Fuel mileage dropped drastically overnight-help!
Discussion in '3rd Gen Tundras (2022+)' started by 2022-1794-4x4, Jan 10, 2023.
  1. Jan 10, 2023 at 4:14 AM
    2022-1794-4x4
    2022-1794-4x4 [OP] New Member
    Has anyone else had any issues with their fuel mileage just dropping all the sudden and staying there. move got a 3in lift of 35s, so naturally I’ve lost some fuel mileage but I was averaging 15.5 mpg for the last 6 months or so. I town my 1500lb side by side on an 8 hour trip and averaged 12.5 miles a gallon. Okay, fine no problem. On the way back home I started averaging 8.5 8.8 got up to 10.8 or near there. Now even without the trailer I’m sitting around 12.5-13.3. Same fuel same everything. Checked my air filters, tire pressure you name it. Is this maybe a turbo issue?? No check engine lights.
  2. Jan 10, 2023 at 4:22 AM
    You have recalibrated the speedometer and hand calculate right?
    ryanwgregg and 2022-1794-4x4[OP] like this.
  3. Jan 10, 2023 at 4:44 AM
    2022-1794-4x4
    To Colorado TJ and you. I have calculated by hand. Not done a spedo cal. The computer is what made me start doing it by hand. It’s within the computer mpg average by a few then a here or there. Just couldn’t imagine how all the sudden with absolutely no changes to anything, it drops average 3-4mpg and sometimes even more. “Normal driving conditions” cruse control on 60mph or just driving normally. Etc etc
  4. Jan 10, 2023 at 4:50 AM
    2022-1794-4x4
    So I stared here in Atl and drove down to Tampa Florida. Then towing around in Florida during the holidays I started having the massive drop. Chalked it up to towing The sxs but then while not towing it still sucked and has stayed that way. Of course I’ve cleared all mpg history and all that on the computer just to start from a clean slate. Still the same.
  5. Jan 10, 2023 at 5:00 AM
    2022-1794-4x4
    I’m lost at this point. I don’t dare even consider asking the dealer, I know they’ll be absolutely no help. I’ve check my air filters, hoping on the 1% chance there’d be a plastic back in one of them or something, but no. Unplugged the negative cable for about a minute. But I’ll try 10 mins.
  6. Jan 10, 2023 at 5:05 AM
    It’s easy to calculate mileage on long trips with GPS to figure out the losses with the bigger tires. In town is a lot more difficult.
    If you do a hard reset on your ECM, the truck will have to relearn your driving habits. FYI.
    I would give it a couple tanks and see if it improves.
  7. Jan 10, 2023 at 5:06 AM
    2022-1794-4x4
    I’ll give er a shot. Idk what else in the world it could be.
    willy and ColoradoTJ like this.
  8. Jan 10, 2023 at 5:13 AM
    Hope you find a resolution. Fuel isn’t cheap!!
    willy likes this.
  9. Jan 10, 2023 at 5:20 AM
    TWade
    TWade New Member
    Tanner
    2023 Tundra TRD Pro Black on Black
    Ill ask the stupid question. Did you reset your MPG readout prior to driving after towing? If not, it is still averaging the ~8MPG you got when you were towing. I tow a 23.5 foot boat and always reset my MPG gage to make it more realistic.
    LimitedLuck and iiawah808 like this.
  10. Jan 10, 2023 at 11:07 AM
    xc_tc
    xc_tc New Member
    Sometimes it’s wind or grade that causes big differences in fuel economy on the same route.
    HLR_NM, snivilous and Terndrerrr like this.
  11. Jan 10, 2023 at 11:12 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock with trail boxes
    Try non-ethanol fuel, winter fuel tend to have more ethanol (up to 10%) and it can be lot less efficient than ethanol free fuel, usually I see quite bit mpg drop in winter when they switch to higher ethanol blend, then it quickly returns to normal after one or two tank of ethanol free fuel.
    FYI, you have higher chance to find ethanol free on octane 91.
    ElectricMan likes this.
  12. Jan 10, 2023 at 11:13 AM
    2022-1794-4x4
    Yeah I took that into account. Did it both ways, and still up here at home now too. Hard to say what’s going on.
  13. Jan 10, 2023 at 11:19 AM
    2022-1794-4x4
    I’ll check it out, and all your guys tips are good tips. But I can’t find a reason for the sudden 4 or so mile mpg drop. That’s huge.
    I’ve heard non-ethanol burns a lot whats up Omer, but I’ve never really looked into it. I’ll give it a try. I’m sure there’s some near me somewhere
  14. Jan 10, 2023 at 11:21 AM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Dumb question. Are you sure your parking brake is fully released?
  15. Jan 10, 2023 at 11:23 AM
    2022-1794-4x4
    Yeah I did. On the way down it was good relatively speaking. From 15.5 to 12.5-13. It was later during the trip it just dropped drastically. And now still does even with no trailer. I’ve reset all the trip and mpg gauges. Tried to reset the ecu by unplugging it 10 mins not sure if it did or not.
  16. Jan 10, 2023 at 11:25 AM
    2022-1794-4x4
    I hope so, it’s electronic. It either is or isn’t, as far as pressing the button. But you’d think it’s something like that to drop 4mpg. It’s something major or a bad ecu read out. A little tire pressure or a dirty air filter etc etc (which neither I have) would drop 4 mpg.
  17. Jan 10, 2023 at 11:29 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Does the exhaust smell rich cold? Warm?
    an engine is a pump, and this fancy efi only uses the fuel to satisfy the requested power. Make sure your brakes or pulleys arent dragging. You better believe i see the irony of a dude with a lift and 35's whining about fuel milage. Whats your tire PSI?
    willy likes this.
  18. Jan 10, 2023 at 11:32 AM
    Believe someone on here had a sticking rear caliper, not sure if it was the main or parking brake. A temp gun after a drive would reveal the difference in hub temps if that was the case.
  19. Jan 10, 2023 at 11:33 AM
    2022-1794-4x4
    I’m not whining about fuel mileage as that I’m not getting what everyone else is getting. It’s that I’ve had the lift and tires for 6 months and ALWAYS been at 15.5 then all the sudden it’s 10-11 with no change. Exhaust smells the same. No hot wheels or calipers. No check engine lights. No new sounds or feelings when driving or idling. Wondering if every little problem with the turbos would through a code or not.
    tire psi is right at 40
  20. Jan 10, 2023 at 11:40 AM
    SwitchThrottle
    SwitchThrottle Living in Idiocracy
    2021 Barcelona CrewMax
    You sure this is not a uphill into the wind difference? My 2.5gen averages mid 20s driving from my moms house to my house, but mid teens on the way back.
  21. Jan 10, 2023 at 11:45 AM
    2022-1794-4x4
    Positive. Same rounds I’ve been driving since I got the truck.
  22. Jan 10, 2023 at 11:56 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I didnt mean nothing by it. When i drag my truck down to 16 i curse myself, and promise to drive easier next time. I had an instant mpg gauge in my moms sequoia, learned that killing overdrive below 60 saved lots of fuel. Whats peak torque start at 1500rpm? Do the math and see which gear is happiest at 1500 rpm. Maybe whatever lockup is. Thats my theory on why the other guys sequential mode defaults to whatever gear locks up. (nissans have a rev matching thing), my moms newer qx80 drops to whatever gear is in lockup at whatever speed, (i use engine braking as much as necessary) and it'll be 6th or 7th depending on who i settle behind 60-70mph, the titan doesnt offer OD in sequential mode, but i would love to run a toggle or flappy paddles on my tundra to give me control of the solonoids, instead of an OD button and shift lever.
  23. Jan 10, 2023 at 12:13 PM
    art64
    art64 New Member
    OP, how's the rpm while cruising? I'm just wondering if the transmission if shifting all the way to 10 and not getting stuck to 9 or 8. Did you notice a change of rpm after the towing? How about turbo boost? Did you notice any change in boost or if the turbo stay in boost in more time than before the tow? Really curious about this.
    Have you disconnected the battery for a few minutes to reset everything? Not sure if it will work but maybe worth trying.
  24. Jan 10, 2023 at 12:32 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    I’m gonna guess sticking caliper or parking brake. Or maybe your trans isn’t going into the overdrive gears. Something isn’t right. That’s a drop of 30-35%.
  25. Jan 10, 2023 at 12:52 PM
    Jaxyaks
    Jaxyaks New Member
    The difference in mileage difference on the return trip from Tampa to ATL is not surprising, you are going uphill. Where did you get gas?, have you run thru the tank with the "low mileage yet".
  26. Jan 10, 2023 at 1:24 PM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    May be a dumb question but just trying to rule stuff out with everyone else. Are you using remote start more than you were? Idling with remote start dropped my mpg average 2-3 mpg.
  27. Jan 10, 2023 at 1:51 PM
    2022-1794-4x4
    No I’m up for all questions. I’m hoping there’s an “ahha moment” but I’m not sure there will be haha.
    No I actually use it a lot more in the summer when it’s hot, than now. But even then never noticed a drop in mpg. I use it time to time now, but not often.
  28. Jan 19, 2024 at 7:28 AM
    1Tundra5
    1Tundra5 New Member
    Junior
    2015 White SR5
    How do you calibrate the speedometer?
  29. Jan 19, 2024 at 8:25 AM
  30. Jan 19, 2024 at 8:42 AM
    This is a bit troubling. So you say nothing has changed on the truck (lift tires driving habits etc), then maybe we should start looking at other things:
    Alignment. This can still be in spec and reduce fuel economy drastically.
    Winter/summer fuel blends. I have never lived in the SE part of the country so not totally up on fuel blends where it doesn't freeze often. I will say this, my vehicles take about the same hit in fuel economy as you during the winter months (Sept-May).
    Adaptive learning when towing. I really don't think this is it, but when I tow a lot with my truck, it takes a bit to get back to a normal fuel trim/transmission shifting. Your truck is programmed for towing performance over fuel economy, that's for sure.
    When towing, do you use premium fuel? (I would always use premium fuel anyway)
