024 at 8:23 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    MJH[OP] likes this.
  10. Mar 25, 2024 at 8:52 AM
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    2023 Tundra 1794 Edition
    I used these to haul my Old Town 147 on a Grand Cherokee I used to own. You screw them down to a fender bolt under the hood. When you need them, you pull them out between the hood and fender. When you don’t, you tuck them back under the hood. 6 bucks at REI. Or you can buy the exact same thing from Thule and pay $30. And in case anyone is wondering, I never had any issue with them rubbing the paint off the side of the hood.
    MJH[OP] and KNABORES like this.
  11. Mar 25, 2024 at 8:55 AM
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    Here's another shot of how they look.
    Wyoming, KNABORES and Tundrastruck91 like this.
  12. Mar 25, 2024 at 9:08 AM
    jcneng
    jcneng Retired
    2023 1794 Off Road Crewmax MGM
    There was a thread a year or so ago regarding putting a front hitch on a Gen 3. That could also act a tie down point.
  13. Mar 25, 2024 at 9:30 AM
    Outbound
    Aaron
    Northern Alberta
    I believe I remember @Mattedfred having a good solution to this?
    Mattedfred likes this.
  14. Mar 25, 2024 at 11:28 AM
    Toyotaloop
    Toyotaloop New Member
    Pittsburgh
    2021 SR5 Crewmax MGM
    Very little so far
    Just buy some strap material, cut it tp 12 inches, double it over and push a hot nail through the tag ends. Hot nail pokes a hole and melts the strap material for a homemade grommet. Attach to bolt under hood as shown. Cheap diy version.
    20 years and hundreds of miles of hauling canoes in multiple trucks and never had any paint wear issues either. Better than strapping down over the hood and bumper.
  15. Mar 25, 2024 at 11:47 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    20240325_144524.jpg 20240325_144530.jpg Mine for kayak..
    des2mtn and KNABORES like this.
