Gas Gauge Reads Above Full
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by locomocos, Jun 28, 2024.
  1. Jun 28, 2024 at 2:28 PM
    locomocos
    locomocos [OP] New Member
    2021 tundra sr5 5.7 v8 RWD
    So I just acquired a 2021 tundra, love it so far, gas gauge was at half from the dealer, filled up , drove home, drove the next day, truck sat for a day and a half and when I went to drive it again, the gas gauge needle reads as above full with the truck on and when the trucks off the needle sits right on the full line. My digital gas gauge still reads miles as i was full then decreasing as i drive now so i still have some way of seeing if the truck has fuel. any fixes? i tried the truck on, shift to drive, shut truck off wait and then shift to park but that didnt do anything to my needle. Any fixes other than that which wouldnt be replacing the needle?
  2. Jun 28, 2024 at 2:35 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    This is entirely normal for most rigs when full. I can usually go 50-60 miles before it drops below “full”
    On the other end, it will drop faster.
    Also expect to have 6-8 gallons of “reserve” when the fuel light comes on…your 38 gallon tank will take 30-32 gallons to fill.
    ZappBrannigan and Tundra234 like this.
  3. Jun 28, 2024 at 3:31 PM
    locomocos
    only thing confusing me is it reads 256 miles left which was below half just barely when i bought it from the dealer, after filling it did go to full then it randomly jumped to the farthest point above full , thats normal?like it isnt on the "full" line its way above it
  4. Jun 28, 2024 at 3:51 PM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Yea, mine goes past full a little, every vehicle I've had did, but not that much. I never have DTE up on my display but I always fill my tank and reset my tripometer, 400-440 miles is roughly what I get before needing to refuel. I'd at the least disconnect the battery for a bit and see if something resets, worth a shot.
    locomocos[OP] and BiiigTruck like this.
  5. Jun 28, 2024 at 3:58 PM
    BiiigTruck
    BiiigTruck New Member
    2016 TRD Off Road Limited
    Exactly this, Its normal to go slightly above the "F" but that seems much farther than normal, and definitely farther than any gauge I've ever seen.
    locomocos[OP] likes this.
  6. Jun 28, 2024 at 4:00 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Does the gauge seem operational otherwise? I would be inclined to chalk it up to a neat quirck about your truck. I'd rather my gauge do that than the empty light come on and I have a whole 8 gallons (30%) of the tank left!
  7. Jun 28, 2024 at 4:32 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Ok
    That picture tells a different story
    That’s fucked up
    “Above full” is like a needle thickness at most- not half way to the other side.
    Changing the needle isn’t really an option, but something ain’t right with the gage cluster
    I would start with pulling the negative battery terminal for ~15 minutes to fully reset all the various computers
    Note that doing so will reset any mileage/mpg calcs and your truck will think it can go ~600 miles on a tank for your first 3-4 tanks after that.
  8. Jun 28, 2024 at 4:37 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Also - you are still under the factory warranty (maybe barely depending on original sell date of the truck) - get it into a dealer to get the issue documented so it’s on record before the warranty is past.
  9. Jun 28, 2024 at 9:08 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Yeah, that's not normal...
  10. Jul 12, 2024 at 8:40 PM
    locomocos
    Update : the gauge ended up resetting itself after a couple weeks and it’s back working normally again. , not sure what caused it in the first place but it’s accurate and normal again , thanks for the replies to the post everyone
