Got New 2018 Tundra Limited today, did I make a mistake?
Discussion in 'General Tundra Discussion' started by BD264, Dec 17, 2018.
  1. Dec 17, 2018 at 8:24 PM
    BD264
    BD264 [OP] New Member
    Stac
    2018 Limited
    Hope to do a lift, but all the Safety stuff has me worried
    Hello all, Bought my 4th Toyota today and ordered tires that will raise the truck about 3 inches. Came with 18 rims, Im putting XD wheels 20 inch rims. I bought this truck to put on a 2 inch lift like I did with my last 2 Tundras, now Im reading all the precollision Safety posts. If I do my mods what will happen? Will it suddenly stop if the radar / sensors are activated. SO bummed, I should be super pumped..can I still do the mods, must I disengage the PSC everytime before I drive it? My 2013 Tundra I traded in had 35K miles 2 inch lift 20 inch wheels and was perfect. Boy I hope I did not screw up. I really appreciate any help you guys can share. I live in central Pa. DRive safe
    Pinay and TXRailRoadBandit73 like this.
  2. Dec 17, 2018 at 8:26 PM
    Welcome from Texas, Let's see your ride
  3. Dec 17, 2018 at 8:28 PM
    If the truck stays level you’ll be fine. There are plenty of lifted 2018-2019 Tundras lifted without issue. Take a breath.
  4. Dec 17, 2018 at 8:30 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC! You should be fine but just research the posts as it relates to the Safety Sense sensor and camera. Some have issues while others do not.
    Pinay likes this.
  5. Dec 17, 2018 at 8:38 PM
    BD264
    Stac
    2018 Limited
    Thanks guys Hey T-Rex266..you mentioned that if it stays level Im ok? Is that the part about "rake" so you would recommend not leveling it then. 1 or 2 inches max flat? Thanks again!
  6. Dec 17, 2018 at 8:39 PM
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    Welcome from New Jersey!
    :worthless:
  7. Dec 17, 2018 at 8:40 PM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    Welcome, I belive level would be 2" up front. That will take out the rake.
    NewImprovedRon likes this.
  8. Dec 17, 2018 at 8:50 PM
    BD264
    Stac
    2018 Limited
    Thanks I was going to do 2 inch rear and 2 inch front
    geno0506 likes this.
  9. Dec 17, 2018 at 8:50 PM
    Welcome from NY.
  10. Dec 17, 2018 at 8:51 PM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Welcome! Your only mistake was buying 20" rims. ;)
    831Tun and lionix like this.
  11. Dec 17, 2018 at 8:51 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado
  12. Dec 17, 2018 at 9:19 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    I’ve had a 3/1 lift in my 2018 for over a year with zero issues..you’ll be fine
  13. Dec 17, 2018 at 9:27 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    What size tires did you get that will raise it 3"? I think stock is around 32" to get 3" lift from tires you'd have to be around 38" tires.
    And as far as the TSS systems, you should be ok with a couple inches of lift. People seem to be having more issues with changing the grill than with a lift.
    I dont know that I've seen an 2018 or 19 lifted more than 3 inches though, and you're taking about 2 inches of suspension lift and massive tires equaling 5" lift. Not sure of that high will be an issue.
  14. Dec 18, 2018 at 4:36 AM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    :wave: welcome... breathe, breathe,, breathe... 10...9..8...7...6..5..4..3...2......1 exhale... woooosahhh
    for reference find a dealer that has the tools to calibrate the radar and have them adjust or verify after lifting.
    a dealer that sells them already lifted should be able to recalibrate so that the system is targeting (painting) correctly.
    a friend of mine that works on a different OEM told me that not all shops will have the equipment because it's new and expensive.
    you have nothing but time to get it all worked out via resources here, if you need the lift for offroading immediately just do it. if it's for crusing the mall then take your time, sidewalks, speedbumps and curbs haven't changed in quite sometime so stock clearances should still be fine. ;) good luck bud.
  15. Dec 18, 2018 at 5:53 AM
    WolfofWattsStreet
    WolfofWattsStreet New Member
    2018 Tundra Crewmax 5.7L
    FWIW, I have a 2018 lifted 3.5/1/5 and it sits a tad nose high, plus I have shell on the back which sags it a tad. zero issues with sensors so far and its been about 6 months.
  16. Dec 18, 2018 at 5:59 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    That will not make any difference to the safety system. Most of the hype about the system not working with a lift or level is just rumor anyway.
    You will be good!
    Congrats on the truck, welcome to the page, and post pics when you have the lift and wheels installed.
  17. Dec 18, 2018 at 6:06 AM
    Boerseun
    Ferdie
    Sarasota Florida
    You mentioned that you ordered tires that will raise the truck about 3 inches. Is that with the 2" lift? Tires that raise the truck 3" would have to be 6" taller tires (only the bottom half count for raising the truck) which will cause rubbing issues. I assume you are counting the 2" lift with 2" taller tires for 3" total lift. With 2" lift you can go up to 285/60R20 (33.5") but bigger will rub.
    Pudge and NewImprovedRon like this.
  18. Dec 18, 2018 at 6:48 AM
    Steve6
    Steve6 New Member
    Tucson
    Welcome from Arizona.
  19. Dec 18, 2018 at 6:51 AM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Welcome from SE PA!
  20. Dec 18, 2018 at 6:54 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Welcome from La,
    You’ll be fine. Relax. There’s a ton of 18-19 tundras out there that haven’t had problems with their sensors after lift/level.
    Worst case, yours does and you lift it 1 inch in the back for rake.
    Best case, your mods don’t give you any problems.
    Not a bad gamble.
