Glass Break Sensor
Discussion in '2.5 Gen Tundras (2014-2021)' started by Avi8or, Aug 24, 2022.
  1. Aug 24, 2022 at 3:07 PM
    Avi8or
    Avi8or [OP] New Member
    Johann
    MO
    2020 Limited Crewmax
    FYI
    just installed the glass break sensor in my 2020. It was plug and play on my truck. Techstream activation was not needed.
    Your truck will need the factory alarm installed for this to be plug and play.
    I’m not sure at what year this started because it seems Techstream was needed in the past on earlier model years.
    I have attached the instructions my dealer gave me that appear to be for 2018+ but not for sure on that.
    batman900 and bulldog93 like this.
  2. Aug 24, 2022 at 4:34 PM
    bmw345
    bmw345 New Member
    CT
    2018 Platinum Pro, Pro Fox's TRD Skid
    I have this GBS in my 2018 Platinum but have no alarm that I know of.
  3. Aug 24, 2022 at 4:45 PM
    If it came with GBS then you have an alarm.
  4. Aug 24, 2022 at 6:33 PM
    bmw345
    bmw345 New Member
    CT
    I have a standard fob, how do I activate this alarm?
  5. Aug 24, 2022 at 7:26 PM
    Avi8or
    Johann
    MO
    An additional fob is not needed. When you lock the doors, the system activates.
    Mine had standard door and hood triggers.
  6. Aug 24, 2022 at 7:43 PM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    I added this sensor to my 2011. I didn’t need Techstream activation either.
    I think if you have the alarm already active then it’s just as simple as plugging in the sensor module and microphone!
    Avi8or[OP] likes this.
  7. Aug 24, 2022 at 8:52 PM
    bmw345
    bmw345 New Member
    CT
    Anyway to test it without breaking anything?
  8. Aug 24, 2022 at 8:58 PM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Get an app for your smartphone that will make the sound of breaking glass.
  9. Aug 24, 2022 at 9:02 PM
    bmw345
    bmw345 New Member
    CT
    Lol, I will try that!
  10. Aug 25, 2022 at 4:27 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Not sure that will work. It is likely a pressure sensor as much as a sound sensor.
  11. Aug 25, 2022 at 4:29 AM
    Musicmasterd12
    Southern Louisiana
    To test it, I tapped on my driver window with my key and set it off
  12. Aug 25, 2022 at 4:45 AM
    Avi8or
    Johann
    MO
    Same. You can also sit inside and clap.
