Gas tank roll-over valve stuck causes hard fuelling - anyone else?
Discussion in '2.5 Gen Tundras (2014-2021)' started by baguafan, Mar 20, 2019.
  1. Mar 20, 2019 at 11:15 PM
    baguafan
    baguafan [OP] New Member
    2016 SR5 TRD
    I am not getting anywhere with Toyota about an issue with my Tundra, so I thought I would post about it, and hopefully get some opinions.
    I bought my 2016 SR5 TRD with 66,000kms (41K miles) a year ago, and its always been hard to fuel. I now have 75,000 kms ( 46.6K miles), Sometimes it's literally seconds between having the pump click and starting over and over again, extremely frustrating and it leads to lots of overflows.
    Due to the constant over-filling of fuel, the carbon canister failed and I replaced it, but the filling problem continued. It took several cycles, but I finally found that the roll-over value in the fill spout of the fuel tank itself gets stuck closed when the tank is fully filled, and then blocks the flow of fuel after that while fuelling. It took several months (and several tank fulls) to isolate the exact problem. I can manually open the value with a pick after removing the filler hose, and then it fills up fine.
    On this forum, I found this issue is not isolated, and found a thread where 6 separate Tundra owners (3rd Gen trucks) had filling issues that were diagnosed as a problem with filling due to the rollover valve being blocked. Out of those, it appears 4 had tanks replaced under warranty, and the remaining two did not provide an update as of yet. One owner was told they see at least 2 trucks a year with this issue.
    The issue is not just inconvenient and unsafe (given it often leads to fuel overflows), it impacts the emissions system on the truck.
    Oh, the roll-over valve cannot be purchased separately, it requires a new tank (the 38 gallon one), which is $$$$ - which is why I am pursuing Toyota.
    Ok, so I contacted Toyota service and their support lines several times, the conversations go like this:
    Conversation 1:
    ME ->
    Hi, I have an issue with my Tundra, it appears the tank on my truck has an issue and was defective, is there any warranty support?
    TOTOTA -> We totally support our customers, offer a substantial warranty, and are very sympathetic to your issue. You are beyond the warranty period, go away.
    Conversation 2:
    ME ->
    Hi, I have found a defect with my tank that is impacting my ability to fuel the truck, and it's been this way since I bought it. Given this also ruined the carbon canister which I replaced at my own cost, it's probably been overflowing since new, I cannot prove it but you can if you contact the previous customer. What support can I get from Toyota?
    TOYOTA -> We totally support our customers, offer a substantial warranty, and are very sympathetic to your issue. You are beyond the warranty period, go away.
    Conversation 3:
    ME ->
    Hi, we talked about my defective tank. I suggest this will impact my emissions system again. and I know there is a fair amount of discretion and good will available with warranty claims, and given the evidence that this issue is not isolated, can cause fuel overflows which are unsafe, and directly impacts the emissions system, I continue to ask to replace the fuel tank under warranty, in this case the emissions warranty. To do my part, I will absorb the cost of replacing the carbon canister.
    TOYOTA -> We totally support our customers, offer a substantial warranty, and are very sympathetic to your issue. However, you are beyond the warranty period, we will not offer any support. Go away.
    This is my first Toyota truck, and while I acknowledge that I am beyond the standard warranty, they are offering me zero support, I mean nothing. Maybe I was under the illusion they support their customers and care about their reputation, but I guess not.
    I have more steps planned to take it much higher in the organization, it's clear that the support people are just told to say no, and they do it well.
    I think this fuelling problem is a lot wider than I initially thought, and while searching through the net this issue keeps coming up, but it usually blamed on the carbon canister being plugged. I am suggesting that a defective roll-over value can both cause hard fuelling and eventually ruin the carbon canister.
    While Toyota will not own up the problem given the potential liabilities, you figure they would offer to help in some way, not just state the warranty is up.
    What do you guys think?
    Cheers
  2. Mar 21, 2019 at 7:14 AM
    Therin7
    Therin7 New Member
    West Tennessee
    2014 Tundra Platinum
    You are out of your warranty period, please go away.
  3. Mar 21, 2019 at 7:38 AM
    baguafan
    2016 SR5 TRD
    Exactly ... and I would agree that I am on the hook for most items on the truck, but now I need to pay for a new gas tank because Toyota screwed up on manufacturing the tank? It looks like it's a $1000 bill just for the parts before shipping. I have had other brands of trucks, and bought into the Tundra due to its reputation of quality, pretty disappointed so far.
    TTund16 likes this.
  4. Mar 23, 2019 at 9:02 PM
    Therin7
    Therin7 New Member
    West Tennessee
    My 2016 GMC was a PITA to fuel, constantly clicking, stopping, starting...you had to fiddle with it the entire time, everytime you got gas. Never bothered to figure out why, it was the least of that trucks many issues. Traded it and moved on. I am not a fan of these "sealed nonservicable" systems in new vehicles. 2015 Rav4 has a sealed transmission....componet fails (like TQ converter) entire $5k unit is replaced. Its becoming the norm across all manufactures unfortunately.
    Clemsonman14 likes this.
  5. Mar 24, 2019 at 12:14 AM
    1engineer
    1engineer New Member
    Appalachians
    2019 Tundra Limited TRD Off Road.
    Truth is most Tundras fill up with no drama. Good luck and I hope you fix it but when you buy used you get the good with the bad.
  6. Mar 24, 2019 at 3:21 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
  7. Mar 24, 2019 at 5:27 AM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    Feel entitled much?
  8. Mar 24, 2019 at 9:21 AM
    Therin7
    Therin7 New Member
    West Tennessee
    I would comb the forums for some kind of alternate/cheaper fix...maybe somebody has figured it out. Lot of smart yota folks on the forums.
  9. Mar 24, 2019 at 9:55 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Find out if the PO took it in for this issue during warranty. That’s probably your only chance. If not, I’m not really sure what you want. When the warranty ends... it ends. My wife’s car does this and I know how frustrating it is.
    GodlessPro, 2mchfun, GODZILLA and 2 others like this.
  10. Mar 24, 2019 at 10:07 AM
    Geezer
    Geezer New Member
    Heart of the Catskills
    2019 Tundra Limited
    If you feel that this is a safety issue then you should contact NHTSA - National Highway Traffic Safety Administration and discuss it with them. If they agree that there is a safety issue then they will work with you and Toyota and possibly have Toyota issue a TSB or even a recall. Your chances of this happening are slim, but I have seen it happen for a motorcycle wiring issue that was pursued this way. You have nothing to lose by trying.
    TTund16, 15whtrd and JohnLakeman like this.
  11. Mar 24, 2019 at 10:17 AM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Is this valve right inside the filler neck? If you can easily open it with a pick with no other problems this is what my cheap ass would do if it's out of warranty. Is this part defective from the factory or is this something that can happen at anytime?
    JohnLakeman likes this.
  12. Mar 24, 2019 at 10:32 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I think this isssue is so remote Toyota won’t even touch it. Things go wrong on vehicles. They are mechanical devices after all.
    If you think this diminishes Toyota’s “reliability” rep then trade that bad boy in and see how trouble free the big 3 will be.
    Not trying to be a jerk but what’s with people thinking Toyota should stand by every problem that arises when youre out of warranty? Do you think Ford would help you out when your turbo smokes after warranty? Even if they issued a TSB for this you’re still screwed as once the warranty is up they don’t honor TSBs.
    Good luck. I hope you are able to find a solution but I’m pretty sure it won’t be free from Toyota.
    Rider0120 likes this.
  13. Mar 24, 2019 at 11:42 AM
    Geezer
    Geezer New Member
    2019 Tundra Limited
    I agree with you that the chance of Toyota fixing this for free is slim, but I think you are wrong about TSBs. My wife's Highlander has been repaired for TSB issues for free long after the normal warranty had expired. The TSBs themselves each have an expiration, but that expiration is not the same as the normal warranty expiration.
  14. Mar 24, 2019 at 12:05 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Ok. I’ve been wrong many times before.
  15. Mar 24, 2019 at 12:08 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    1engineer likes this.
  16. Mar 24, 2019 at 8:47 PM
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    Holy mother of narratives.
  17. Mar 24, 2019 at 9:23 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    How many large corporations are going to fix a single, isoloted problem after the warranty has expired? What exactly are you expecting? Did you say anything to the dealer at which you bought the truck? Did you buy it with at least a 30 day warranty from whomever sold it or "as-is"? If this disappoints you, so will every other manufacturer...
  18. Mar 25, 2019 at 5:45 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Yeah, I'm thinking I would use a little tight-azz squarehead ingenuity to discover the perfect tool to do a "laparoscopic hemorrhoidectomy" on that sumbeach...Sawsall on a stick?. Government is supposed to HELP people...Ha!
  19. Dec 15, 2019 at 12:25 PM
    nuclearlemon
    nuclearlemon New Member
    wyoming
    2012 dc
    @baguafan
    is it only on the 38 gln tanks that it's an issue? i upgraded to a 38 gln last year and now i'm having fueling issues. no check light, no warning. just went to fill the other day and can't.
  20. Dec 28, 2019 at 1:38 PM
    cruisermansd
    cruisermansd New Member
    jeffrey
    2018 Tundra Limited CM
    ARE topper and a bed rug
    Nuclear, I am going through this right now. I am currently 1100 miles from home and sitting at Toyota right now. The service tech told me the filler tube is bent (not sure how that happens). First Toyota said that it’s not covered under warranty but I raised hell since I have 26k miles on the truck and Toyota is doing the right thing and replacing the entire tank. I went back to grab some stuff from the truck since the family is on Vaca and I talk to the guy working on the issue and he said that there is no way to bend the filler neck. And this is the 3rd tank he has replaced and it only seems to happen on the 38 gln tank.
    if your truck is still under warranty I would definitely have mr Toyota check it out.
  21. Dec 28, 2019 at 4:44 PM
    nuclearlemon
    wyoming
    2012 dc
    i can guarantee it's not a bend filler neck as my old 26 gallon tank works just fine. no warranty for me..my truck is a 2012 that i modified to add the 38 gallon tank :( sucks that yours happened on a trip, but glad they are taking care of it.
  22. Dec 29, 2019 at 1:29 PM
    cruisermansd
    jeffrey
    Yeah it was not a bent filler neck!
    it sure added to the adventure of the trip .
  23. Dec 29, 2019 at 5:10 PM
    newguy
    newguy New Member
    2016 CM TRD off road limited.
    TRD Dual Exhaut TRD Pro wheels BFG KO2 275/70/18 GoRhino RB20s Blacked out tail lights Bilstein 6112/5160 combo Coach builder +1 in the rear
    This same thing happened to me. I am a second owner and was 2 months out of warranty. I went to about 6 different gas stations and same thing. I could only trickle gas in.
    I took it to a dealership and low and behold, they had no problem filling the tank. Something must have been stuck, but knock on wood, this hasn’t happened since.
    I can’t really see by your receipt, but what did they end up replacing? Is that the whole tank?
  24. Dec 29, 2019 at 5:32 PM
    cruisermansd
    jeffrey
    Yes they replaced the whole thing, apparently the filler neck and tank are one sealed unit. Kinda crazy since the tank and all is $1400, all said and done with labor I would have been charged $2250 ;( thank god I was under warranty.
    NewImprovedRon likes this.
  25. Dec 29, 2019 at 5:36 PM
    SuperWhite20
    SuperWhite20 New Member
    Robert
    Georgetown TX
    2020 Tundra Crewmax SR5 4X4
    TRD Sway bar. Deck Rails, Maxliner rear floor mat, Driver side grab handle. Dee Zee bed mat
    Usually this is caused by the tube inside the filler neck. Yes, a vent tube inside the neck. I have replaced or repaired many fuel tanks. 99 percent of the time a hard fueling issue is the tube is kinked or collapsed or trash in it. I would pull the filler neck out and check it for a tube to allow the vapors to escape while fueling.
  26. Dec 29, 2019 at 5:45 PM
    nuclearlemon
    wyoming
    2012 dc
    the filler neck is not part of the tank. there's a hose connecting it to the tank. the fuel vent valve is part of the tank and that's what sticks on these tanks.
  27. Dec 29, 2019 at 5:49 PM
    cruisermansd
    jeffrey
    That makes sense, i did find it odd that Toyota said it was one sealed unit. I did ask if they could change just the fill neck and they said no.
  28. Dec 29, 2019 at 7:02 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Witch one is the fuel vent valve?
  29. Dec 29, 2019 at 7:06 PM
    WNY PAT
    WNY PAT New Member
    Western New York
    2017 Crewmax Limited (Mines) 2019 Crewmax SR5 (Work)
    Is the transfer flow 46 gallon tank less expensive than the 38 OEM? I think if this happened to mine, i might look in to that.
  30. Dec 30, 2019 at 5:31 AM
    nuclearlemon
    wyoming
    2012 dc
    they end up being about the same price by the time you figure adding the strap and crossmember for the oem
