Fuel Stabilizers?
Discussion in 'General Tundra Discussion' started by Lug Nut, May 27, 2021.
  1. May 27, 2021 at 6:13 PM
    Lug Nut
    Lug Nut [OP] New Member
    2021 Limited TRD
    Bone Stock
    Love my 2021 TRD.
    After 6 months of ownership, I’m still on the 2nd tank of gas.
    The 38 gallon tank seems to have more than one compartment and I’m not sure how long fuel may remain in a compartment, especially for this truck that will see little use.
    Is it recommended to use a fuel stabilizer for recreational Tundra’s that see little use?
    I hope to take it on two road trips per year and I try to drive it at least once per month for a short freeway trip.
    I used Lucas fuel treatment in my 97 taco for over 20 years, in every tank of gas. That thing still runs like new.
    Metro14536 likes this.
  2. May 28, 2021 at 3:58 AM
    Shamrock92
    Shamrock92 New Member
    My opinion - couldn’t hurt, but more importantly is keeping the tank topped off before long periods of inactivity.
    Space in a tank is room for humidity to build - water in fuel.
    Pure gas in small engines is important as they use a carb and are highly sensitive to that moisture draw. In a V8 - those additives in ethanol gas actually do good - but again this is with frequent use.
    Running pure gas might be an idea too in place of a stabilizer. Potentially adding some sort of injector cleaner occasionally before use (but really if it’s not being run regularly and with quality gas - injector cleaning shouldn’t be needed too frequently)
  3. May 28, 2021 at 5:11 AM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    Star Tron is cheap may as well add it at each fill up.
    DSLKSL and Sundog like this.
  4. May 28, 2021 at 8:07 AM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    I would use stabilizer. It is cheap insurance. If you can run non-ethanol gas that would be better too. I have gotten to where I put stabilizer in anything that is going to have gas sitting in it for a few months. I always use it in gas I put in a portable can. I figure, why not.
    Startron or marine Stabil is usually what I use.
  5. May 28, 2021 at 8:14 AM
    Blue Thunder
    Washington
    If you are burning through a tank of gas in just three or four months, I wouldn’t worry about it. Stabilizer won’t hurt but I don’t think it is needed.
    I don’t know what you mean by compartments inside the tank. I think there are baffles, but everything has to be open so gravity can draw the most gas to the pump. Just don’t fill your tank until your down at 1/4 and that should be fine
    Lug Nut[OP] likes this.
  6. May 28, 2021 at 8:40 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    This is the best I have used for autos, motorcycles, yard machines.
  7. May 28, 2021 at 8:47 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    I have not had good luck with anything from Sta-Bil unfortunately. Especially chainsaws. Switched over to Star Tron years ago and no issues since.
    DSLKSL likes this.
  8. May 28, 2021 at 8:57 AM
    frichco228
    I didnt like the regular stabil either. Startron is good stuff and we use it in the boat motor shop.
    The marine 360 however has been great in motorcycles and things with steel tanks. Addresses the ethanol and as it sits in the tank releases fumes that coat the inside of the tank to keep it protected and clean. The inside tank of my 2006 motorcycle was so clean it looked like it had never been used.
  9. May 28, 2021 at 9:01 AM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    Just for kicks if your into youtube watch the fortnine video about motorcycle stabilizer. Also project farm covered some good ethanol issues.
    Seems most agree that 45-60 days is the self life of ethanol gas and the plastic gas tank in the truck doesn't help.
    I agree with posts about volume and air space listed here (the more air space consumed by gas the less the moisture can get in the tank?
    Take it for what's it worth.
    (note project farm tested the stablizers listed in this thread, no very promising results, but again its the internet).
  10. May 28, 2021 at 4:09 PM
    Lug Nut
    2021 Limited TRD
    Bone Stock
    Thanks, guys. Lots of informative replies.
    45-60 days is shorter than I thought. Really good to know.
    I think I’ll keep it full and just drive it more often. I doesn’t take much to guzzle gas in these trucks.
    And probably use Lucas fuel additive in this truck too.
  11. May 29, 2021 at 6:24 PM
    mb66l79
    mb66l79 New Member
    Seafoam has worked wonders as a stabilizer for me.
  12. May 29, 2021 at 7:34 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    Make sure your fuel stabilizer is one that will prevent Ethanol from breaking down or there’s no point. +1 for ethanol free in your case.
