Hard time starting after fuel injector replacement
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra03, Feb 16, 2019.
  1. Feb 16, 2019 at 7:40 PM
    Tundra03
    Tundra03 [OP] New Member
    Peter
    2003 Tundra White
    Howdy fellas,
    The rig: 2003 Tundra SR5 v6 3.4L 2WD
    Background: Recently had a misfire issue (P0306) and rough idle. Replaced valve cover gasket, o-rings, spark plugs, plug wires, and coils (NGK). Still idled rough but went down the road fine. Thanks to a suggestion on my previous post I put in refurbished NGK fuel injectors.
    After the fuel injectors went in the truck definitely idled better (still a touch rough occasionally) but went down the road great.
    Issue:However, after I switched out the fuel injectors it has had a really hard time starting. Turns over for about 10 seconds and only starts if I give it a fair mount of gas. Once it has fired up its running fine.
    Today I cleaned MAF sensor and pulled off throttle body and gave the butterfly valve a good cleaning. It's still having a rough time starting. Maybe check valve on fuel pump?
    Anybody have this issue? Or any good ideas?
    Thanks!
  2. Feb 17, 2019 at 4:57 AM
    Professional Hand Model
    Hand Protectors
    How old is your fuel filter?
  3. Feb 17, 2019 at 8:54 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Maybe check your fuel pressure, could have a failing fuel pump.
  4. Feb 17, 2019 at 9:52 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Could also be a poorly "refurbished" set of injectors. I once bought a refurbished starter for an Acura only for it to die after 13 months. I went new the 2nd time.
    I hope this isn't the case but the timing leads me to think it might be.
  5. Feb 17, 2019 at 12:51 PM
    Tundra03
    Peter
    2003 Tundra White
    No record of changed fuel filter from previous two owners and I have never changed it so assuming the age of the car - I think that'll be my next job. From what I've read online the fuel filter on '03 is not in the tank...? Would really like to not have to drop the tank out haha.
    I'll check the fuel pressure. When I switched out the injectors the fuel lines seemed to have quite a bit of pressure. Of course that doesn't mean its the right amount. Also, the issue is only when it starts up - idles ok after that and goes down the road fine. So the pump seems to be working after initial start.
    Certainly hope it is not the injectors that would be a bummer. Also they are denso not ngk from original post - lifetime warranty on the refurbished ones. Fingers crossed I didn't waste my money.
  6. Feb 17, 2019 at 12:57 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    Fuel filter is under driver side cab area. Parking brake pedal adjustment is there also.
  7. Feb 17, 2019 at 12:57 PM
    Hand Protectors
    Filter is under the drivers side seat under the chasis. A small little black canister.
  8. Feb 21, 2019 at 10:57 AM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    how old are the O2 sensors?
  9. Feb 21, 2019 at 5:43 PM
    Tundra03
    Peter
    2003 Tundra White
    Ok maybe I will try and change the fuel filter since it is fairly accessible.
    Im not sure - the O2 sensors have never been changed so I would assume the age of the car.
  10. Feb 21, 2019 at 6:03 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Just so you know, O2 sensors have no effect on inital start-up.
    By your description, it sounds like you have a vacuum leak somewhere, or an injector (or multiple injectors) that is leaking fuel into the intake ports and flooding the engine while it’s shut off.
    For the vacuum leak check, you can idle the engine and carefully spray a bit of starting fluid in short bursts around the intake manifold to see if the idle speed / sound changes. Do this outside and avoid spraying near the air cleaner intake. Any change is RPM indicates a vacuum leak.
    For the leaking injector theory, a borescope type camera is useful in finding the leaky injector(s). Shut the engine down, remove the TB and inspect the ports for wetness, or drips from the injectors.
    TX-TRD1stGEN and Aerindel like this.
