Garage Doors Operate without Key
Discussion in '2nd Gen Tundras (2007-2013)' started by Kabra, Jan 28, 2020.
  1. Jan 28, 2020 at 8:19 AM
    Kabra
    Kabra [OP] New Member
    I have 2014 Limited and the garage door buttons are operational without the key. That's a concern since it's parked outside and all someone needs to do to get in the garage is break in to the Tundra and hit the button. Does anyone know of a way or a hack to solve this problem without making the buttons inoperable?
    Curious if this has been discussed before as I couldn't find any existing threads about it.
  2. Jan 28, 2020 at 8:28 AM
    08crewmax
    08crewmax New Member
    CA
    ‘08 Pyrite Mica Crewmax Limited
    We have a power switch on the inside of our garage for this reason.
  3. Jan 28, 2020 at 8:36 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    This is known, it's been discussed, and nothing has come of it in terms of a satisfactory solution.
  4. Jan 28, 2020 at 8:45 AM
    Kabra
    And you turn it off at night or when you're not home? I'd be forgetting a lot plus have two vehicles that do go in the garage.
  5. Jan 28, 2020 at 8:50 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    since this topic comes up every few months, here's a question: what would you do if you had a dedicated opener remote? would you leave that in your vehicle at all times? if you do, how is that any different from the built-in buttons being on all the time?
  6. Jan 28, 2020 at 8:51 AM
    Kabra
    I did see someone added GDO functionality to their Tundra that didn't have it and wired it to a circuit that's only hot when the ignition is on. That's a great idea but that mod sounds easier said than done for a factory setup. Thinking out loud maybe there's a third party opener that works with 12v I can wire into an ignition triggered circuit like that guy did.
    Wynnded[QUOTED] likes this.
  7. Jan 28, 2020 at 8:53 AM
    Kabra
    It's no different at all and I'd be looking for an alternative for that as well!
    Sunnier likes this.
  8. Jan 28, 2020 at 8:56 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    And aren't all vehicles like this? :notsure:
  9. Jan 28, 2020 at 9:01 AM
    Kabra
    The GDO buttons on my car only operate with the ignition on.
  10. Jan 28, 2020 at 9:10 AM
    Kabra
    I found a 12v homeland button set on Amazon but it's $149 and I'd still need to wire and mount it. In the process I think I figured out a good work around. One of those key code openers and they're only $30. The downsides of course is that it's larger which isn't a big deal and I need to enter a code every time I use it. But I think that would be far easier (for me anyway) to remember to turn a power switch on or off to power the GDOs.
    Thanks guys! I think you helped me solve this.
    Keypad Remote:
    https://www.amazon.com/gp/product/B00715DTJQ/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
    12v Homelink Remote:
    https://www.amazon.com/HomeLink-60-HMLKV5BLK-Wireless-Control-Headliner/dp/B00A79G9FY
    Sunnier likes this.
  11. Jan 28, 2020 at 9:10 AM
    Trooper2
    JR
    Interesting, the few vehicles I have had do/did not require the ignition to be on.
  12. Jan 28, 2020 at 10:40 AM
    rebmo
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Is this a techstream setting? Seems like default should be GDO works only with vehicle on. Will operating trigger alarm if non fob entry ? I have glass break sensor assuming that works.
  13. Jan 28, 2020 at 10:47 AM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    I was concerned at first when I bought my Tundra since the GDO buttons work with the truck off (previous cars only worked with ignition on) but you are 100% correct about the old school garage remote .. people leave them in the car for the night without thinking twice about it. I realized if someone wanted to get into my garage they could just as easily break the glass window on the normal door to the garage and let themselves in that way which would be easier than hoping the truck had an opener. Also garage door RF "security" is a joke and any kid with 5 minutes and a HackRF can grab your code in the morning and let themselves in after you leave without you ever knowing (or they could go old school with a coat hanger ... https://www.corporatetravelsafety.com/safety-tips/how-thieves-break-into-homes-by-the-garage-door/).
    So in the end do the most you can to prevent or discourage such things. The driveway is well lit at night and there are cameras also if the garage door opens the smart home system will automatically lock the deadbolt on the inside garage door to the house if it's unlocked as well as the alarm sensor on the garage doors and window.
    Trooper2 likes this.
  14. Jan 28, 2020 at 11:33 AM
    Dr_Al
    Dr_Al New Member
    Al
    If you have a modern opener it'll use rolling code technology that can't easily be hacked. Back in the day openers only used a few different codes and they were set with dip switches. Now each time the remote is pressed a new code is generated between the two. If you're worried about you car being broken into and the door opened then you should think about switching to a cell phone app based approach. Something like MyQ from liftmaster.
    As for which is better, the buttons on the mirror or a clip on remote, one of the two can be stolen and since your address is in your glove box a thief would know exactly where to go even if you aren't parked at your house. All they would need to do is steal your remote and replace it with one that looks the same. You would get home and push the button thinking that it just needed resetting and nothing more.
  15. Jan 28, 2020 at 11:48 AM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Three Solutions:
    1. Use the deadbolt
    2. Plug your garage door opener into a Wemo Switch and use your phone to turn your opener on and off via Wifi. I have mine set to a schedule to shut off automatically at a certain time, then come back on again in the morning.
    3. Ultimately I decided not to use the mirror and went this route with the OEM remote and hid the button. https://www.howtogeek.com/189435/add-a-hidden-garage-door-opener-to-your-vehicle/
    Joss1799 and tinman10101 like this.
  16. Jan 28, 2020 at 12:07 PM
    abomb60
    Massachusetts
    In all honesty i'd be more worried about leaving my car/truck with a sketchy valet for a number of reasons.
  17. Jan 28, 2020 at 12:10 PM
    If you don't park your truck in the garage, why did you program your buttons to open it in the first place?
    ColoradoTJ and Jrharvey02 like this.
  18. Jan 28, 2020 at 12:14 PM
    abomb60
    Massachusetts
    Convenience. It's easier to park the truck and open the garage door to walk in than get out keys and open the door manually. For me the convenience is worth the potential security trade off as I have other security in case someone breaks into the truck and opens the garage door (alarm, cameras, inside door locks, attack kittens, etc). Also when the truck is in the driveway 99% of the time I am home so the potential of someone using the garage door opener in my truck to get in without me knowing is minimal.
    radon222 likes this.
  19. Jan 28, 2020 at 12:16 PM
    KMG
    KMG New Member
    Kevin
    Yacolt, WA
    2018 White Tundra Limited DC 4x4 TRD
    BFG KO2s, TRD Rear Sway Bar, Firestone RideRite Air Bags, B&W Gooseneck Hitch, Trail Ridge Extendable Towing Mirrors
    Maybe so he can enter his home through the garage door
    Cement4WD, AKJ78 and abomb60 like this.
  20. Jan 28, 2020 at 12:27 PM
    Sephon
    Sephon Don't be an American't
    Northwest PA
    2020 Black Tundra TRD Pro
    Icon Rebounds w/285/75 BFG KO2’s, Coachbuilder +2
    If they someone is willing to smash glass to break into your truck, they are willing to smash glass to break into your garage or house.
    Worry about whether or not your aim is true. Not which glass they have to break first to push the button to open your doors.
    Cement4WD, Worriedman50 and abomb60 like this.
  21. Jan 28, 2020 at 1:08 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    Both our garage door buttons in the garage have a "lock" option.
    Cement4WD likes this.
  22. Jan 28, 2020 at 1:10 PM
    Dr_Al
    Dr_Al New Member
    Al
    I guess it's different for each one of us. For me I don't lock doors as if someone wants in they would just damage more stuff. I'm too far away from any houses to hear someone breaking in and it would take police far too long to get here. I park my car in the garage and my truck outside (my tractor's in the other bay). I don't have a Homelink mirror in my Tundra but my Rav4 has one. The truck has a remote in one of the overhead compartments. What I do like about the mirror is that my opener must send out a signal and the mirror tells me which direction the door is going with a yellow triangle and then it turns green once it's finished. If I'm closing it and it reverses course the triangle will show it changed directions. Much nicer than trying to look in the mirror at an angle to make sure it closed.
    For those who don't use their garage as a place to store your vehicle I would suggest a keypad like Kabra posted a link to. Or, just hide a remote somewhere and not use the Homelink mirror.
  23. Jan 28, 2020 at 2:10 PM
    Kabra
    Haha that's a great question! My truck is often used as a truck rather than just transportation. So it's pretty frequent that things from the garage are going in the truck or visa versa. Or even just taking groceries in is a more direct route through the garage.
    AKJ78 likes this.
  24. Jan 28, 2020 at 2:18 PM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    I think this is an example of the old adage "1st World Problems". Most residential locks basically keep honest people honest.
  25. Jan 28, 2020 at 2:22 PM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
    I had the same exact concern and carry a small remote with me. I have a piece of velcro attached to it and a small piece on the console just under the 4WD select knob. I'll attach it there when I'm in the truck, then take it inside when I exit the truck.
    I'd rather the mirror button option be inoperable without the key in the ignition but from the Infiniti, Corvette, and Mazda I've had, all operate without the key.
    Here is what I use now:
    https://www.amazon.com/Pack-Replace...all+garage+door+remote&qid=1580250013&sr=8-15
  26. Jan 29, 2020 at 7:40 AM
    08crewmax
    CA
    Two cars in the garage here. Then the power switch off to opener when we are all inside and down for the night
  27. Jan 29, 2020 at 8:10 AM
    Figured that much, but wanted to know if there was a specific reason beyond the obvious. If the security is a concern for the OP the simplest solution is to go through all the hassle of using a third party opener and carrying it with you when you leave the truck. That or use your regular keys for the man door, if your garage has one.:notsure:
    IMO this just seems to be a search for a solution to a problem created unnecessarily. Reprogramming is overly complicated when it can be resolved with in either of the two ways listed in here.
    KMG[QUOTED] likes this.
  28. Jan 29, 2020 at 9:50 AM
    Kabra
    I'm the OP and I just don't like to create situations where I have one more thing to remember as I want to simplify my life and these little things add up. I have a car and truck and drive and drive them both about the same. The truck is kept in the driveway and the car in the garage. Taking the remote inside with you is a reasonable solution and maybe fine for a lot of people. For me it will be a nuisance I don't want. If you didn't see the solution I figured out in all the discussion, it's to use a remote with a keypad and keep it in the truck. I don't need to open the garage every time I drive the truck (maybe 1/3?) so for me this should be a great solution. A little more trouble than hitting a single button but I'll use a four digit code and that's not much more pain.
  29. Jan 29, 2020 at 9:57 AM
    radon222
    radon222 '21 CrewMax / '18 4Runner
    Ed
    NW Arkansas
    2021 CrewMax TRD OffRoad
    Stock for now
    I've had the same concern but our Liftmaster control pad in the garage has Lock button that disables the opener.
    Other options... key fob size third-party openers. Or make it a SmartHome opener for a few bucks.
    https://www.youtube.com/watch?v=SMhcsfr29Yg
  30. Jan 29, 2020 at 10:55 AM
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    My 2017 was the same way. I contacted Bob at http://www.bobsmirrors.com He made me a pigtail that was simple to install between the mirror and the harness. Now my homelink only works with the key in the on or aux position.
