Gen 2.5 2021 6.5ft bed camper topper options?
Discussion in 'Tonneau Covers, Caps and Shells' started by Fishruss, Aug 30, 2024.
  1. Aug 30, 2024 at 4:37 AM
    Fishruss
    Fishruss [OP] New Member
    Russell
    2021 tundra 5.7 limited 6.5ft
    Hi gang i just bought a 2021 tundra limited 4 door 6.5ft bed. Im trying to find a camper topper. I live in Miami Florida. As i read many companies don't make compatible toppers for this truck?: how much does a higher top then cab high change mpg? I bought a white truck because it's hotter then hell here 364 days a year. I imagine the black stainless steel or aluminum tops are not a option? What fits my truck and would be best temperature inside option? I want to be able to sleep in bed overnight or nap between crazy hours i work in busy season 20 plus hrs day sometimes so i might be trying to sleep in middle of the day in high temperatures. I have a icy breeze cooler i use camping in the boat i waa thing would help with some fans. Thanks for your help and guidance from a toyota newbie.
    Wallygator likes this.
  2. Aug 30, 2024 at 8:15 AM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    Where did you read that? Most major cap manufacturers make one for that truck. I've had Leer, Century, ARE, and Jason toppers over the years on various trucks. My opinion is that all the major fiberglass manufacturers are essentially the same quality wise and you're best served by finding a reputable dealer/installer that can install correctly and willing to help you through quality control and warranty issues. I personally find the quality of fiberglass toppers to be lacking given the prices they charge. You can get better quality with a high end manufacturer (Go fast campers, Spacekap, Smartcap, etc.) but you certainly pay for it.
    I have a Century High-C (rebranded Leer 180) and basically the same truck as you. It's ~4" higher than the cab and definitely nice for moving around in, I don't think it affects the fuel economy much. My Fuelly app shows me averaging 16.5 mpg over the last 24k miles on an otherwise stock truck, 80% of that driving is interstate at 70-75 MPH. Minimal in-town running around, some long trips at 85 MPH where I usually get ~14 MPG or less depending on the head wind. It generates a little more wind noise at 75+ MPH so it's adding a little drag.
    If it's hotter than hell outside, it's hotter than hell inside the topper. I slept in it in the summer in Big Bend National Park and it sucked even though I was somewhat used to the heat from working in the oil fields. You're probably gonna want some sort of fancy portable air conditioner or cooler to make it bearable to sleep in in the heat. I've never tried this personally, but it's not a huge space to cool and I think you could make it work with the right equipment.
    @Wallygator has a well documented build with a commercial aluminum topper, it seems like a good option if you want to insulate it which would certainly help your hot camping situation but only if you had a way to cool the inside.
    bpilati and Wallygator like this.
  3. Aug 30, 2024 at 9:50 AM
    Fishruss
    Russell
    Thanks for your reply it's good information. I read on other posts on here that it was hard to get options for tops.
  4. Aug 30, 2024 at 1:45 PM
    Wallygator
    My mileage didn’t change much either. I love the setup I have now. In my opinion it’s the best way to travel and camp.
    You should be able to find plenty of options for tops. As @Tbrandt says, spend some time finding a good dealer. My dealer sucked and eventually I just stopped going back to them about issues and fixed them myself. Having a good dealer that cares about its customers will make a huge difference.
    Camping in the heat in the top is really no different than camping in a tent in the heat. However the insulation I put in made a big difference. I have a battery system, and the ability to have shore power if it’s available, so I usually have a fan going in the heat. In the winter I like to use shore power with an electric space heater but I do have a Chinese diesel heater if needed.
    Ok good luck with your search and please post what you decide to get. Then please make a build thread!:thumbsup:
    Tbrandt likes this.
  5. Aug 30, 2024 at 1:59 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Build a platform over the rear bench (you have a DC, right) and sleep there with the engine/AC running. I have a wooden tote in bed under Leer cap, I prefer the one in cabin in hot days. Passenger seat goes all the way to front and 5'10" of me can lay diagonally with legs stretched.
  6. Aug 30, 2024 at 2:46 PM
    Fishruss
    Russell
    The back seat is what i have done for years. I like the idea of the bed vs cab for more room.
  7. Aug 30, 2024 at 3:19 PM
    Blast Chamber
    Blast Chamber New Member
    WI
    2020 DC Limited - Cement
    I recently went with a Ranch brand top for my Tundra and I'm very pleased by the build quality. It came with a sliding/fold-down front window and a carpeted headliner. I could have spent more money on other brands but didn't see the point in doing so.
  8. Oct 6, 2024 at 6:27 AM
    anthony1958
    anthony1958 New Member
    anthony
    2017 tundra 4.6
    hello sir i have a 2017 crew with 6.5 bed.what size or model number is that cap.i like it a lot
  9. Oct 6, 2024 at 11:19 AM
    Blast Chamber
    WI
    If you are referring to my pictures, it is a Ranch Sierra Xtra cab-high model. I like it and it has a lot of nice features for the price. I recommend getting the optional tip-down front window to make it easier to clean the rear window of the truck cab.
    https://ranchfiberglass.com/truck-caps-and-tonneau-covers/sierra-xtra-truck-cap/
  10. Oct 8, 2024 at 9:32 AM
    anthony1958
    anthony
    2017 tundra 4.6
    good advice on rear window. thanks
  11. Dec 8, 2024 at 5:36 AM
    T-bone Tundra 63
    T-bone Tundra 63 New Member
    2019 Tundra limited
    Backflip tri-fold bed cover Go rhino running boards
    Looks great .What is the general price range on those?
  12. Dec 17, 2024 at 6:18 AM
    bpilati
    bpilati New Member
    2020 Magnetic Gray Metallic DC 4x4 SR5 TRD
    Nice boxes. You built a living room. ;) I see you bought the lined cap.
  13. Dec 17, 2024 at 6:20 AM
    bpilati
    bpilati New Member
    You can actually buy mattresses that fit around the wheel wells.
