Gear Ratio
Discussion in '2nd Gen Tundras (2007-2013)' started by fishon4x6, May 24, 2020.
  1. May 24, 2020 at 8:31 AM
    fishon4x6
    fishon4x6 [OP] New Member
    5.7 what is best for hwy driving 18" stock,4x4
  2. May 24, 2020 at 8:58 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Something above 488s, but only with a supercharger
    Getmeacoors likes this.
  3. May 24, 2020 at 9:14 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    stock for mpg
    Stock 4.30 gears in 5th is 0.6% more rpm than 5.29s in 6th gear with the same tires, so 5.29 spin about 2400 rpm @ 70mph on factory tires, still spinning slower than a 2nd gen Tacoma 4.0L V6 6MT
  4. May 24, 2020 at 9:18 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    If you're thinking of buying a Tundra, then you do not get to choose axle ratio with Toyota trucks.
    With Toyota, you get the axle ratio that Toyota considers the best overall choice for a working truck (tow/haul) that can be used as a daily driver. For a 5.7L Tundra, Toyota's choice is 4.1:1 unless you have the tow package, then it's 4.3:1. You can forget 3.08:1 rear axle ratio in Toyotas.
  5. May 24, 2020 at 9:19 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    The 6 spd transmission behind the 5.7 is so tall that even with the 4.30 rear end it's effectively taller than a Ford 3.73 6 speed. Going to 3.73 would be like a 3.08 Ford, which is why no one makes that set
  6. May 24, 2020 at 9:21 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    I forget sometimes people don't know this, now the OP makes more sense haha
    Get the tow pkg for the bigger rear gear 4.30. The new trucks don't even offer the 4.10 anymore
    JohnLakeman[QUOTED] likes this.
  7. May 24, 2020 at 11:05 AM
    fishon4x6
    Thank you everyone !!!its a 08 with the 4.30 tryin to think of ways to get better mpg is all
  8. May 24, 2020 at 12:01 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Lose all nonessential weight, and drive slower than 65 with a light right foot.
    Matala likes this.
  9. May 24, 2020 at 1:56 PM
    frichco228
    MPG and Tundra are contradictory. But, stock size highway tread tires (standard load- NOT E load) and keeping speeds @65 will offer the best MPG. You could see 19MPG on the highway.
