Gun magnet
Discussion in '2.5 Gen Tundras (2014-2021)' started by netranger6, Jul 21, 2018.
  1. Jul 21, 2018 at 1:02 PM
    netranger6
    netranger6 [OP] New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    Hiw are you guys mounting them. Where at. I got one from Ronin. It came with 3m tape. Tried it. Wouldn't stick to anywhere under dash or side of shift box. Same for gorilla double sided. Think the texture of the plastic prevents a good bond.
    4x4_Angel likes this.
  2. Jul 21, 2018 at 1:11 PM
    tundras00
    tundras00 New Member
    Did you try cleaning with alcohol first? Honestly, I haven't found a good way to mount either. I just keep it at the ready.
  3. Jul 22, 2018 at 6:22 AM
    netranger6
    Jeremy
    Yep. Heck the gorilla tape barely holds to back of magnet. Sorcery I say.
  4. Jul 22, 2018 at 7:52 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    eric.t.lindgren likes this.
  5. Jul 22, 2018 at 4:15 PM
    netranger6
    Jeremy
    This came with screws AS well
  6. Jul 23, 2018 at 3:14 AM
    netranger6
    Jeremy
    Welp. Tried loctite red double sided. Same effect. What is this sorcery??
  7. Jul 23, 2018 at 3:22 AM
    ARES
    ARES ARES Fabrications
    God Bless America
    2018 Tundra TRD Cement
    1. Inside the rear pocket of passenger seat seems to be a nice spot with the seat slightly more forward then drivers side.
    2. Amazon has some nice 40lb magnets set of 2. Mount one under the dash to the lower right of your leg. And another in the middle of the lower drivers side door pocket for a quick cross draw if the one behind the seat becomes unattainable.
  8. Jul 23, 2018 at 4:33 AM
    ladywolf
    ladywolf New Member
    Kristen
    Clarksville TN
    05 S45 4x4 Double cab Jade Green Mica
    2.5" eibach coils/springs
  9. Jul 23, 2018 at 9:10 AM
    Runnerstrom28
    Runnerstrom28 Hail Hydra
    Derek
    14 limited blue ribbon tundra crewmax
    This is what I plan on doing! Looks good
  10. Jul 23, 2018 at 9:12 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    love vet owned companies!
  11. Jul 23, 2018 at 9:51 AM
    tundras00
  12. Jul 23, 2018 at 10:18 AM
    4x4_Angel
    Bree
    Funky Town, Texas
  13. Jul 23, 2018 at 9:06 PM
    tundras00
    After going to the truck and checking, I don't think it can work on our trucks. We don't have any rails under our seats.
    This should work though: https://www.daraholsters.com/ram-quick-ship-mounted-holster/#write_review.
    I'd rather not drill into anything either, but it looks like the only way possible to have a solid grip. I was thinking of picking this type of magnet up(https://www.amazon.com/Tac-Mag-Gun-...iptionId=AKIAILSHYYTFIVPWUY6Q#customerReviews), but from reviews some say that it can't hold a full gun. I don't want anything flying around.
    4x4_Angel[QUOTED] likes this.
  14. Jul 24, 2018 at 1:08 AM
    geno0506
    geno0506 New Member
    Michael
    Amen to that Bree! :oldglory:
  15. Jul 24, 2018 at 9:54 PM
    ARES
    God Bless America
    Gun Magnet Mount 2-Pack | 43 Lbs Rated | IronMount Rubber Coated Magnetic Gun Mount & Holster | Concealed Holder for Car, Handgun, Pistol, Shotgun, Rifle https://www.amazon.com/dp/B077J1TT1P/ref=cm_sw_r_other_apa_diawBb97FBTCK
    I used these. I know for a fact your freedom piece will not move
    plumber802 and 4x4_Angel like this.
  16. Jul 24, 2018 at 10:01 PM
    tundras00
    I don't know. Most of these magnets have mixed reviews. I will probably look for a holster mounted system.
  17. Jul 30, 2018 at 10:53 AM
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    I have a couple of these. Since my Jeep was tight on space, I really didn't have a lot of room for a holster mount that wasn't visible if the top or doors were off. I slipped it under the upholstery and could just stick the handgun to the seat if I was on a long drive. It was strong enough to rack the slide through the leather. I am looking for a spot in the Tundra to mount it for those drives that I might want to unholster but keep it close.
    https://www.amazon.com/Magnetic-Gun-Mount-Car-Holster/dp/B07BPWYBTQ
  18. Jul 30, 2018 at 1:55 PM
    tundras00
    Any lefties in here and how are you mounting the magnet/holster? Due to someone coming on the driver's side, the best option is to use your weak hand and draw with right hand I would guess. It would also keep the handgun out of reach of the BG. Since seatbelt is mandatory in most states, it's also hindering our draw. If i were to draw with the left, I would have to shift the position and square the body towards the BG. The belt keeps you from doing that.
    EDIT: Just realized I hijacked the thread. Sorry OP
  19. Jul 30, 2018 at 2:03 PM
    Burn69
    Burn69 New Member
    2018 Tundra Platinum 4x4
    Ready Lift 6" Lift Black Rhino 20x9.5 w/ 35" BFG KO2's Winjet Rear LED Tails GoRhino Bull Bar w/ Rigid Duallys Rough Country DS2 Steps
    I would like to mention the OEM Gun safe that can be installed in the center console. Not sure if your looking for quick draw or not but it is good for securing the gun from thieves as well as kids in the truck. Also the safe is large so you can put other valuables in it as well.
    plumber802 likes this.
  20. Jul 30, 2018 at 2:13 PM
    tundras00
    It is different to store and different to have it ready for a fight. If you have it inside the safe, than you might as well be disarmed. That's the whole reason why guys/gals mount magnets or mounts.
    I have the OEM safe and it is used only for storage, as it is intended.
  21. Jul 30, 2018 at 2:17 PM
    Burn69
    Burn69 New Member
    That is true, the best thing to do if your using magnet style is to get a very powerful one and put it under the dash on the drivers side but not attached under put the magnet inside the panel and stick a piece of felt on the outside to prevent from marring the panel. This will eliminate the issue with it falling off since you wold be attaching it from the inside of the panel, the panel itself will assist in holding it on.
  22. Jul 30, 2018 at 2:18 PM
    BWinter
    BWinter New Member
    Central California
    2018 White 1794, TRD Off Road, 4x4
  23. Jul 30, 2018 at 6:15 PM
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
  24. Dec 27, 2019 at 6:09 AM
    ZPMAN
    Minnesota
    I'm about 90% done with my mount, just have to epoxy Phantom to the mount and paint.
    This was first go round, 2" short.
    Solid frame mount.
  25. Dec 27, 2019 at 6:39 AM
    TXTundra2722
    2015 Black Tundra
    Not the prettiest thing, but that is some damn fine ingenuity!
    ZPMAN[QUOTED] likes this.
