Hack for allowing moving truck with door open?
Discussion in '3rd Gen Tundras (2022+)' started by Maddogs, Oct 19, 2024.
  1. Oct 19, 2024 at 6:43 PM
    Maddogs
    Maddogs [OP] Re-Tarred
    Southern WA
    23 Limited Dbl Cab
    4Wheel camper, airbags, rear seat delete. thass it.
    Sounds wierd I know, why would you do that? I have a gen 3 tundra limited trim. My scenario is that we have an in-bed camper, and when camping out in the boonies I often have to use leveling blocks under the wheels, usually backing up onto them. In order to do see the rear tire and where it is in relation to the blocks I have to open the door and try to go slowly backwards to get up on the block in the right position. First time I tried this however with this new truck I got a rude beeping from the dash somewhere and the truck went into park. I fully admit I'm not familiar with modern vehicle safety features, we have a fully manual 96 tacoma. Anyone know of a way to turn off all the safety crap that prevents me from doing this?
  2. Oct 19, 2024 at 7:14 PM
    GilFavor
    GilFavor New Member
    2023 silver tundra 1794
    I think you gotta open the door, put it in park, and then back into drive.
  3. Oct 19, 2024 at 7:31 PM
    Breathing Borla
    Northern Illinois
    ^ this
    put it back in p then try again and it will disable the safety bs
  4. Oct 19, 2024 at 7:42 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    These "safety" devices are such a nuisance it's becoming dangerous .
  5. Oct 20, 2024 at 2:17 AM
    wing-2
    wing-2 New Member
    Following.
    I have had a few occasions where I was inching the truck fore or aft, and was rudely interrupted by the parking brake coming on. Being old(er), it's frustrating that the machine I am operating refuses to obey my commands.:confused:
  6. Oct 20, 2024 at 3:12 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Not weird at all. If you use your truck other than just an A to B, it's good for many things. One example, I was pulling a ton of shrubs for several houses around me, being able to leave the door open was fantastic.
  7. Oct 20, 2024 at 3:45 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Yep!
  8. Oct 20, 2024 at 8:38 AM
    Maddogs
    Southern WA
    23 Limited Dbl Cab
    thanks guys I'll give the park then reverse thing a shot and report back!
    Breathing Borla likes this.
  9. Oct 20, 2024 at 10:12 AM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    I cut a buckle off a wreck and use it in the seatbelt latch for when I'm maneuvering and loading/unloading.
    Saves having to put seat belt on and off to drive short distance on the farm. I've done what suggested above,
    been able to drive with door open but door is open before I pull out of park. But mine is a 2010.
    When I was 5 we had a '63 Biscayne Wagon, I opened the rear door and out I went.
    It was winter and I fell into a slushy ditch, no harm no foul. Perhaps I'm the reason these things come to market?
    j-utah and 22whatwedo like this.
  10. Oct 20, 2024 at 11:18 AM
    Woodrow bangs
    Woodrow bangs New Member
    Baltimore
    2023 MBM Platinum
    Dangerous? Really? No
    Duckinatruck and raylo like this.
  11. Oct 20, 2024 at 2:43 PM
    JerseyGeorge
    JerseyGeorge New Member
    2024 Platinum
    I launch a 23' boat solo all the time. As soon as boat starts coming off trailer on the launch ramp I need to set brake and get out quickly. Often have to get in, back a little more, and slap on brakes to nudge boat off the trailer. So much easier to back the foot or two with door open. Likewise when hooking up trailer hitch. The cameras are awesome, but the last few inches forward or backwards have to be done by taking a look at alignment of hitch and ball. The door open, brakes on is a total PIA.
    sandiegosteve likes this.
  12. Oct 20, 2024 at 5:38 PM
    virgilus11
    virgilus11 New Member
    2022 Tundra Capstone
    1/2" front spacer 37" Cooper ATX
    Try to disable the auto parking brake. Toyota tech told me so
  13. Oct 20, 2024 at 6:57 PM
    Maddogs
    Southern WA
    23 Limited Dbl Cab
    Couldn't find any options on either the small dash features editing screen or the biga$$ infotainment screen vehicle settings to disable auto-park. Anyway I got it to work, albeit with a funky combo of steps. It didn't matter if I had the door open before or after the motor was running, but once door was open and motor running I started from park, put it in reverse (light clunk of brake coming off), put it back in park (light noise of brake engaging), then put it back in reverse (LOUD clunk of brake disengaging). Could indeed keep moving backwards in reverse at that point with the door open, but the dash still beeped at me annoyingly. The mechanical side of my brain is thinking that the very loud clunk on the 2nd move to reverse can't be good, plus it was physically harder to move the shift lever. Guess I can live with this, but I better park and get up on the blocks before I have any beers or I'll never remember the magic sequence.
  14. Oct 20, 2024 at 7:08 PM
    centex
    centex New Member
    Buy a 2.5 gen.
    MadMaxCanon and Woodrow bangs like this.
  15. Oct 20, 2024 at 7:17 PM
    Maddogs
    Southern WA
    23 Limited Dbl Cab
    Ha... Well that's a bit less than helpful, but I have actually been giving it some thought in light of the engine recall situation.
    TundraDan723 likes this.
  16. Oct 20, 2024 at 8:55 PM
    Woodrow bangs
    Baltimore
    2023 MBM Platinum
  17. Oct 20, 2024 at 9:25 PM
    Hella Krusty
    Hella Krusty New Member
    I used a Carista and just shut all the seatbelt BS off.
  18. Oct 21, 2024 at 5:37 AM
    Observer
    Observer New Member
    Haven't done it but if your will. If i remember correctly there is a option on the dash to not lock the doors when you put your truck in gear. if you were to set that then pull the jam switch on the driver door out and jump it then replace it the truck would think the door is closed even though you had it opened. I've had the door open and just pressed the door jam switch in and moved the truck. you can see it on your dash showing the door closing when you push the switch in.
  19. Oct 21, 2024 at 6:32 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I'm really curious how this would be dangerous.
  20. Oct 23, 2024 at 7:59 AM
    nodak67
    nodak67 New Member
    JR
    the procedure from the manual is in my sig
  21. Oct 23, 2024 at 8:31 AM
    Rcflyersd
    Rcflyersd Wingnut
    Mark
    Dakota
    01 Tundra SR5, 02 Sequoia SR5, 23 Tundra Limited double cab
    What I do when moving with the door open is: Let park brake engage quick, then step on brake pedal and tap park brake switch to the release them and it will let you move with the door open. Only issue is warning beeper will beep after that but park brake will stay disengaged.
    wing-2 likes this.
  22. Oct 23, 2024 at 8:39 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Previous generations back off with all the doors opened, seatbelt not buckled, parking brake applied and kids running behind the rear bumper. Just like trucks should do.
  23. Oct 23, 2024 at 8:41 AM
    Rcflyersd
    Rcflyersd Wingnut
    Mark
    Dakota
    I understand buckling the drivers seat belt will prevent the park brake from engaging with the door open as well...
  24. Oct 23, 2024 at 8:55 AM
    TexasCabledawg
    TexasCabledawg New Member
    2024 Land Cruiser (had a ‘22 Tundra)
    It’s not. There are people that struggle to adapt to new technology and change. Reminds me of my grandparents. Vehicles are safer now than they have ever been. “Back in my day we only needed lap belts, didn’t have crumple zones, pesky airbags and had “X” frames. Life was so much simpler.”
    Jaypown[QUOTED] likes this.
  25. Oct 23, 2024 at 9:19 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    It's not a novel technology question, it's a convenience question. Convenience is why good technology stays, even when it becomes old, and weird ones are gone after a short number of years.
  26. Oct 24, 2024 at 6:26 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Convenience is also why new technology comes. Sure I can lock my door to my house with a key. But new tech allows me to do it via an app from anywhere I have cell service. I'm sure some will say it's not reliable and you don't know that it's not locked or someone could hack into it. They can also steal your key fob data and steal your vehicle.
    Technology advances for safety will always be prevalent and grow/adapt. People with old mindsets that can adjust will not grow/adapt. That's life. Live under the rock or live with the rocks.
  27. Oct 24, 2024 at 6:39 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Excellent example! Now, I don't lock my house nor cars :)
  28. Oct 24, 2024 at 6:43 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Even better! You live in an area where that's not a problem. Truly something we would all love to have but unfortunately, not as common.
  29. Oct 24, 2024 at 6:53 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Drug addict in need may happen anywhere. He better take what he needs for his doze without causing even more expensive wreckage. Broken window is $1k at least.
    I grew up in a very bad neighborhood. Had a knife on me in school years, had to put it to work a couple of times. 11 y.o. knife fighting over there is why I raise my kids here.
  30. Oct 24, 2024 at 6:54 AM
    j-utah
    j-utah performance warrantied member
    Utah
    Fortress of Solitude, CO
    2024 Tundra SR5
    Dice valve stem caps (black)
    The seat belt inserts mentioned will bypass the safety features.
    https://thetikit.com/?gad_source=1&...ioRQk0PRkP64doYPQka5mblZyD33hT6kaArihEALw_wcB
