GM diode/X2 power battery
Discussion in '2.5 Gen Tundras (2014-2021)' started by JG1982, Apr 5, 2023.
  1. Apr 5, 2023 at 4:58 PM
    JG1982
    JG1982 [OP] New Member
    Jeff
    2015 SR5 5.7flex fuel Tundra
    I have a X2 power AGM battery and just installed the GM diode. Before I did I had my alternator tested at Auto Zone and it said the voltage regulator failed, however after putting in the diode and testing again it was good. What’s everyone’s thoughts on this?
  2. Apr 5, 2023 at 6:18 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    There are several ways a voltage regulator can fail, so it will be hard to say without knowing how it specifically failed to begin with and what was the actual result of the diagnosis.
    Also did it fail before your X2 install or was that diagnosed after the install?
    It could be as simple as a grounding issue from corrosion that was fixed when you put in a new battery.
    My understanding is the diode tricks the ECU into thinking the voltage is lower than it really is. If it wasn't a ground issue, my guess would be the alternator failed low as in it produced a voltage too low out of spec.
    I don't work on automotive systems so it is possible there is some other blue smoke magic going on.
  3. Apr 5, 2023 at 6:24 PM
    JG1982
    Jeff
    No it failed after I put the AGM battery in. But during the test the machine said turn on headlights and then it was holding around 13.6V but then said failed regulator but diodes good. I was just thinking maybe because the X2 requires higher voltage to properly charge it was giving a false negative on the test.
  4. Apr 5, 2023 at 6:33 PM
    Saltyhero13
    This helps to clarify the situation.
    It is possible the AGM's lower internal resistance could have something to do with it.
    A quick read says it is a common issue and can "fix" itself based on hot/cold weather.
    Curious to see what more knowledgeable people say about this.
  5. Apr 5, 2023 at 6:38 PM
    JG1982
    Jeff
    Interesting, I haven’t read the hot/cold thing. I’ll have to research more. Some people say I should just get a high output alternator, but doesn’t the computer in a Tundra limit the output anyways which is why I put the diode.
  6. Apr 5, 2023 at 6:41 PM
    Saltyhero13
    Hot/Cold may be a one off dealing with loose solder/connector.
    Yes my understanding is the ECU controls the output. The diode causes the ECU to see a lower voltage which then signals to increase the voltage keeping the AGM happy.
    HulkSmurf14 likes this.
  7. Apr 5, 2023 at 6:48 PM
    Saltyhero13
  8. Apr 5, 2023 at 6:50 PM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    I'm not understanding this diode thing.
    A diode is essentially a check valve for current, only allowing it to flow in one direction.
    If the AGM battery requires a higher charging current/charge rate, what would a diode do?
    Can someone explain?
    seahaul likes this.
  9. Apr 5, 2023 at 6:55 PM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    Explanation of a forum member:https://www.tundras.com/threads/charging-diode-for-agm-batteries.111426/#post-2876510
    The diode lowers the battery voltage signal sent to the alternator voltage regulator, this raises the output of the alternator same amount.
    I installed an Odyssey AGM battery a few months ago and didnt bother with replacing the alternator fuse with a diode. Plugged in a voltage meter and it was reading 13.5-13.7volts on idle.
    Got curious about the diode and installed one. After installing a diode, voltage reading jumped to 14.3-14.7volts on idle.
  10. Apr 6, 2023 at 10:57 AM
    Sunfish
    Sunfish New Member
    17 4X4 CM Limited
    I don't even have a AGM and run a GM diode. It stays just above 14 and never needs water. 27F Interstate does the job.
  11. Apr 6, 2023 at 11:48 AM
    TheBeast The Beach
    I run the X2 AGM with no diode for the past 3 years. No issues to report.
  12. Apr 6, 2023 at 12:20 PM
    Saltyhero13
    I've seen quite a few people report this. Makes me wonder why it works out for some to run with no diode and no trickle charger where others have the battery shit the bed. I would be curious to know.
  13. Apr 7, 2023 at 12:20 AM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    May be the difference between daily driver duty and occasional use vehicles. If you start and run your vehicle every day and the battery gets a good charge, even if its lower than what it can handle, it will last a good long while. If its a weekend only type vehicle, and you run the batteries down while camping or whatever, and you're not getting a full recharge, then it may shorten the life of the battery. This is just a theory obviously.
  14. Apr 7, 2023 at 5:35 AM
    I ran the X2 in my Jeep for a while with poor performance. The alternator was upgraded to a 160a but it never seemed to get a good charge. It ended up needing to be replaced within a year. Now I run Walmart ever start brand and have no issues.
    Interesting....
    WVI and Saltyhero13 like this.
  15. Dec 14, 2023 at 12:37 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    I've been running an Optima AGM battery since 5/2022 (about a year and a half). No diode, no worries. It starts briskly every morning with no issues in 1 1/2 years.
    If AGM batteries require baby sitting with diodes and trickle charging what is the advantage of even considering them? I've used AGM batteries on several motorcycles (some old enough that AGM batteries weren't even invented yet) all with absolutely no worries.
  16. Jan 26, 2024 at 2:35 PM
    Ctaylor76
    Ctaylor76 New Member
    Chaz
    Houston
    2021 Tundra Supercharged
    BDS 4.5 inch coil over lift BDS UCA’s 35 inch ridge grapplers AT 20 inch methods with offset 5.29 Nitro Gears ARB rear air locker with dual stage air compressor RC switch panel Both bumpers are RC LED Bumpers (6 pods and lower LED light bar) AMP Research power steps Lower RC Tow hooks B&M Transmission Pan CSF Radiator Radium Duel Catch Can BDS recoil traction bars Helwig adjustable rear sway bar Retrax Power Trax tunnel cover NSV LED front light bar Morimoto XB LED Head lights DOOD Rear smoked LED Tail lights (Amazon) NSLUMA Smoked 3rd brake light (Amazon) Morimoto 4 Banger LED A pillar lights Boostautoparts LED tow mirrors w/ power fold (smoked black) Full 3 inch true duel with XF Flowmaster mufflers custom Vbands Steelworks Longtube Headers RC seat covers OEM Audio plus full sound system duel sub 13 inch Phoenix Automotive In dash screen Stater X remote start system Uniden R8 Radar detector Odyssey Extreme Battery RC Seat Covers RC Rubber Mat Bed Cover Full body color door handles & TRD Grille OEM Magnuson TVS2650 Supercharger
    It’s just a little diode you swap out for a fuse, I wouldn't over think it just swap it out if you have a charging cycle battery over 14v so your battery stays topped off while your driving on the freeway or your alternator won’t click on. It’s honestly just a pre caution, I did this and noticed the difference immediately and I have a crap ton of lights and a ARB pump and an android deck and audio system in my truck. If your lights flicker when you crank then you know your batteries not topped off mine did before and it doesn’t now. I need my battery to stay optimal and letting your battery die because of that stupid voltage regulator Toyota puts on the ECU is just non sense.
  17. Aug 11, 2024 at 8:10 AM
    Pac12AfterDark
    Pac12AfterDark New Member
    Deleted
  18. Aug 13, 2024 at 8:33 PM
    jmanscotch
    jmanscotch New Member
    Jake
    2020 Tundra TRD OR CM
    Diodes do have “resistance” or voltage drop across them, so a diode does have a different resistance across it compared to the fuse it replaces…essentially.
    In the case of changing the alternators charge monitoring circuit from a fuse to a diode, the resistance only needs to change by approximately ~0.8 ohms to change the charging circuit voltage from mid 13V to mid 14V.
    In normal operation, the ECU would see ~13.5 volts on that observed circuit voltage with a fuse in line, and charge the battery accordingly.
    Add the diode with a small resistance/voltage drop across it and the ECU will see a false lower ~12.7 volt reading instead and let the alternator charge more to correct the “low” voltage reading. Since that low voltage reading is actually erroneous/modified, the net effect is an actual ~14.x voltage charge being emitted from the alternator, the ECU monitoring the alternator just doesn’t know it…but the battery does.
    BTW, I’m running an X2 Power battery and I have the GM diode, but I’m not running it. I personally believe the battery isn’t meant to be charged by 14.6 volts constantly, as much as it isn’t meant to be charged at 13.4 volts. I think it really needs an occasional charging to 14.6 volts aka letting it charge at the lower voltage normally and throwing it on a charger once a month to bring it to 14.6 volts. But I’m too lazy to do that and opt to just charge it at the 13v level and let it ride. We’ll see.
