Gen 2 head unit
Discussion in 'Audio & Video' started by Vince, May 31, 2019.
  1. May 31, 2019 at 6:01 AM
    Vince
    Vince [OP] New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    Well today was the first day my factory head unit acted up.
    Had sound but no screen lights,
    Anyone have any luck with keeping all my options with a after market head unit, maybe gain a back up camera. Thank you for the help.
  2. May 31, 2019 at 6:23 AM
    Dr_Al
    Dr_Al New Member
    Al
    Two months ago I just replaced mine to get hands free, GPS and a rear view camera. If you don't want to spend the money you should be able to find a replacement factory head unit for cheap. I think I threw mine out already.
  3. May 31, 2019 at 6:26 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Vince[OP] likes this.
  4. May 31, 2019 at 6:30 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Thinking there are harnesses for most HUs to keep all functions.
    Crutchfield.com is a great resource for these types of needs. Most install shops have or know what is needed as well.
    TheBeast, Vince[OP] and Black Wolf like this.
  5. May 31, 2019 at 7:21 AM
    Vince
    Vincent
    What did you replace it with ?
  6. May 31, 2019 at 7:52 AM
    Trooper2
    JR
    Probably can't go wrong with Pioneer, Sony, Kenwood, or Alpine. Find one that fits your needs and budget.
    I have a Pioneer and it works well.
    The Masters Tailgate latch with camera on Amazon works great too.
    Both in pics in my build below.
  7. May 31, 2019 at 9:01 AM
    minter66
    minter66 2007 TSS CrewMax
    Boom:
    Added backup cam
    Added front cam
    Apple CarPlay
    Android OS
    Works with Factory JBL audio (don't see JBL on your old H/U - so not an issue)
    Only issue I had was I had to splice 12V into ACC wire as the FCAM was still staying powered up when the truck was off.
  8. Jun 1, 2019 at 4:04 PM
    SCtundra215
    SCtundra215 New Member
    Jmart
    Sc 2nd gen Trd
    Supercharged 5.7L Trd big brakes Trd sway bars Trd exhaust Amp power steps Decked bed box 3.5” lift 35” kumho m/t 20” -44 rockstar blk/machine 811 wheels
    Is that the Belsee 10.1 tilting style unit? If so how is it so far? I have a Tesla 13.1” and it would work great if I didn’t have the TRD SC flash which causes the HEadunit to turn off my ABS module for some reason, so Iv been eyeing that unit
  9. Jun 1, 2019 at 4:56 PM
    minter66
    Dasaita Android 10.2”
    The unit itself is great, like I mentioned above on my second gen (you might have this issue) it wouldn’t kill power to my front cam when the truck was off. I ended up cutting the 12V constant and wiring into the ACC wire.
    But it’s fast and looks great. Even has an Apple CarPlay adapter. Really made the stock JBL audio come alive
  10. Jun 1, 2019 at 6:19 PM
    SCtundra215
    Jmart
    Sc 2nd gen Trd
    Really glad someone did this HU cause Iv been considering it since I experienced the issue. So does the tilt make it easy to shade from the sun or direct at the driver side or passenger side?
    Texas Bandit likes this.
  11. Jun 1, 2019 at 6:52 PM
    Tundra_power
    Tundra_power New Member
    Nick
    Hey i was wondering about your Tesla unit. How long is it? Im trying to put the 13.6 unit in my 2008 tundra but i have the bench seat with the column shifter
  12. Jun 1, 2019 at 6:53 PM
    Tundra_power
    Nick
    And how did you hook up the a/c was everything plug and play?
  13. Jun 1, 2019 at 7:26 PM
    kgb4187
    kgb4187 New Member
  14. Jun 1, 2019 at 7:37 PM
    SCtundra215
    Jmart
    Sc 2nd gen Trd
    The screen is I believe the largest available 13.1”, is don’t believe they’re would be any issue with the column shifter. The chrome fan speed remains the same and is attached to the headunit, the AC button In the center, the climate control is all touchscreen and if u touch the section at the bottom of my screen the larger climate screen appears. The Ac controls are plug n play. My heated seat dials were moved to under the HU where they include a 12v and 4 rocker openings. On newer tindras the heated/ac seats can be digitalized
  15. Jun 1, 2019 at 7:40 PM
    Tundra_power
    Nick
  16. Jun 1, 2019 at 7:43 PM
    Tundra_power
    Nick
    You see the base where the head unit of yours go to the center council. But with mine it might go all the way down where the base of my dash. If you can measure the length of the Tesla head unit just to make sure it would fit with my setup thanks..
  17. Jun 1, 2019 at 7:44 PM
    Tundra_power
    Nick
  18. Jun 1, 2019 at 7:49 PM
    SCtundra215
    Jmart
    Sc 2nd gen Trd
    Any chance you could do a video demo? Just with backup cam/general stuff?
  19. Jun 1, 2019 at 9:56 PM
    SCtundra215
    Jmart
    Sc 2nd gen Trd
    Yea I’ll measure it tmw for u
  20. Jun 1, 2019 at 10:00 PM
    Tundra_power
    Nick
    Ok thanks i appreciate it..
  21. Jun 2, 2019 at 3:32 AM
    Trpl7
    Trpl7 My best friend Tate
    Rob
    Washington
    Super White 07
    Partial level kit, Total chaos UCA, coach builder shackles, magnaflow ex. Tuner, SABM, complete poly bushing suspension.
    I have a stock HU sitting on my shelf if you just want to reinstall theodicies al. Just PM me and I can ship it to you
  22. Jun 2, 2019 at 4:25 AM
    Dr_Al
    Dr_Al New Member
    Al
    I got a Kenwood 874S. I wanted something with the GPS built in as there's lots of spots around here without data. I could see myself running into a dead spot wanting to find a address. Plus being last year's model it was cheaper.
  23. Jun 3, 2019 at 11:54 AM
    SCtundra215
    Jmart
    Sc 2nd gen Trd
    CaptSpaulding likes this.
  24. Jun 3, 2019 at 12:05 PM
    Tundra_power
    Nick
    Oh man your the best... Just wondering how long is it after 13in where it cuts in maybe 4in?
  25. Jun 3, 2019 at 1:51 PM
    SCtundra215
    Jmart
    Sc 2nd gen Trd
    18” on the dime, I see no reason ur setup wouldn’t work.
    Tundra_power likes this.
  26. Jun 3, 2019 at 2:13 PM
    Tundra_power
    Nick
    Ok cool thanks i appreciate it alot...
  27. Jun 3, 2019 at 2:25 PM
    Vince
    Vincent
    Does that get modified to go in.
    It is awesome looking
  28. Jun 3, 2019 at 2:27 PM
    Tundra_power
    Nick
    Nope its a direct fit for your setup.
  29. Jun 3, 2019 at 2:28 PM
    Vince
    Vincent
    Do you have a link where you purchased from
  30. Jun 3, 2019 at 2:29 PM
    Tundra_power
    Nick
