Fuel Covert wheels
Discussion in 'Wheels & Tires' started by hennly, Jan 27, 2021.
  1. Jan 27, 2021 at 9:37 PM
    hennly
    hennly [OP] New Member
    Anyone running fuel covert wheels? +20 offset for flush look. Want to try them on 275/70/18 on stock trd sport. Any suggestions or advice?
  2. Mar 14, 2021 at 6:51 AM
    GunMetalLou
    GunMetalLou New Member
    19 Gray Tundra SR5 TSS Off Road
    Mine come in today. 18x9 +20 offset. 285/70R18 ridge grapplers is what I will be running. 2.5 front lift via fox coilover. Pics to follow!
    Also, this video may interest you... https://youtu.be/aRXSSCH6AvM
    Cheers!
    Vang530 and hennly[OP] like this.
  3. Mar 14, 2021 at 10:35 AM
    hennly
    Think 275/70/18 will fit no lift or level?
  4. Mar 14, 2021 at 10:37 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    They will, I ran that size when my tundra was stock. Only difference was I was still on stock wheels, idk if your different offset will change anything. (Unlikely)
    Skey44 likes this.
  5. Mar 14, 2021 at 10:58 AM
    GunMetalLou
    Pretty sure it will. As mentioned above offset has a lot to do with the fitment. Single digit and negative offsets is where you have to start modifying.
  6. Mar 14, 2021 at 6:23 PM
    hennly
    Fuel covert +20 offset. That’s my concern. Compare to original rims offset.
  7. Mar 14, 2021 at 6:36 PM
    Depends on the tire and offset. I have 275/70/18 on +25 wheels, and I get a little rub while backing and turning more than about 3/4 turn. Another member had the exact same wheels but 275/70/18 from a different manufacturer and he had zero rub. Not all tires are true to size. Some run small, some run large. That's why it's so hard to answer a "Will XXX size tire fit" kind of question. Lots of variables.
    hennly[QUOTED][OP] and Skey44 like this.
  8. Mar 14, 2021 at 7:57 PM
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    And it will definitely fit... that word leaves a lot of wiggle room ;)
    hennly[OP] and GODZILLA like this.
  9. Mar 20, 2021 at 11:18 AM
    GunMetalLou
    As promised..
  10. Apr 17, 2021 at 7:44 AM
    hennly
    Pulled the triggered. 275/70/18 +20 offset fuel covert stock trd suspension
    harrybdoyleiv likes this.
