Gator Tri-Fold Tonno Cover
Discussion in 'Tonneau Covers, Caps and Shells' started by doughboysigep, Jan 26, 2024.
  1. Jan 26, 2024 at 8:46 AM
    doughboysigep
    doughboysigep [OP] New Member
    Delhi, NY
    '20 SR5 CM 4x4
    My 2020 CM came with a Gator tonno cover. Fit doesn't seem quite right. At first it wasn't seated all the way forward. Now that I have that adjusted, closing the tailgate really pushes the back end up (water can easily get in). I have the front push forward to hit the under "lip", maybe that has to be up on bulkhead rail? Tailgate then pushes up on the rear under lip. I like the cover but wondering if it isn't the exact right one for the truck?? Springs seem a bit loose on the back too - can easily lift cover up. Any experience with these covers?
  2. Jan 26, 2024 at 8:46 AM
    doughboysigep
    Delhi, NY
    '20 SR5 CM 4x4
    front fit
  3. Jan 26, 2024 at 8:47 AM
    doughboysigep
    Delhi, NY
    '20 SR5 CM 4x4
    tailgate hitting under lip (rubber gasket)
  4. Jan 26, 2024 at 8:48 AM
    doughboysigep
    Delhi, NY
    '20 SR5 CM 4x4
    when closed
  5. Jan 26, 2024 at 8:58 AM
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    You should be able to adjust the clamp that lock it in. Make sure they are snug.
  6. Jan 26, 2024 at 9:06 AM
    doughboysigep
    Delhi, NY
    '20 SR5 CM 4x4
    not sure on that. it is not the lever clamp - it is the pull down spring handle. I couldn't see how there was any adjustment? spring just seem worn out??
  7. Jan 26, 2024 at 9:08 AM
    Sean492
    Sean492 New Member
    Winston Salem, NC
    2018 MGM Tundra Sport
    If I am understanding your correctly, you will need to move the under lip up onto the bulkhead rail so water can drain down between the bed and cab. This should pull the cover forward some and maybe create the clearance you need.
    Cliffy34 likes this.
  8. Jan 26, 2024 at 9:09 AM
    Damie Street
    Edsel
    South Carolina
    Can you take a pic of how it is connected to your truck? I'll go out and take a pic of the clamps I was talking about. I am a visual learner.
  9. Jan 26, 2024 at 9:13 AM
    doughboysigep
    Delhi, NY
    '20 SR5 CM 4x4
  10. Jan 26, 2024 at 9:15 AM
    doughboysigep
    Delhi, NY
    '20 SR5 CM 4x4
    I have seem videos with this style clamp as well but not on mine
  11. Jan 26, 2024 at 9:19 AM
    Damie Street
    Edsel
    South Carolina
    That is what mine look like. You must have a newer model. Maybe you can search youtube. Sorry I was unable to help.
  12. Jan 26, 2024 at 9:21 AM
    Cliffy34
    Cliffy34 New Member
    Pittsburgh
    2018 White Tundra SR5 Crewmax
    Second what @Sean492 said. The lip should be on the bulkhead rail.
