Fuses
Discussion in 'Electrical' started by Roughneck18, Nov 27, 2022.
  1. Nov 27, 2022 at 11:10 AM
    Roughneck18
    Roughneck18 [OP] New Member
    Louie
    2019 white Tundra Trd off-road
    Trd exhaust
    Looking for fuse diagram for ‘19 limited crewmax.
    Thanks
  2. Nov 27, 2022 at 1:20 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Which fuse box. There is one under the hood and one in the interior under drivers side dash
  3. Nov 27, 2022 at 2:25 PM
    Roughneck18
    Louie
    Trd exhaust
    I’m thinking driver dash. I think i blew the charging ports. Only 1 is working.
  4. Nov 27, 2022 at 2:42 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Which charging ports are not working?
  5. Nov 27, 2022 at 2:49 PM
    Roughneck18
    Louie
    Trd exhaust
    All 3 rear and the 2 12v in front
  6. Nov 27, 2022 at 3:06 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    The two fronts are on power outlet #1 fuse while rear are on power outlet #2
  7. Nov 27, 2022 at 3:09 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Power out let number 1 is in the engine fuse box. Power outlet number 2 is in the interior fuse box under the dash. I posted the layout of it above.
    This is part of the engine fuse box
  8. Nov 28, 2022 at 4:19 AM
    Roughneck18
    Louie
    Trd exhaust
    Excellent, thanks bro
