Greasing Camburg 1.5" Uniballs, help?!
Discussion in 'Suspension' started by d0zer, Feb 2, 2019.
  1. Feb 2, 2019 at 9:42 AM
    d0zer
    d0zer [OP] I beat the internet.
    Definitely somewhere
    2017 MGM Platinum
    ADS 3.0" & 2.5" AllPro APEX Sliders SCS SR8 on Cooper ST MAXX 295/70r18
    Attempted to grease my Camburg 1.5" uniballs via the zerks this am. Loosened the UCA bolt and connected up the grease gun. Gave it some pumps, but the bushings never moved. Almost like the grease wasn't flowing. Pulled off the gun, pumped it into the trash, grease oozed fine. Back on the zerks and 3-4 pumps still nothing.
    Do I have a bunk gun? Am I missing something? Tried pushing the needle of the zerk in with a pick, worked fine, it depressed. I can't imagine these things would take more than about 1-2 pumps.
    Any ideas/help would be appreciated.
    Pic for attention :D just before starting.
  2. Feb 2, 2019 at 10:08 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    You are fighting the pressure. Mine seemed to almost make a seal. What worked for me was do 2 pumps, then when the gun handle gets hard to squeeze just wait a few seconds and then you'll notice it gets easier. Pump pump and wait again.
  3. Feb 2, 2019 at 2:16 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I thought you were supposed to loosen the bolt so you don’t warp the bushings. I know that’s how total chaos says to do theirs. Loosen bolts, then pump till you see it come out, then re-tighten.
  4. Feb 2, 2019 at 2:19 PM
    d0zer
    2017 MGM Platinum
    That is what I did. UCA bolt totally loose, no grease out of the bushing, no deformation of the bushing. Thinking either pressure issues or bad grease gun. Bolted everything back up, because I gotta do other stuff today, but will try another time.
  5. Feb 2, 2019 at 2:21 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Maybe the knob on the arm is blocked. Can you push a pin in to scrape it out or unscrew it to clean it?
  6. Feb 2, 2019 at 2:22 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Just noticed your pic, good beer.
    d0zer[OP] likes this.
