General Spring of Kansas City
Discussion in 'Suspension' started by dgtulsaguy, Dec 9, 2021.
  1. Dec 9, 2021 at 8:54 AM
    dgtulsaguy
    dgtulsaguy [OP] New Member
    18' 1794
  2. Dec 9, 2021 at 9:05 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
  3. Dec 9, 2021 at 2:07 PM
    dgtulsaguy
    18' 1794
    I ordered the pair, $630 shipped to the shop. I plan on putting them on myself, will report back with opinions and pics.
    worktruckwhite likes this.
  4. Dec 9, 2021 at 2:13 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I feel like the Gen 1 guys have brought those up as good replacements.
  5. Dec 9, 2021 at 3:11 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Since they are not driver/passenger side specific, you will likely be lower on the driver side with the gas tank, battery, and you, sitting on one side of the truck.
  6. Dec 9, 2021 at 3:15 PM
    dgtulsaguy
    18' 1794
    Good looking out. So far, I've tried to offset that by keeping all my recovery gear on the passenger side decked drawer. I'm still almost 1/2 an inch lower on the driver rear.
  7. Dec 13, 2021 at 3:42 PM
    dgtulsaguy
    18' 1794
    Leaf’s arrived less than 48 hours after ordering, can’t complain! Can confirm they are identical on each side. Should get to the install in a day or two and will post before and after numbers… they look BEEFY
    alb1k likes this.
  8. Dec 13, 2021 at 3:45 PM
    alb1k
    Left Coast
    It's good
    Looks great. Military wrap to the front.
  9. Dec 13, 2021 at 3:50 PM
    MadMaxCanon
    Are these supposed to add lift or are they stock height?
  10. Dec 13, 2021 at 4:58 PM
    dgtulsaguy
    18' 1794
    They are supposed to add about an inch
  11. Jan 4, 2022 at 8:45 AM
    dgtulsaguy
    18' 1794
    Got them in a week ago. Added around an inch with a much stiffer ride over the collapsed stock leaf . Happy with it overall, I'll will post an update in a few months.
  12. Jan 4, 2022 at 8:56 AM
    Kung
    KG, VA
    Given I'm maybe 3 hours from KCMO...I find this highly interesting. :)
    dgtulsaguy[OP] likes this.
  13. Jan 4, 2022 at 9:15 AM
    2mchfun
    It really is sort of pointless to be concerned about it too much, afterall, all corners flex and bounce while in motion anyway. Glad you found something better than the stock garbage!
  14. Jan 4, 2022 at 9:57 AM
    MadMaxCanon
    Looks like a solid alternative to stock springs. I am looking to upgrade them in a few years when they wear a bit, they are pretty weak compared to other trucks Ive had, I dont see them lasting that long. What shocks do you have these paired with?
  15. Jan 4, 2022 at 10:46 AM
    dgtulsaguy
    18' 1794
    King 2.5 remote resi's and shdq's 3/4 inch lift shackles on the rear
  16. Jan 4, 2022 at 10:49 AM
    MadMaxCanon
    Thanks, so with the shackles you are right around 2" of total lift?
  17. Jan 4, 2022 at 4:32 PM
    dgtulsaguy
    18' 1794
    With everything together it was closer to 3 inches
  18. Jan 4, 2022 at 6:00 PM
    MadMaxCanon
    3 inches because your stocks were sagging right? Otherwise it seems like double what it should be
  19. Jan 4, 2022 at 6:18 PM
    dgtulsaguy
    18' 1794
    I would guess so.
