General Grabber non LT!?
Discussion in 'Wheels & Tires' started by H22dx, Feb 17, 2022.
  1. Feb 17, 2022 at 4:35 PM
    H22dx
    H22dx [OP] New Member
    Trevor
    '18 Limited TRD Off Road
  2. Feb 17, 2022 at 4:42 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Whether you go LT or not is up to you. That’s all I run. You’ll save weight and have a smoother ride if you don’t put LT tires on.
    I’ve used the AT/X. It’s a good tire. Does well in snow and on ice and isn’t very loud.
    H22dx[OP] likes this.
  3. Feb 17, 2022 at 5:12 PM
    Redcon41318
    Redcon41318 New Member
    Do not go LT, e rated it will ruin or negative affect your ride and performance.
  4. Feb 17, 2022 at 5:23 PM
    Cdub1962
    Cdub1962 New Member
    You will enjoy ride more without LT. I've had the Grabber AT/X and could not keep them balanced. Other than that they were good tire in dry, rain, and snow. I replaced them with set of Toyo Open Country AT3's; best tire I've owned. Smooth and quiet ride, great in rain and beast in snow.
  5. Feb 17, 2022 at 5:41 PM
    NjPro
    NjPro New Member
    Tom
    Nj
    2017 Trd Pro Tundra cement
    Magnuson supercharger, Sprint booster, CB TRD PRO kit, 295/70/10 terra grapple G2, Black TRD shift knob, Rhino shackle hitch, Lund Tri-fold bed cover, 1.25 Spidertrax wheel spacers. TRD rear sway bar. Bud Built cross member. Arb Diff breather. Grab handle installed. 2012 DC SR5 TRD Supercharged, Gone but not forgotten.
    I run 295/70/18 terra grabbers g2 non Lt
    Coming from a 285/70/18 Lt tire, there is no comparison between ride quality. I rarely tow and if I do it is under 5k. I have had no issues with off-roading either. Off-roading for me is dirt and mud, not rocks and boulders.
    For how I use my truck, it’s a no brainer to run lighter tires. Good luck man.
    Tundra_361 and H22dx[OP] like this.
  6. Feb 17, 2022 at 6:18 PM
    H22dx
    Trevor
    That’s good to hear for sure. Thanks man!
  7. Feb 17, 2022 at 7:29 PM
    Redcon41318
    Just because you tow with your tundra does not justify E rated tires. Our tundras
    With factory SL tires are rated to tow within the capacities of factory tires. I had E rated tires and it was a poor decision since i was coming from 2500 suburbans and Silverados.
    e rated tires do not
    Enhance the towing capabilities or raise more towing weight.
    Chucho and frichco228 like this.
