Gear Oil without Limited Slip additives for TrueTrac, Helix, Torsen, Grip Pro differentials
Discussion in 'Performance and Tuning' started by dinosaur, Jan 17, 2022.
  1. Jan 17, 2022 at 5:57 AM
    dinosaur
    dinosaur [OP] New Member
    Dave
    2004 DC Tundra 4x4
    Greetings, I am installing a Torsen-style, helical gear limited slip differential and have been researching the right gear oil to use.
    The manufacturers almost universally say to use dino conventional oil with no limited slip modifiers. Eaton Detroit TrueTrac has more recently "allowed" the use of synthetics, but still say not to use LS formulas. This way their stuff can be compatible with automakers that require synthetic in their differentials for the benefit of the gears and bearings. The idea is that synthetic and/or LS formulas are more slippery and reduce the torque bias of the helical LSDs. Nobody wants that.
    Here is a list of what I came up with for gear oils without limited slip additives. It is not easy to find synthetic gear oil without the LS! I put the cheapest places that I found in the "Where to Buy", but it can be found in multiple places. Also, I put the cheapest size that I found (Qt., Gal, etc.). Lastly, there are many more conventional oils without LS than I listed, but my main goal was to get all the synthetics in one place.
    I am leaning toward using the Mobil Delvac 75W-90. I may decide to break in the new gears (which are going in at the same time as the Nitro Helix) on conventional, and then switch to Delvac and see if I can feel any loss of torque bias on the differential. Anyone have any opinions on that? What do you use?
    thearborbarber likes this.
  2. Jan 17, 2022 at 6:55 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    What does the manufacturer of your new differential specify for oil?
    dinosaur[OP] likes this.
  3. Jan 17, 2022 at 7:10 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Richmond "richgl5" or valvoline in the white quart bottles is what powertrax said they use.
  4. Jan 17, 2022 at 7:11 AM
    dinosaur
    Dave
    2004 DC Tundra 4x4
    Nitro does not specify anything, but it looks like a rebrand of the Powertrax Grip Pro. Powertrax contradicts itself in the installation instructions:
    "Use any gear oil without friction modifier", then later in the same document, "IMPORTANT LUBRICANT NOTE The Powertrax® Grip Pro™ limitedslip differential design uses helical cut gears to transfer power to the wheel with the most traction. Always use an 80W-90 mineral/petroleum based gear oil with at least a GL-5 rating. Synthetic oil and oils that contain friction modifiers are NOT recommended."
  5. Jan 17, 2022 at 7:27 AM
    dinosaur
    Dave
    2004 DC Tundra 4x4
    Thanks! I have the Valvoline in my list at the top. I just looked up the Richmond RichGL5 and it says it has friction modifiers, so I will pass on that one. Also, the Mobilube I listed is more of an industrial lube and the specs look better to me than the Valvoline. To top it all off, ECGS only recommends Lucas 85W-140 for any and all differentials, but it has LS modifiers in it.
    I am sure that I am overthinking this and it probably does not matter much, as long as you change the oil often enough. I will avoid LS additives though, so that rules out Lucas, Amsoil Severe Gear, and most of the synthetics.
  6. Jan 17, 2022 at 7:35 AM
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    Also, just out of curiosity, check out Dino motor oil Castrol GTX 10w40 and compare viscosities with 75w90 trans oil. No limited slip additives, good wear protection package. $20 for 5 quarts on Amazon.
  7. Jan 17, 2022 at 7:36 AM
    sd172
    sd172 New Member
    South Dakota
    If you are feeling very fancy, you can use motor Redline 0w40 for lower warm up times in winter.
  8. Jan 17, 2022 at 7:51 AM
    timsp8
    NY
    Auburn says the same thing but I’ve been using nitro synthetic gear oil with the additive for 1000s of miles and it’s still working fine. I can feel it lock up when it should. Sometimes I think it might be locking up too much. Maybe that’s why they say no synthetic. I’m not sure of any long term effects, but I did the same in my 2010 with the Auburn for over 50k miles and it still worked fine.
    Saltyhero13 likes this.
  9. Jan 17, 2022 at 7:58 AM
    dinosaur
    Dave
    2004 DC Tundra 4x4
    Oh man, you just opened up a can of worms :D They may have the same viscosity, but they are made for different purposes. The gear oils are made to resist shock load, water, tarnishing and a bunch of other stuff. The motor oil needs to resist being diluted or washed away by the gas. You are right that they both need to provide wear protection.
    sd172[QUOTED] likes this.
  10. Jan 17, 2022 at 8:00 AM
    dinosaur
    Dave
    2004 DC Tundra 4x4
    Thanks for sharing real world experience! Is the Auburn a cone style clutch LSD? They don't offer anything for my 1st Gen.
  11. Jan 17, 2022 at 8:12 AM
    sd172
    sd172 New Member
    South Dakota
    I am doing my next differential and transfer case oil changes with motor oil and will report if something blows up. I used to be on the ‘it should have the manufacturer approval’ team.
    dinosaur[QUOTED][OP] likes this.
  12. Jan 17, 2022 at 8:18 AM
    dinosaur
    Dave
    2004 DC Tundra 4x4
    Cool, you are a pioneer! No progress is made without people like you. But I don't think you should do this particular experiment, ha. I have been researching gear oils for almost a day, so I know what I'm talking about...
    hagrid and sd172[QUOTED] like this.
  13. Jan 17, 2022 at 8:20 AM
    sd172
    sd172 New Member
    South Dakota
    In the old days, a factory fill for the manual transmission was engine oil. I’m not pioneering anything here, just using good old pre-marketing era knowledge.
  14. Jan 17, 2022 at 8:27 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I've run amsoil synthetic in my powertrax it's whole life without complications. My figuring is worst case the thing doesn't lock up as well, and it's an oil change away to fix that, and in the mean time the gears and diff will be "better" lubricated. No issues in the past year/25k miles.
    TX210Tundra likes this.
  15. Jan 17, 2022 at 8:40 AM
    dinosaur
    Dave
    2004 DC Tundra 4x4
    Yeah, that makes total sense. All the gears should be well protected with that stuff. But I want it to lock up real good! I can't find any test -even seat of the pants test - of dino vs synthetic - with and without FM. That's why I think I may start with dino for the break in and then switch to non-FM synthetic. If I can't feel a difference, then try some of that Amsoil Severe Gear with the FM. It may not make much difference.
    Here's a study of gear oil that is pretty interesting.
    http://www.syntheticwarehouse.com/brochures/g2457_gearlube_study.pdf
  16. Jan 17, 2022 at 9:09 AM
    timsp8
    NY
    Yes it’s a cone style and I completely missed that you had a 1st Gen.
  17. Jan 17, 2022 at 9:14 AM
    dinosaur
    Dave
    2004 DC Tundra 4x4
    No worries. I would think that a friction modifier would be a requirement on those. Do they specify no synthetics?
  18. Jan 17, 2022 at 10:28 AM
    TX210Tundra
    TX210Tundra New Member
    2008 RCSB 5.7 2WD "Sport" / 2022 Limited Hybrid
    2008 - SOS 2/4 Lowering Kit : Firestone Bags : Bilstein Sports at 4 corners : TRD Pro Grill : TRD Pro 18in BBS Forged : Grip Pro LSD : Mike's "ByeNanny" : ARH LT 1 3/4 : ARH Cats : 3" X-Pipe: 3" Dual Borla XR1's / 3" Vibrant Resonators: 3" Tail pipes: DIY SABM: TRD Intake : AFE T/B Spacer : TRD Accelerator : LED Interior/Exterior : Atoto Pro HU : Cerwin Vega 10in Slim : AVS Visors : Sequoia Leather Seats : TRD shift Knob - OVTuned "Spicy 91 Torque Tune" 2022 Limited Crewmax Sonic Red Hybrid - TRD Filters : EGR Window Visors : Cheer Dring Android Adapter : RC Bed Cover : RC 1.75 Level Kit : Undercover Swing Case
    I also run Amsoil synthetic Severe Gear 75w90 with my Powertrax and it Performs flawlessly.
  19. Jan 17, 2022 at 10:48 AM
    timsp8
    NY
    Auburn says no synthetic oil like the others but to put in the additive. I used the synthetic that says it has additive and still put in a little additive to be safe.
  20. Jan 17, 2022 at 11:58 AM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (current)
    Check out redline NS (no slip additives) gear oil. It's meant for manual transaxles with hypoid gears.
  21. Jan 17, 2022 at 12:01 PM
    Retroboy1989
    Northern Utah
    Fwiw Torsen brand differentials don't care what fluid you feed them. Torsen simply specs whatever the ring gear specs.
    I have no insights on Eaton.
  22. Jan 17, 2022 at 7:33 PM
    dinosaur
    Dave
    2004 DC Tundra 4x4
    Yeah, I was checking that one out too. I have also had good luck with Liqui Moly in another car - it is quality stuff. A lot of good choices out now. I will report back if I learn anything interesting while testing dino vs synthetic. Thanks to all for the input. I feel better about using the Amsoil if I decide to go that route too.
  23. Jan 18, 2022 at 7:01 AM
    MadMaxCanon
    Lucas is another option that is very similar to the white valvoline stuff. Though i have heard but cant verify that the lucas is noisier in diffs.
  24. Feb 26, 2023 at 1:34 PM
    BabyBlackYota
    BabyBlackYota New Member
    Alex
    Longview TX
    2015 Black Tundra SR5 offroad
    AFE cold air intake, Outlaw Catback Dual Exhaust, ProRunner Fender Flares, DAPTISED 37x12.5x20’s, (soon to be 38x13.5x17) Zone 5 bracket lift kit /with pro comp spindles and outer tie rods grip pro lsd rear, Revolution 5.29 gears Deaver U748 springs Camburg shackles Fox 2.5 Coilovers 7” BDS Icon Billet adj/UCA’s
    So im running the revolution 5.29 gears with the Powertrax Grip Pro in the rear they put regular mastercraft 80w-90 in it from
    O'Reilys and im wanting to run something better I run the shit out of my truck offroad and on what should i put in front and rear or same in both?
  25. Feb 26, 2023 at 7:19 PM
    TX210Tundra
    AMS oil for sure. I run the synthetic severe duty and 2yrs layer still great
  26. Mar 2, 2023 at 10:11 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Motor oil doesn't have the shear strength to deal with the hypoid pinion and ring gear contact. The pinion is offset from the axle axis so the gear faces don't so much mesh in the traditional fashion, but are constantly sliding across one another. That's why they emphasize the difference with numbers like 75w90 vs 10w40 even though they're similar viscosities.
    Inside the torsen shouldn't care. Honda has run torsens in some manuals with basically a special 5w30 for trans fluid.
    Spez: incorrect term
  27. Mar 2, 2023 at 1:05 PM
    sd172
    sd172 New Member
    South Dakota
    If you think that some ‘magical’ fluid can save a poorly mechanically designed mechanism, you are welcome to continue to believe in it.
    From the formulation standpoint, there is nothing special in the transmission oil that clearly separates it from the motor oil. The marketing and markups are different though.
  28. Mar 2, 2023 at 1:21 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Not the transmission/tc. I ran 10w-40 in the 5 speed tacoma for years. I'm talking about the ring and pinion in the diff. Iirc a GL5 fluid has a lot of a zinc-based additive that bonds to the steel so it can act as a sacrificial layer to handle the sliding under pressure far more than just a liquid can do.
  29. Mar 2, 2023 at 3:01 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Hypoid not helical. You'd think I could keep those terms straight. Anyway a good read. Please don't put motor oil in the rear end. Bad things happen.
    https://www.engineeringchoice.com/what-is-hypoid-gearbox/
    I made the mistake once of putting GL5 in a manual gearbox that needed 75w-90 GL4 and I can verify 100% its not snake oil. That oil is so gosh darn slippery the truck absolutely required double clutching every shift from the very first drive down the road. Those syncros gave basically zero friction. Couldn't get it out fast enough. But you need that owl snot for the diff ring and pinion to survive.
    The additives mentioned like for limited slip clutch packs make it even more resilient to losing the fluid layer under pressure to keep the clutches from chattering in a turn. The less you go into that territory the better for the torsen to work right.
  30. Jun 9, 2023 at 3:59 PM
    Retroboy1989
    Northern Utah
    I've also had manual transmissions that called for GL4 and warned against GL5 for both slipperiness and for harm to brass synchros.
    Redline MT90 is a GL4 that works excellent in Toyota pickup manual transmissions.
