Gas Mileage When Towing
Discussion in '2.5 Gen Tundras (2014-2021)' started by JWWard03, Aug 17, 2023.
  1. Aug 17, 2023 at 8:09 AM
    JWWard03
    JWWard03 [OP] New Member
    James
    2021 Tundra SR5 CrewMax 4x4
    Hi all. I've got a '21 CrewMax SR5 4x4 and tow a 4k lb travel trailer quite a bit. I'm getting 8-9 mpg when towing a max of 70mph on the highway. 55-60mph gets me 9-10. Does that sound right? I upgraded the tires to 34s and did a 2-1 level/lift so I lost some mpgs there. I know mileage sucks on these and I'm not looking for upper teens, but I keep seeing Tundra towing videos saying they are getting 12-13 towing heavier than I do.
  2. Aug 17, 2023 at 8:18 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I dont tow but from the many threads I have seen on this forum, getting 9-10 is normal to slightly higher than average I think. Keep in mind terrain is going to play a big role. Someone towing across Oklahoma is going to get better mileage than someone towing through the mountain west.
  3. Aug 17, 2023 at 8:20 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Its the tires.
    my trailer is 4300 lbs, stock tires i get 12-14 towing at 60-65
  4. Aug 17, 2023 at 8:25 AM
    JWWard03
    James
    I figured they played a big role.
  5. Aug 17, 2023 at 8:26 AM
    rockR67
    rockR67 New Member
    Northern Louisiana
    2018 Cement SR5 (sold)
    a few other things standing in ... for now.
    Yeah, I'd think the tires too. I've seen 12ish on my '18 towing about 5500lbs. It's a HiLo so there's a bit of wind reduction there, but still heavier than what you're hauling.
  6. Aug 17, 2023 at 8:30 AM
    Chelly
    Chelly ...
    Mt Hood / PDX OR
    2020 Platinum - Super White
    Elka DSC Suspension, Ray-10s, MaxTrax, Dirt King UCA, 295/70/18 Toyo AT3, TRD Skid + Intake, .25 Bumper Shim, UnderCover UltraFlex Tonneau, RoadActive Suspension, Tuffskinz, etc.
    I get about 10-11 pulling the 7k airstream. Pacific NW with hills and such, you can do pretty well watching your speed, right around 65 seems to be the sweet spot (on stock gears, Lift, 295/70/18 ~ 34.5") tires. Puts the 5.7 right where it wants to be with torque converter locked in 5th. The hills and stop and go will get ya, I try to watch my acceleration as reasonable and that helps a bit and making it up on the downhills helps as well.
    Edit: I also run premium while towing, as much as it hurts to do so at the pump. Keeps the ECU from pulling timing under load, but thats a separate thread / debate.
    HulkSmurf14 likes this.
  7. Aug 17, 2023 at 8:35 AM
    SD Surfer
    Bruce
    So Cal
    Sounds about right... I see those posts too, and I have trouble believing that it's consistently 13 mpg. Yeah, sometimes I get 12-13, sometimes I get 8. Coming back from the mountains I get 20! ('Cuz it's all downhill)
    When I'm budgeting a trip I just figure on 10, and when the gas gauge get low I fill it up.
    It might be a little more or less than 10 but I'm on vacation, I don't care.
    FWIW, my trailer is heavier (5,500 lbs. wet and loaded) and wider (More frontal area) than yours, but for 34's and the level/lift, you not doing too badly.
    Good looking combo! Some camping friends of ours have the Winnie Minnie that they've been real happy with.
    TOYOTARIG likes this.
  8. Aug 17, 2023 at 8:40 AM
    SD Surfer
    Bruce
    So Cal
    I feel like wind resistance is the big MPG killer, probably more than weight.
    Once you hit about 40+ mph I can totally feel the parachute start to open.
  9. Aug 17, 2023 at 8:43 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    To clarify yes my trailer is also only 7.5ft wide which definitely helps mpg. Unless i have a strong headwind i see good mpg for towing.
    i used to have 35s, those took 4mpg off my highway just empty truck. are yoy towing in s4?
  10. Aug 17, 2023 at 8:48 AM
    joe_from_iowa
    joe_from_iowa New Member
    Iowa
    2021 Tundra Double Cab SX
    Peeled off the SX stickers from the bed sides. Tyger running boards. A.R.E. DCU topper
    9.8 mpg pulling a Jay Flight SLX8 212QB with my 2021 Double Cab.
  11. Aug 17, 2023 at 9:06 AM
    Chelly
    Chelly ...
    Mt Hood / PDX OR
    Another thing to consider, mileage will be a little understated with the larger tires if using the truck computer to calculate. Example for easy math, Stock 100 miles, 10 gallons = 10 MPG. On 34.5" tires 100 miles indicated * 1.078 = 107.8 miles / 10 gallons of fuel = 10.78 MPG. :) Tires being roughly 7.8% larger than stock.
    Blue Thunder and OHwendTrd like this.
  12. Aug 17, 2023 at 9:30 AM
    AZBoatHauler
    So.Arizona
    I only get 12 when I’m not towing. I’m on 34s with the extra weight of a bumper, winch, sliders and skids.
    8-9mpg freeway speeds and 9-10mpg at 55-60mph seems to be what people get when they’ve increased tire size and pull a travel trailer.
  13. Aug 17, 2023 at 9:59 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    This^ I was going to chime in about the same thing as being a factor.
  14. Aug 17, 2023 at 4:52 PM
    rockR67
    rockR67 New Member
    Northern Louisiana
    Yeah, good point. With things fairly flat and level especially, the drag kills you.
  15. Aug 17, 2023 at 5:11 PM
    centex
    centex New Member
    I get 7.6 towing 3500lbs at 65mph. Also on 34’s with front and rear bumpers. Can’t wait to get the 5.29’s installed and tuned next week.
    Hbjeff likes this.
  16. Aug 17, 2023 at 5:42 PM
    Blue Thunder
    Washington
    When I jumped to 33's I lost 1mpg just driving unloaded. We just sold our 1700BH Minnie Winnie that was about 4,200 loaded. I'd get 10.x if I kept it at 60mph and 9.x if I was going 65mph. I didn't look going over mountain passes...This past summer I've been towing when running premium and it seems to add a few 10ths to the MPGs and feels better. Doesn't pay for itself, but I like it. I got over 11mpg for the first time this summer with a long 60mph run and 10.x mpg keeping it at/under 65mph. These numbers are "mental" averages for 100-200 mile tows the past 3 years; not short runs or downhill coasts. I've also verified that my tires have made my speedo and mileage more accurate than it was with the factory rubber.
    We just upgraded to a trailer that's a foot wider, two feet taller and probably 2,500lbs heavier. My mileage dropped into the 8s!
    So I guess I'm saying your numbers are pretty close to mine. Gotta pay (fuel) to play (go)!
  17. Aug 17, 2023 at 5:52 PM
    bflooks
    bflooks New Member
    Metrowest MA
    It's all so environment dependent.
    I range anywhere between 6.3 and 8.7mpg towing 8000lbs with 275/70 Wildpeaks with 2.75" lift and 5.29s. Wind direction cost me nearly 1.5mpg on a 6 hour tow today.
    For reference, towing a 4000lb pop up, stock, I was getting 14mpg on the same trip. Less weight, lighter tires, totally different trailer profile
  18. Aug 18, 2023 at 7:08 AM
    JWWard03
    James
    Thanks everyone. Got right at 10 coming back from Florida to NC yesterday. Figured it wasn’t off what actual real numbers were for others but wanted to check. This Winnebago Hike is not aerodynamic at all.
  19. Aug 18, 2023 at 7:47 AM
    SD Surfer
    Bruce
    So Cal
    Yep, call it the price of admission.
    A luxury tax for pulling a little house behind us.
    It's painful at the pump, but when I'm laying in my queen bed with the AC cranking, watching a movie on the flat screen while eating ice cream in the desert, it's not so bad. :rolleyes:
  20. Aug 18, 2023 at 7:54 AM
    JWWard03
    James
    Very true.
  21. Aug 21, 2023 at 12:33 PM
    DirkS
    DirkS New Member
    Dirk
    Abbotsford, BC
    2016 Tundra Limited
    So, just got back from our first real trip towing with the Tundra. A mix of flat highway and ups and downs in the mountains here in BC, and got about 9.5 mpg. That’s towing this - 24’ long, about 6500lbs.
    All in all, while the pump stops are painful, it’s still worth it.
    2014 Black tundra likes this.
  22. Aug 21, 2023 at 1:13 PM
    Retired...finally
    My set up is around 5k on the trailer axles and my truck is right at gross. 65 is my preferred speed but I'll slow going up hills and make up the difference down the other side. Tire pressure is 40 ft, 43 rear. Never use cruise on hills. Wind resistance is the enemy more than weight.
  23. Aug 21, 2023 at 1:15 PM
    Digging the retro vibe on that.
  24. Aug 21, 2023 at 1:54 PM
    SD Surfer
    Bruce
    So Cal
    Well, you are traveling in style!!
    You have impeccable taste in trailers.
    Are you on LOA? *Edit* Just saw you in a thread on there, too funny!
  25. Aug 21, 2023 at 5:12 PM
    DirkS
    DirkS New Member
    Dirk
    Abbotsford, BC
    2016 Tundra Limited
    As do you!
    Too funny - it’s a small world sometimes. Looks like you went with the model we almost bought.
  26. Aug 21, 2023 at 5:48 PM
    SD Surfer
    Bruce
    So Cal
    The 1685 has served us well. Yours is a 2185?
  27. Aug 21, 2023 at 6:27 PM
    DirkS
    DirkS New Member
    Dirk
    Abbotsford, BC
    2016 Tundra Limited
    Yes, it is. We’ve been really happy with it - just wish we could spend more time away with it. The Tundra’s turned out to be a good tow vehicle, so…more trips planned!
    SD Surfer likes this.
  28. Aug 26, 2023 at 5:29 PM
    Rotorwash
    Rotorwash New Member
    Robert
    2018 Tundra Crewmax 4x4 MGM
    Talon Cat Shields
    Pulling my Coachmen Freedom Express at 6,350 pounds loaded on a 2,200 mile trip from Texas to Arizona I averaged 8.2 mpg for the entire trip.
    Kept it in S4 and my sweet spot was 62-65 mph.
  29. Aug 30, 2023 at 1:52 PM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    I tow a Forest River Flagstaff MicroLite 25BRDS. The trailer is about 6500 lbs loaded, 26' long, and 8' wide. She's lovely, but the front end is anything but aerodynamic.
    My biggest variables are of course wind and hills. With no side/head wind, and maybe a bit of a tail wind, I can get over 11 mpg on flat terrain. On my last trip over the mountain pass, despite the elevation, I hit 10 mpg and suspect I had a bit of a tail wind helping me out, or perhaps no wind at all. Was a nice drive. On the return trip, I was pulling 5 mpg heading up hill on the pass with a severe side wind. Was like riding a bucking bronco. Ugh. I think I averaged about 7.5 on that whole drive, helped out by getting to the other side of the pass and not having any wind.
    Y0TA PR0 likes this.
  30. Aug 30, 2023 at 2:07 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Natural Habitat for a Tundra.
    Around 9 US MPG between home and the mountains. About 5700 dry, likely 6500 lbs here, 29 feet long.
