grille swap
Discussion in '2.5 Gen Tundras (2014-2021)' started by brico1, Jan 30, 2021.
  1. Jan 30, 2021 at 10:52 PM
    brico1
    brico1 [OP] New Member
    hello all,
    I'm trying to do a grille swap on my 2018 Limited Tundra Cement Grey. I have looked at that "grille information thread" page and still cannot determine what exact parts i need to make the swap. I'm trying to go from the factory all chrome bumper to this in the photo ( picture i saw somewhere here on the forum) any and all feedback is helpful!
  2. Jan 31, 2021 at 4:28 AM
  3. Jan 31, 2021 at 4:52 AM
    I_Am_Thee_Walrus
    I_Am_Thee_Walrus New Member
    ‘21 Tundra TRD Off-Road
    You need the TRD Pro Grill with color matching surround. If the surround is already the same color(not chrome), then you only need the grill “insert”. If your hood “bulge” is also chrome, you will need the color matching option of that too.
  4. Jan 31, 2021 at 5:14 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    FAA0C53E-7974-4719-A8D5-8E87DCF5F581.jpg I have a cement gray and got the 2014-17 pro grill with the Jomax relocation bracket.
    If you get the newer pro grill you need the sensor garnish which is absurdly expensive. And I don’t believe you can get the newer pro grill color matched with cement gray - you would have to get it painted
  5. Jan 31, 2021 at 5:14 AM
    zach_attack4
    zach_attack4 New Member
    Zach
    York, PA
    21 Army Green CM
    Have to agree here. This thread has all the info and part numbers you will need. Without a picture it's hard to say exactly what combination of parts you need. The grill is pretty straightforward but you have options with your bumper. With the existing chrome, you'll need a few extra parts other than the covers. Again, all of that is listed in the quoted thread. Another, cheaper option, would be the bumper corner skins a few members are running.
  6. Jan 31, 2021 at 5:14 AM
    Alt0174
    Alt0174 New Member
    2021 Limited
    Chromerectomy
    Tundra2 and Black Wolf like this.
  7. Jan 31, 2021 at 5:32 AM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    This should be everything you need for the grille. You'll have to get the surround (and probably the bulge too) repainted to match.
  8. Jan 31, 2021 at 9:22 AM
    jefroshm0
    jefroshm0 New Member
    Elk Grove, CA
    2018 Cement Tundra Crew 4x4 SR5
    I have 2018 SR5. I bought cement hood bulge color matched and a 2014 trd pro grille with color matched surround. I did not want to use a TSS relocation bracket and personally hate the “Toyota” written across so I kept my sport grille.
    you have to separate the grille insert from the surround for both pieces. Then replace the grille you want into the color matched surround.
  9. Jan 31, 2021 at 9:25 AM
    jefroshm0
    Elk Grove, CA
    https://m.youtube.com/watch?v=kb4iBLYoq9M
    video shows how to swap grille inserts into the color matched surround. Be gentle about the clips. They do break easily. I broke 2 off but haven’t had any issues.
    JerryH and pvn.beluga like this.
  10. Jan 31, 2021 at 10:07 AM
    InsaneAuto86
    InsaneAuto86 New Member
    SE PA
    2020 Tundra SR5 TRD
    Check my sig link for tips on not breaking the clips.
    off topic: what rims are in the above vid?
  11. Jan 31, 2021 at 10:32 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    According to the channel:
    "The wheels are the trd 22” forged alloy rims that were out in ‘09-11. I then had them powder coated"
  12. Jan 31, 2021 at 1:31 PM
    brico1
    this is the exact look I'm going for!
  13. Jan 31, 2021 at 1:34 PM
    brico1
    i appreciate all the responses! i'm digging through info now trying to determine what i need to make the conversion!
  14. Feb 3, 2021 at 10:11 PM
    WhiteStar20
    WhiteStar20 New Member
    Dennis
    Okotoks, AB., Canada
    2020 Tundra Platinum CM
    Rockstar XD 20” rims, BAK Bed cover, TRD Dual Exhaust, etc., etc...
    If anyone's doing a grill swap from a honeycomb sport model to Pro grill type, I'd be interested in the discarded, unwanted insert. Any condition is fine.
