Frozen Cam bolts
Discussion in '2.5 Gen Tundras (2014-2021)' started by TylerVG, Oct 12, 2018.
  1. Oct 12, 2018 at 3:57 PM
    TylerVG
    TylerVG [OP] New Member
    Tyler
    2014 Tundra CM 1794
    3/1 level
    Hey everyone,
    I tried to get my truck lined up a few days ago and they said the Cam bolts are rusted to the bushing's. Not exactly what I was hoping to hear lol. I guess my options are new lower control arms, cam bolts. Has anyone found a way to press the bolt out and just replace the bolts? or should I try to just replace the bushings and the bolts? Hoping for some suggestions on this one lol.
  2. Oct 12, 2018 at 5:11 PM
    You could try some good penetrating oil like Kroil, but I’m thinking replacements are coming.
    If you do in fact need new cam bolts, this time use some anti seize.
  3. Oct 12, 2018 at 5:16 PM
    Double Like on this...
  4. Oct 12, 2018 at 5:46 PM
    He might get lucky. When I heard about the alignment cams rusting solid, I remedied that rather quickly. Cost me an alignment, but one of mine was pretty tight.
  5. Oct 12, 2018 at 6:00 PM
    I like PB Blaster too. Do they still make "3 in 1" oil? That used to be great stuff. I'm old....is Monkeywards still open? Joking of course.
  6. Oct 12, 2018 at 7:26 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Acetone, ATF, and penetrating oil. Put some one every day for a week. Then hit them with some heat and give it a try with a breakerbar with a long pipe or an air ratchet. Make sure you're working on the nut first to get it loose then try to free up the bolt.
    If that doesn't work then get them cut out and replaced and cost them with sometime and some never seize
  7. Oct 12, 2018 at 7:49 PM
    TheBeast The Beach
    right...:D
    joonbug likes this.
  8. Oct 12, 2018 at 7:55 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    I used a balljoint press to get them out. Mine were seized pretty badly, too. I put new OEM bolts in with a bunch of anti-seize.
    jackburton likes this.
  9. Oct 12, 2018 at 7:59 PM
    jackburton
    jackburton New Member
    2019 Tundra TRD PRO
  10. Oct 12, 2018 at 8:09 PM
    TundraNoCo
    TundraNoCo New Member
    Northern Colorado, FoCo
    2018 Toyota Tundra Platinum
    Bed lined, tinted all 5 windows, hose clamped tailgate, toolbox, steps, ESP rear seat storage bins, dash cam, anytime camera switch, console safe, pop a lock for tailgate and wheels/flares, sway bar. I have Techstream if anyone local needs it.
    I've always used a ball joint press as well. Not a fan of most penetrating oils, as they are advertised. The best lubricant I have ever used is TriFlow. For my many experiences of not being able to get 3 in 1, PB Blaster, etc., to work, that stuff has never let me down. For years, I couldn't get a super heavy shower door to stop squeaking. Then I applied triflow, 1 year ago. Problem solved. And no, I don't work for them! Good stuff, available at most Ace Hardware locations or Amazon.
  11. Mar 27, 2024 at 4:50 PM
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Anyone have OEM part number for the cam bolts I’ll need?
  12. Mar 27, 2024 at 6:02 PM
    Spvrtan
    Kris
    San Diego, CA
    481900C020 & 484090C020. You'll need 2 of each.
  13. Mar 27, 2024 at 6:04 PM
    therealjonwick
    JR
    2019 OR
    Thank you!
  14. Mar 27, 2024 at 7:52 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Number #13 is the part that siezes in the bushing. It's a long tube that the bolt goes through. It's not an easy job but you have to drive out the bolts. The sleeve (#13) usually has to be cut so the control arm can be removed. I then use a long special punch to split the sleeve inside the bushing then hammer it out. Most techs like to just replace the bushing but the bushing are expensive and sometimes they don't come out of the control arms in a friendly way requiring new control arms. Spending a little time to remove the sleeves is the better way but it does take some skill to spit the sleeve so it can be removed.
    BTW, once the sleeve seizes no amount of penetrating fluid is going to loosen them.
    koditten likes this.
  15. Mar 28, 2024 at 2:10 AM
    therealjonwick
    JR
    2019 OR
    Man, wish Toyota developed these a little better. Going to put a lift on the truck in the beginning of the summer. Budgeting new control arms was not in the plans haha. Hopefully mine are still good (fingers crossed). Factory LCA are pricy. Someone recommended Moog. Idk
  16. Mar 28, 2024 at 5:01 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Moog makes some good products. Because the ball joint is not in the ball joint, I would consider Moog if the price was substantially less.
  17. Mar 28, 2024 at 5:12 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I'm going to invest into inductive bolt heater. MAP torch works, but it heats up everything around, wiring and rubber including.
    Reuse factory LCAs if can, they are very good.
  18. Mar 28, 2024 at 5:54 AM
    therealjonwick
    JR
    2019 OR
    Moog is less. Almost by half of the factory cost.
  19. Mar 28, 2024 at 6:18 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I would buy the Moog. I believe Moog has a lifetime warranty on the BJ.
  20. Mar 28, 2024 at 8:30 AM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    I’ve cut so many of these out. Even new trucks had corrosion on the cam. If it’s seized, it will need to be cut out. Don’t waste time with trying to use penetrating fluid. Poly bushings are a great replacement. Super pro makes some super solid bushings. Then you’ll need the new cam bolts to replace them with. I’ve used a grey moly grease to prevent any further corrosion on the cam bolt, but Lucas red n tacky works very good as well.
    ChesterTundra and Ruggybuggy like this.
  21. Mar 28, 2024 at 8:39 AM
    therealjonwick
    JR
    2019 OR
    Do these also come with the other parts in this photo? #16, 15, and 12? Or will those parts be reusable?
  22. Mar 28, 2024 at 8:42 AM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    13 and 14 will be the only unusable cam bolt parts
  23. Mar 28, 2024 at 9:36 AM
    therealjonwick
    JR
    2019 OR
    Awesome, thanks.
  24. Mar 28, 2024 at 1:56 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Just remember it's not an easy job and does take a level of skill. Once you start there's no going back.
    Leo's first likes this.
  25. Mar 28, 2024 at 2:16 PM
    therealjonwick
    JR
    2019 OR
    Yea doesn’t seem easy. Might have the shop do it when I do my lift. They will prob say I need new LCA’s
  26. Mar 28, 2024 at 4:07 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Maybe they aren't siezed? I've had a few that weren't on newer trucks. If you live in an area that doesn't use road salt they may be fine.
  27. Mar 28, 2024 at 4:55 PM
    Radarninja
    Radarninja New Member
    Ryan
    Ca
    From experience here.
    Air hammer them out. By far the easiest method.
    Moogs are ok.
    On my Tacoma I went moog. But…
    I later went long travel and the moogs were not compatible with my kit. Ended up buying oem again. It’s been awhile but the bolts were damn expensive.
  28. Mar 28, 2024 at 5:23 PM
    therealjonwick
    JR
    2019 OR
    Live upstate NY… they use salt. It’s only been through one winter here. Bought it last summer from PA. Truck was in Delaware and PA and they use sand. It looked perfect underneath when I bought it. No rust at all. Hopefully one winter didn’t ruin it. Thanks for all the info guys. Much appreciated.
  29. Mar 28, 2024 at 5:51 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    You might be OK.
  30. Mar 28, 2024 at 5:56 PM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Don’t know who told you they use sand, but they lied to you.
