Hard Shift on gear 4,5,6
Discussion in '2.5 Gen Tundras (2014-2021)' started by Yota707, May 18, 2021.
  1. May 18, 2021 at 3:38 PM
    Yota707
    Yota707 [OP] New Member
    David
    Bay Area
    2015 Tundra TRD
    Auto detail, vinyl wrap specialist. Truck has a 300gal fresh water tank for spot free water while detailing and a Honda pressure washer
    I have a 2015 SR5 crewmax tundra with 110k miles on it. I haven’t had any issues with this truck. Over the past week I have noticed a hard shift between gear 4,5,6. I haven’t done anything to service the transmission yet. What would be causing this hard shift all of a sudden?
    I can’t check the transmission fluid there isn’t a dip stick. Any advice would be great before I take it to the dealership and they give me the run around.
  2. May 18, 2021 at 3:42 PM
    TXTundra2722
    2015 Black Tundra
  3. May 18, 2021 at 4:06 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    I think you answered your own question. I would do a fluid flush and fill at a minimum and see how it goes.
    HulkSmurf14, Tyman and FrenchToasty like this.
  4. May 18, 2021 at 5:59 PM
    Yota707
    David
    Bay Area
    2015 Tundra TRD
    So start with a fluid flush and see if that fixes it? Filter to or only flush the fluid? When I talked to Toyota they said that transmission is good for the life of the vehicle I’ve never heard that.
  5. May 18, 2021 at 6:43 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    Most people agree that's a gimmick. I would do just the drain and fill and see what happens. You can even repeat it after few thousand miles if theres an improvement. Filter is not usually needed but if all else fails you can try as a last resort.
  6. May 18, 2021 at 7:00 PM
    15whtrd
    15whtrd Mr. Blonde
  7. May 18, 2021 at 7:24 PM
    15whtrd
    15whtrd Mr. Blonde
    Just be careful with the word flush when taking it to a service shop. Also think about cleaning your MAF and throttlebody. That’s maintenance that should be done even if it doesn’t fix the problem. But a dirty MAF can cause some hard shifts. In my experience it was all the gears not just 4,5,6.
  8. May 18, 2021 at 7:28 PM
    Yota707
    David
    Bay Area
    2015 Tundra TRD
    Awesome I will look at this as well. Sorry I’m not very mechanically inclined what are you referring to MAF?
    15whtrd[QUOTED] likes this.
  9. May 18, 2021 at 7:44 PM
    15whtrd
    15whtrd Mr. Blonde
    https://youtu.be/DDgbiHe__j4
    Mass airflow sensor. It is located on your intake tube, you’ll see a couple‘s wires connected to it. Just get yourself a can of MAF cleaner, disconnect the wires leading to the intake tube, two Phillips head screws and pull it out. Don’t touch the sensor portion of it physically, just spray it off with the cleaner. You can also take this time to clean your intake tube if it’s dirty. As well as inspecting your throttlebody and cleaning that as well. I’m sure there’s a good YouTube on that one too.
    Yota707[QUOTED][OP] likes this.
  10. May 18, 2021 at 7:46 PM
    Yota707
    David
    Bay Area
    2015 Tundra TRD
    Awesome man thanks for the advice going to give that a shot this weekend
  11. May 21, 2021 at 4:45 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Hard shifts are one of the first signs of trans fluid changing its composition with age. The friction modifier goes and changes how the clutches slip in the shift. I've seen just heavy towing do this in well under 30k miles with the WS. The truck shifted very hard especially in 4-6 when the locked torque converter stopped insulating shock from the engine. Twice it's happened, and both times a full change of fluid made it run like new again. That truck stopped towing duty about 3 years ago and like magic the fluid hasn't broken down again.
    The old Honda ATF Z1 was awful for this. I did a drain/fill of the transmission fluid every year or so to refresh the additives otherwise it would start slamming gears. Enough Honda autos failed back then to convince them to reformulate the fluid but just a little preventative maintenance kept it going on the original sauce for hundreds of thousands of miles with no teardown.
    Which reminds me, mine's due for a pan drain/refill this year. It works out to about 1/3 of the total fluid.
    Yota707[OP] likes this.
