Going to pull heavy trailer with an 23 SR5 TRD
Discussion in 'Towing & Hauling' started by MoPops, May 2, 2024.
  1. May 2, 2024 at 4:30 PM
    MoPops
    MoPops [OP] New Member
    Jeff
    2012 Dbl cab, 4x4, 2023 SR5 TRD 4x4 Dbl cab
    Bilsteins all around, RAS, E tires.. All on the 2012
    I pull a 25’ airstream TT. It has a tongue weight of about 1,000 lbs. Right now I’m pulling it with my 2012 with the 5.7 and a Roadmaster Active Suspension. It does great. I think Im selling my 2012 to my son. The local dealer has a 2023 SR5 TRD for a decent price. I obviously can’t use a RAS because there aren’t any rear leaf springs. So, I’m guessing I’ll need an airbag of some kind. Just wondering what others with a similar situation are doing. I tried searching, because I imagine this has been asked numerous times before. I have poor search skills. Sorry.
    Leo's first and MEGA VOL like this.
  2. May 2, 2024 at 4:40 PM
    NORTHof54
    NORTHof54 New Member
    Mario
    Alberta
    ‘24 Limited Windchill TRD OR
    Watch your payload rating compared to hitch weight is going to be the common answer to this question
  3. May 2, 2024 at 5:37 PM
    MoPops
    Jeff
    I’m sorry. I thought this was a Tundra forum. I’ve been pulling this same trailer for 4 years, 30,000+ miles all over the US, with my 2012 Tundra. I guess the newer Tundras can’t take a little stress? Ok..
    DogRunner2 likes this.
  4. May 2, 2024 at 5:55 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Sorry about the lack of a welcome. This is a Tundra forum and towing is sometimes a sensitive subject around here.
    Everyone has a unique experience and opinion for towing as there are so many variables - the only truths are payload capacity and trailer weight. These are tougher with Airstreams. They are built hitch heavy so it eats into the truck payload. If you are over payload, well that’s a number you can’t change.
    With that said, if your numbers are in your comfort range, the general approach is to look at the weight distribution hitch before changing anything else.
    Start with reading a thread like this:
    https://www.tundras.com/threads/desperate-for-airbags-or-something-to-eliminate-rear-sag.108650/
  5. May 2, 2024 at 5:56 PM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    Air bags will work fine. Check the suspension thread and tow/haul thread for what other Gen3 owners are using. The SR5 will do fine.
    MoPops[OP] likes this.
  6. May 2, 2024 at 6:10 PM
    MoPops
    Jeff
    I’ll check those threads. Thanks. I just have zero experience with airbags.
    I’ve read a million articles about payload, axle load ratings, GCWR, tow limits and ratings. I use a good weight distribution hitch and have it set up properly. Went over Beartooth Pass last time we were out west. Google it..
    j-utah likes this.
  7. May 2, 2024 at 6:14 PM
    Are you using a Load Distribution Hitch? I would start there before using airbags.
  8. May 2, 2024 at 7:51 PM
    blenton
    blenton New Member
    Welcome to the site. Some folks are payload averse. Some feel these trucks are only good for getting groceries (Costco may or may not be an acceptable since they deal in bulk - means your groceries are heavy..) and should - under no circumstances - be used to tow or haul anything. Some folks feel the space shuttle is well within the realm of possibilities. I’m somewhere in the middle.
    Air bags are the answer for you, my friend. The only other real solution would be different heavy duty coils, but if you don’t have a constant load in the bed 500 lbs or more, they would make for an uncomfortable ride.
    I’ve run airbags for years and tow regularly. They help shoulder and manage the load very well and are obviously adjustable for your varying load needs. I’m a fan of Firestone Ride Rites. Buy a portable tire inflator from the tool color of your choice (Milwaukee for the win!) and you can air up tires and air bags as needed for towing.
  9. May 3, 2024 at 3:52 AM
    MoPops
    Jeff
    Thanks. I’m not super skilled in the shop. I did the RAS install, and would prefer to do an airbag install also. Just curious how challenging it is? I’m sure there’s a YouTube video or two. I transfer as much weight as I feel comfortable with, with my weight distribution hitch. Unfortunately the airstream trailer frames can only take so much stress. If I tried to completely level the truck and trailer with the hitch alone, it would probably separate the shell from the frame.
    Thanks again.
    ColoradoTJ likes this.
  10. May 3, 2024 at 3:57 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Early 2023s were still eating up main bearings.
    Coal Dragger likes this.
  11. May 3, 2024 at 5:18 AM
    Spartanfam
    Spartanfam New Member
    West Michigan
    2024 Tundra Limited TRD Off-Road
    Hello @MoPops
    As mentioned above, there are other threads about towing with the 3rd Gen Tundra. Others are:
    https://www.tundras.com/threads/what-camping-setup-do-you-have.72845/page-21#post-3540483
    https://www.tundras.com/threads/what-do-you-tow-with-your-22.102478/page-5#post-3536565
    I personally tow a 25' Airstream FBQ with my 2024 Tundra. I previously towed it with a 2017 F150. I recently towed through the Appalachian Mtns with it and it was a champ. The engine braking was superior to my F150 3.5L EcoBoost with Tow Pkg. It rides level with a BlueOx SwayPro... same setup I had on the F150. I do not have airbags, just the TRD OffRoad pkg, which has monotube shocks and (I believe) dual-rate springs.
  12. May 3, 2024 at 6:09 AM
    303Gen3
    Golden Colorado
    sounds to me like you have it under control and will have no issues getting your set-up correct. Beartooth.. funny I use to go over that every summer with my father in his International Scout back in the late 50's early 60's - long before it was paved. That was a fun ride. I am sure it still is.
    Leo's first likes this.
  13. May 3, 2024 at 6:18 AM
    303Gen3
    Golden Colorado
    false. many sold and the total failure rate is less than 1/2 of one percent. When they fail - yes it is a big deal. Open ended statements make it sound worse than the facts show. Same could be said for the issues with your truck's powertrain - but even with the number of issues it has they are, just like the Gen3, reliable. Sucks when one person on the assembly line can't do their job correctly - guess that is why people get sent packing and someone else who wants to do the job correct 100% of the time takes over. Problem fixed.
  14. May 3, 2024 at 6:33 AM
    MoPops
    Jeff
    Hmm, this is a used 2023, so I imagine it’s an early one. That might explain the low price. Thx
  15. May 3, 2024 at 6:34 AM
    j-utah
    j-utah performance warrantied member
    Utah
    Fortress of Solitude, CO
    2024 Tundra SR5
    Dice valve stem caps (black)
    OP, I am towing a 25’ Outdoors RV that has 1000 lbs of tongue weight, with a WDH.
    I have only done it once so far, a 1000 mile round trip to western Kansas. Interstate speeds but relatively flat. Before that, I towed with a ‘13 Sequoia SR5 5.7.
    My SR5 Tundra is very smooth and stable towing. The power is impressive. Stopping power was good, brakes on the trailer are good. I had a wife, kid and dog in the cab. Not much at all in the bed. My payload is close to maximum, as it can be, because the engineers said that’s what it can be. I am not going to build in a fudge factor, and if something breaks, I will get it fixed. But I don’t think it will. Got to stay positive but be prepared.
    My 24 Tundra is a fully optioned SR5 with factory air bags and factory tow mirrors. Something to consider. It has the good stuff that I like, very close to a Limited inside. But no perks that add weight such as the sunroof. I don’t need a hole in my roof. Big radio screen but no JBL. Not a lot of chrome. Price was terrible, but not uber terrible. I am satisfied with my purchase and impressed with the smooth power and stability and it ran over tumbleweeds just fine. It is not a perfect truck at all but my dislikes are small.
  16. May 3, 2024 at 12:17 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    You don't know how bad is the bearings damage until the engine is split apart. If it does not knock yet, it does not mean there's no damage.
  17. May 3, 2024 at 12:58 PM
    blenton
    blenton New Member
    No problem. Good approach, IMO. The install on previous model truck is straightforward but a little more involved than perhaps the RAS was. The kit comes with brackets that take all of the guesswork out of placement; you just have to follow the instructions. The only thing you really have to think about is where/how to plumb the airlines, then figure out how to avoid the exhaust and other moving parts (not as hard as it sounds). I wanted to be able to fill either side independent of the other, so I ran two separate lines without a T fitting. I found that they fit great just above the fuel filler on my truck. That may not be the case for you.
    For the 3rd gen, they replace the factory jounce bumper. You basically pull off the jounce bumper and bracket as well as a few other bolts and small pieces (e brake cable bracket, for example), replace them with the the brackets in the kit, install your air bags, the run some air line. A tip for the air lines that they note in instructions: you really do want a clean 90 degree cut. Diagonal cutters and such won't give you that clean cut as it smashes the line flat before cutting. A sharp new utility blade is perfect for making that cut. Use the blade to slice like a piece of bread rather than chop or sever. I've had zero leaks in 7 years using that method.
    MoPops[QUOTED][OP] likes this.
  18. May 3, 2024 at 5:37 PM
    303Gen3
    Golden Colorado
    so your Gen 2 / 2.5 could shit the bed too and you would have no clue there is an issue. So if the Truck you are driving is so good why is it replaced? Looking for sympathy - you will find it in the dictionary between shit and syphilis. V8's are dead. V6 TT are the current and future replacements for the dead option you drive. Go back to your Gen Thread - it is safe there because everyone is like you. Pre Gen3 owners are "Living in the past." Officially "ignored" so flap your lips away! Three down. Flap away you Gen3 haters.
  19. May 3, 2024 at 6:00 PM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Tundra Crewmax Platinum 4WD
    FIFY
    Tripleconpanna and vtl like this.
  20. May 3, 2024 at 6:08 PM
    blenton
    blenton New Member
    So… airbags, then?
    Tripleconpanna and RichterScale like this.
  21. May 3, 2024 at 6:28 PM
    MoPops
    Jeff
    Great info. Thanks! If I get this 2023 I’m looking at, I’ll definitely try towing without adding airbags. I use the BlueOx SwayPro also.
  22. May 4, 2024 at 6:26 PM
    Csteppe
    Csteppe New Member
    Chip
    I have a 2023 Limited with the airbags and it pulls great. I’ve pulled a couple wet pallets of sod, my 19.5 Scout center console and an enormous amount of wood on a duel axel trailer. It’s done great. Even better than my 2021 F-150.
  23. May 21, 2024 at 7:23 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    A 2023 Tundra SR5 should tow your trailer just fine. 2022 and 2023 model year Tundras and even one reported 2024 unit have had some issues with main bearing failures. It’s a very small percentage of trucks, but it is something to consider if you’re very risk averse.
    As an observation if I were towing as many miles as you each year, particularly a travel trailer, I would seriously consider a 3/4 ton with a diesel. Your use case supports it I think, and the 3/4 ton or larger truck will better control the trailer and give you a comfortable margin of additional payload if you need it. All of the current HD diesel trucks also give you an exhaust brake, so your downhill control will be greatly enhanced.
    Either way you’ll be fine, make the best decision for you.
  24. May 21, 2024 at 7:45 PM
    j-utah
    Utah
    2024 Tundra SR5
    No concerns, but I appreciate what you’re saying. Nothing wrong with the JBL and the sunroof, but I don’t need them. I’m glad you like them.
    DogRunner2[QUOTED] likes this.
  25. May 22, 2024 at 4:05 AM
    MoPops
    Jeff
    I didn’t think 33,000 miles in four years actually justified a 3/4 ton diesel, but I never really put it down on paper, and tried to work out the math. I’ve had horrible luck with the big three US automakers over the years. Since I switched to Toyota, all I’ve done is maintenance stuff. Who knows, maybe the 2023 SR5 TRD I just bought will take me back to old days of “what’s wrong now?” I sure hope not. I’ve kept the 2012 Tundra, if I don’t like how the 2023 tows, I’ll just hook it up to the old truck. It was great. Since retirement it’s somewhere warm every January and somewhere cooler every summer. Home when it’s nice. We like the mountains in summer, and prefer out of the way NFS CGs. Some are a bit challenging to get back to.
    Terndrerrr and vtl like this.
  26. May 22, 2024 at 5:55 AM
    j-utah
    Utah
    2024 Tundra SR5
    No, no ….. no problem at all. I got what you were saying. I don’t mind sarcasm! It’s not like my word choices seemed overly diplomatic when I said I don’t need a hole in my roof. :hattip:
    My RV loaded will be around 7,500 lbs and I can make that a little more but not less. I can adjust the tongue weight too if needed but I don’t think by much. But these are all pretty small moves. I would like to have more margin on the payload side. I figured this setup with the Tundra is worth a try, and if it doesn’t work out we can pivot. My truck is going to be on probation for a lot of miles. Maybe in one year, or three I will see a 3/4 I’m comfortable with. And breaking down on the side of the road might not hurt with selling that to the better half. Until then I will be cautious. The more perspectives I get the better in my book.
    :fingerscrossed:
