Gear indicator found
Discussion in '3rd Gen Tundras (2022+)' started by Shopcat, Sep 28, 2023.
  1. Sep 28, 2023 at 4:56 AM
    Shopcat
    Shopcat [OP] New Member
    2023 Mgm Platinum 4x4
    https://apps.apple.com/us/app/car-scanner-elm-obd2/id1259933623
    I have been searching for a way to see what gear my 2023 Platinum is in. I tried several apps and have emailed the folks at OBD Fusion. They have great communication and keep saying support for 2022-2023 is coming, but nothing has ever showed. I have been trying the lesser known apps for iPhone. Finally found one that works! It shows what gear the truck is in, torque converter lock status, and trans temp at different locations. The only thing I can’t find in it is an actual boost gauge, it has the actual manifold pressure. Best part is it’s a free app. $6.99 if you remove ads.
    The question is, why can the other apps seem to find these PIDs?
    9/29. Found a boost gauge. It is “Calculated Boost” sensor, but in the vehicle settings change boost type from “auto” to “MAF”
    t300, Taikowaza and Mattedfred like this.
  2. Sep 28, 2023 at 5:24 AM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    Yes curious how this works as well. Did you have to purchase an OB reader, and which one did you select in the app
  3. Sep 28, 2023 at 5:38 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    You also want an air temperature at intercooler, BTDC, all VVT hubs angles, TCV duty cycle, MAF, etc ;)
    TundraDan723 likes this.
  4. Sep 28, 2023 at 6:03 AM
    99ways2die
    99ways2die New Member
    Sorry, I couldn't help myself!
    The same app exists for Andoridz - will test.
    FI460, Tom976, Hank Hill and 2 others like this.
  5. Sep 28, 2023 at 7:53 AM
    Shopcat
    I have a Veepeak LE (low energy Bluetooth) OBD adapter. That way I use my phone as the gauge and still have CarPlay on the Dash screen. Hopefully Apple will allow OBD gauges on the CarPlay screen soon
    I tried the app with my Veepeak LE and a Wi-Fi version. Just selected which style of adapter I was using and it connects easily
    Danger to manifold!! Yep, you would think if you watch the actual pressure which seems to be Boost+Barometric pressure
    It is Much better than the other paid apps I tried for Trans info
  6. Sep 28, 2023 at 9:21 AM
    Shopcat
    Forgot to add
    Using the profile “Toyota 2016 - OBD II/ EOBD AT”
    ryanwgregg and Mattedfred like this.
  7. Oct 13, 2023 at 10:52 AM
    ToyFan
    ToyFan New Member
    Jay
    2018 Tundra
    Black Rhino Wheels
    Jay from Banks Power here. As you may have heard, we're trying to display transmission gear in the '22 Tundra on our iDash. We tried the app and cannot produce the same results even when selecting "Toyota 2016 - OBD II/ EOBD AT". Even though it shouldn't matter what OBD dongle is used, we've ordered the same Veepeak LE module that you're using. Can you share a photo of the Car Scanner app displaying gears 1-10?
    ryanwgregg likes this.
  8. Oct 13, 2023 at 11:27 AM
    poole34
    poole34 New Member
    2022 Tundra SR5 Double Cab TRD Offroad
    @ToyFan I posted this in the other thread but forgot to tag you. Let me know if I can do anything to assist.
    Here is a screenshot of the parameters I was monitoring with the App. The Gear AT did advance as the gears changed, I did not get above 6th gear as I was in town. I will try to run it again this evening and make sure it goes to 10.
    Kap1 and ryanwgregg like this.
  9. Oct 13, 2023 at 2:07 PM
    ToyFan
    ToyFan New Member
    Jay
    2018 Tundra
    Black Rhino Wheels
    I actually did see your screenshot. I had mistakenly assumed you were only able to see Gear 1. Yes, please let me know if you can see all 10 gears. We have the app and will have the OBD dongle on Monday. If we can reproduce the gear, we can sniff the CAN traffic and implement it into the iDash. I'd love to see the screen shot of 1-10. Thanks in advance!
  10. Oct 13, 2023 at 4:24 PM
    ToyFan
    ToyFan New Member
    Jay
    2018 Tundra
    Black Rhino Wheels
    Haha... Understood. I was actually referring to seeing any gears. If you can see the gears change from 1-9, etc, that's what we're interested in.
    ryanwgregg[QUOTED] likes this.
  11. Oct 13, 2023 at 4:32 PM
    Shopcat
    I am fishing out of town til Sunday
    As soon as I get home I will get a screenshot and any info you need.
  12. Oct 13, 2023 at 5:15 PM
    poole34
    poole34 New Member
    @ToyFan Here are the screenshots you requested. It does go to 10. I had to get up to 80 mph to get to 10 though.
    trazerr and ryanwgregg like this.
  13. Oct 14, 2023 at 2:13 PM
    DRP
    DRP Old Member
    Dave
    FYI..... I was able to see 1-9 today using the ELM OBD2 app. Couldn't get it to go into 10th as there was too much traffic to hold 80 for any length of time. I tried to force it into 10th using manual mode and although the dash display shows it's in 10th, I could not feel it actually shift into 10th. The ELM app never went to 10 even though the dash said it was in 10th.
    That brings up a question..... Why are there 10 speeds if it never goes into 10th gear ( I rarely get above 75mph)
  14. Oct 14, 2023 at 2:44 PM
    Tom976
    Tom976 New Member
    Tom
    I'm more concerned about the oil pressure number. 25-65 psi is normal. 29 at 2k RPM is a little on the lower side.
    Rcflyersd likes this.
  15. Oct 15, 2023 at 8:25 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    This can eaisly be reversed from Toyota Techstream software. I have done it many times for various parameters that are not pre programmed into the apps. If Techstream can ask for it and see it, then your app can if you teach it how.
  16. Oct 15, 2023 at 1:26 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Would you be willing to get me the PID info for transmission temperature? I’ve been searching high and low for the proper name and equation. Thanks in advance.
    PS - I tried the App mentioned in this thread this morning and though there are over a dozen Trans Temps listed all are blank for me (‘23 Tundra non-hy)
  17. Oct 15, 2023 at 3:54 PM
    DRP
    DRP Old Member
    Dave
    I used the Var.1 in this picture.
  18. Oct 15, 2023 at 5:31 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    I would have to have access to a 2022+ Tundra to connect too and log data from. Unfortunately I dont have an close friends or people in my area that own one I could borrow for a few hours one afternoon.
  19. Oct 16, 2023 at 5:21 PM
    Shopcat
    here are some images as I promised
    looks like There were several already posted
    BTW, the same Veepeak obd reader is working great with OBD Fusion and Carista. Just in case any of you were thinking of using those apps
    mayan and SC4333 like this.
  20. Nov 4, 2023 at 10:05 AM
    SC4333
    SC4333 New Member
    Grant
    2022 Tundra Limited TRD OR 4x4
    What Ryan said. I've watched the oil pressure closely since new, and with the engine at operating temperature (oil not coolant) of ~200*F, pressure at idle fluctuates between 8-12psi.
  21. Jan 2, 2024 at 2:44 PM
    Onetrack97
    Onetrack97 New Member
    2024 SR5
    I’m not seeing any data from the tires. Is this normal?
