Gas Can Storage
Discussion in 'General Tundra Discussion' started by Timx9595, May 12, 2021.
  1. May 12, 2021 at 5:39 PM
    Timx9595
    Timx9595 [OP] New Member
    Connecticut
    2020 Black Tundra Crewmax SR5
    Who’s found a good option for storing and securing gas cans in the bed of their truck? If possible I want to avoid drilling holes but I know that might not work. I’m open on the type of gas can but don’t like the idea of them becoming a potentially explosive projectile in bed of my truck.
  2. May 12, 2021 at 6:31 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    I have a Wavian can and their bracket. I drilled the bed. It’s rock solid.
    Black Wolf likes this.
  3. May 12, 2021 at 7:38 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Cut a 2" X 12" board long enough to fit in the slots stamped into the sides of the bed. The slots are located right behind the rear wheel tubs, which gives you about 2' to stow gas cans and any other packages between the board and the tail gate without having them loose in the bed. Easy to load, easy to unload. Run a rope through the handles if you're worried they may spill.
    I don't keep gasoline in my truck bed, but when I make a trip for mower gas, this works well. This can is extremely stable and hard to tip:
    https://www.amazon.com/gp/product/B00004Y75M/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8
    15whtrd likes this.
  4. May 13, 2021 at 6:07 AM
    Kung
    KG, VA
  5. May 13, 2021 at 6:54 AM
    El Two
    El Two I’m only talking to my dog today.
    Lisa
    2018 SR5 Crewmax TRD Off Road
    How much time do you have? . . . . . . . . . . . . . . . . . . . . .......... Eaton rear eLocker, Camburg 1.5” shackles, Rear Seat Delete, S&B CAI, sPOD, Air Bag Helpers w/ Daystar Cradles, RCI engine & fuel tank skid plates, ABS Guards, Job Box Storage, Tailgate Power Lock, Desert Eagle Offroad tranny/cat security skid plate, Added Driver’s Side Grab Handle, VLEDS Footwell & Step Lighting, Anytime Front Camera, Illuminated Ignition Ring, Console Molle Panel, Sound Dampening in Ceiling/Doors/Floor, Yakima Rack, Paracord Grab Handle Wraps, BD Underhood Light, Tuffy Console Safe Insert, WeBoost System, Midland GMRS Radio, Console Interior Lighting, Power Inverter, Custom Center Switch Panel, and Dual Air Compressors
    I made a frame out of 1515 extruded aluminum and secured it to the bed rail. Then added a RotoPax mount with extensions. I can move the frame anywhere in the bed of the truck depending on what I’m hauling. I can also move the containers without hassle to any of our two other 4x4s that also have the RotoPax mount. Gives me a lot of flexibility. I’ve taken two 5,000+ mile trips and the containers didn’t budge an inch.
    EN2TUNDRA and JLS in WA like this.
  6. May 13, 2021 at 6:55 AM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    I have one of these for lawn mower fuel and can say that they are absolutely the best and 100% safe. Not a drop of gas will escape.
    Kung[QUOTED] likes this.
  7. May 13, 2021 at 7:03 AM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    Same here. :thumbsup:
