Fuel Inject Cleaner.
Discussion in 'General Tundra Discussion' started by sergio5327, Mar 31, 2020.
  1. Mar 31, 2020 at 7:56 PM
    sergio5327
    sergio5327 [OP] New Member
    Sergio
    2014 Toyota Tundra Limited
    I’m looking for some advise regarding the use of Fuel inject cleaner.
    I’m driving a 2014 Tundra 5.7L and is 104 200 miles on it.
    Do you think it’s safe ? if yes, what brand would you suggest.
  2. Mar 31, 2020 at 8:10 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    I throw a bottle of Chevron's fuel system cleaner every 5k miles in my Tundra
    Jbehredt and 14burrito like this.
  3. Mar 31, 2020 at 8:13 PM
    Lucas. Get the one gallon jug at Wally World.
    Haggis777 and Flyinryank like this.
  4. Mar 31, 2020 at 8:14 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Same here except every oil change along with some seafoam.
  5. Mar 31, 2020 at 8:28 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    X2 on the seafoam we use it on all of our service trucks
  6. Mar 31, 2020 at 8:29 PM
    ARMYGREEN
    ARMYGREEN New Member
    2014 CrewMax MGM
    Seafoam every oil change! Works great. Worth every penny.
    sergio5327[OP] likes this.
  7. Mar 31, 2020 at 8:33 PM
    IBJC
    IBJC New Member
    2020 tundra sr5 crewmax Cavalry Blue
    Bg 44k for me
  8. Mar 31, 2020 at 8:36 PM
    sergio5327
    Sergio
    Thank you guys for your help!
  9. Mar 31, 2020 at 9:04 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I use this every time i gas up, does it do anything? :notsure: Will i continue to use it not knowing if I'm just wasting my money or not? :monocle:.....of course i will.
    Medic343, Batel and FrenchToasty like this.
  10. Mar 31, 2020 at 9:12 PM
    Rica25
    Ricardo
    Tulare
    I do BG Additive every oil change
  11. Mar 31, 2020 at 10:20 PM
    Batel
    Batel New Member
    2019 Tundra SR5 TRD Offroad
    Back before cleaner was added to fuel Chevron Techron was the only thing that kept my early 80's BMW's running. I tried an STP fuel treatment back then fouled an oxygen sensor upon startup. They say you can't clean an oxygen sensor. THEY would be wrong.
    SuperWhite20 and Rica25 like this.
  12. Mar 31, 2020 at 10:22 PM
    Batel
    Batel New Member
    Seafoam is great stuff. I used Chevron Techron for years but went to Seafoam sometime around 90 and haven't looked back. Both are great products.
  13. Mar 31, 2020 at 10:26 PM
    docfnky
    docfnky New Member
    If all of the carbon deposits and everything is cleaned and ejected through the exhaust wouldn’t it gum up the catalytic converters? I don’t see anything recommended by Toyota in the service manual in regards to fuel injectors or top end cleaning. They did recommend top end cleaning with GM fluids for the 2nd gen Lexus GS but nothing for the Tundra.
    Rica25 likes this.
  14. Mar 31, 2020 at 11:00 PM
    Batel
    Batel New Member
    It's been my experience, with a few exceptions, the car manufacturers are reticent to admit their product needs additional maintenance to keep running well. That being said, if you have a partially fouled injector issue most dealers will run a professional product, 3M used to make a good one, to clean your injectors. This is costly and I think with today's fuels your vehicle probably doesn't need any treatment of any kind unless it's driven short distances and never warms up. I've run fuel either Seafoam or Techron for 35 years in a variety of fuel injected engines, both mechanical and electronic injection and have never had a problem with a cat. Catalytic Converters run extremely hot and tend to burn off the residues. Interestingly, I've replaced about every major component on a vehicle at some time or another and have never replaced a cat. I run Seafoam in my Tundra because it tends to make a lot of short trips to town and rarely gets out and opens up the injectors.
  15. Apr 1, 2020 at 12:28 AM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    I buy one small bottle of Lucas and a huge bottle for refills from Walmart
    Rica25 and ColoradoTJ like this.
  16. Apr 1, 2020 at 1:31 AM
    I can’t remember if it was in here or TacomaWorld, but either way it makes a point.
    One member after 200K miles sent the injectors in for testing. Shop sent them back and told him they looked good....run them. The member never used fuel treatment at all, just fueled and drove.
    Some vehicles require some additional cleaners due to design like direct injection fuel systems. My Lexus, if I don’t use Lucas oil treatment every oil change and “whatever” fuel cleaner a few times per year, the motor gets really loud (like a rod bearing is going).
    Rica25 likes this.
