Grill swap/parts questions
Discussion in '2.5 Gen Tundras (2014-2021)' started by hudrock, Oct 10, 2018.
  1. Oct 10, 2018 at 5:42 PM
    hudrock
    hudrock [OP] New Member
    So Cal
    18 Tundra before 20 Sequioa now
    Question for you Tundra vets...I have a 2018 and watched a video on swapping out the front grill - really simple and straight forward. I have the smoke/gun metal color honeycomb grill on my truck which I like and don't want swap out however the big chrome color pieces are another story. I want to order only these 2 pieces and swap them out with white. What is this part called so I can research. Also do you know if I order them without the grill? Thanks in advance
  2. Oct 10, 2018 at 5:45 PM
    TheBozzHogg
    TheBozzHogg New Member
    Jimmy
    2015 White Texas Edition SR5 CrewMax
    The top part is called the hood bulge, I personally have not seen the outer portion sold by itself. . Maybe someone else will know more.
  3. Oct 10, 2018 at 5:46 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    The top is a hood bulge, and the lower is a grille. You will probably have to order the whole grille.
  4. Oct 10, 2018 at 5:50 PM
    hudrock
    So Cal
    Thanks for the responses...yeah I sort of figured.
  5. Oct 10, 2018 at 6:12 PM
    nodnero
    nodnero I'm here legally yo!
    Temecula, CA
    Cement 2018 Limited 4x4 Crewmax
    18x9 Method 312 285/75R18 Toyo R/T Trail TRD Pro Suspension
    As others have said:
    Top part - Hood bulge
    Lower part - Grille assembly
    Middle part - Grille insert
    You cannot order just the surround from the grille assembly without the insert. Best bet is buy a painted grille assembly and then disassemble both your stock and your purchased assemblies so you can get the insert you want. I did that because I wanted to keep my stock limited insert with the sensor. The assembly is easy enough to take of the truck, thank god somebody at Toyota was thinking on the tundra to have the cut out and easy remove clip for the sensor. My Tacoma didn’t have that and it was such a pain to access I didn’t even bother removing the grille when I sold it.
    There’s a thread here from @Roman regarding the specifics of the grille for your review.
    Roman likes this.
  6. Oct 10, 2018 at 6:13 PM
    bfd300
    bfd300 New Member
    I love that grill
  7. Oct 10, 2018 at 6:26 PM
    hudrock
    So Cal
    Great info thanks... Yeah the 2018s at least seem really easy to swap out.
  8. Oct 10, 2018 at 6:35 PM
    johnsmsith6073
    johnsmsith6073 New Member
    2015 Limited
  9. Oct 11, 2018 at 6:35 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  10. Oct 11, 2018 at 7:24 AM
    hudrock
    So Cal
    Roman[QUOTED] likes this.
