Harrop E-locker installed (2020 Tundra)
Discussion in '2.5 Gen Tundras (2014-2021)' started by king.cong.1119, Mar 3, 2022.
  1. Mar 3, 2022 at 11:31 AM
    king.cong.1119
    king.cong.1119 [OP] New Member
    Ordered my harrop e-locker from ECGS (pre-assembled into a spare 3rd member), had my local 4x4 shop swapped in the 3rd member, went in pretty smooth. Can't wait to test them out on the trails.
    Photo Mar 02, 9 23 22 AM.jpgPhoto Mar 03, 8 07 23 AM.jpg Photo Mar 03, 8 25 23 AM.jpg Photo Mar 03, 8 32 46 AM.jpg Photo Mar 03, 9 22 01 AM.jpg Photo Mar 03, 10 19 33 AM.jpg
  2. Mar 3, 2022 at 11:50 AM
    timsp8
    NY
    Did you also regear? Mind sharing what ecgs charged?
  3. Mar 3, 2022 at 11:52 AM
    king.cong.1119
    No I did not regear, was happy with how my 4.30 gear behaves with 35s.
    I did not regear, it was $1800 ish for the locker parts (including master kit) and $1200 for them to put the locker into a refurbed 3rd member.
    timsp8[QUOTED] and reywcms like this.
  4. Mar 3, 2022 at 12:06 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    I was unaware an e-locker was available for the Tundra. Awesome
    It seems all I hear about are the air lockers.
  5. Mar 3, 2022 at 12:16 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    You're gonna love it but wait til you get a front locker. The things you can do are outrageous!
  6. Mar 3, 2022 at 12:17 PM
    timsp8
    NY
    Eaton has one too.
  7. Mar 3, 2022 at 12:18 PM
    king.cong.1119
    I was determined to get an E-locker after research and even my local gearing/locker shop is saying the air locker is just an disaster in terms of having way more parts prone to fail (reliability) and ease of servicing.
  8. Mar 3, 2022 at 12:31 PM
    king.cong.1119
    I do believe the harrop is part of Eaton, and this is the same Eaton E-locker for tundra (only e locker option I could find)
  9. Mar 3, 2022 at 12:31 PM
    king.cong.1119
    Stop putting ideas in my mind :)
  10. Mar 3, 2022 at 1:51 PM
    pandapro
    pandapro New Member
    Harrop = Eaton.
    Throw the front in there too! I installed mine a few months back and have only been able to go to the snow for a few trips since then. They make a HUGE impact and really is the difference between getting stuck and not stuck. I can’t wait to get in some wheeling on the dry stuff once the snow goes away.
    Also, what is this master kit you speak of? My rear came with everything I needed to install and wire up.
  11. Mar 3, 2022 at 2:16 PM
    poop_bubbles
    poop_bubbles New Member
    4.30s on 35s? Do you ever see 6th gear?
    I’d also do front and 4.88s but I already did.
    You’ll like the rear locker but you’ll LOVE the front locker
  12. Mar 3, 2022 at 2:19 PM
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    Nothing to say about the locker except your awesome!
    Nice rear shocks, same as my 5160's?:hattip:
    But you need a fancy mounting spacer like I used for mine, forgot what it was called but its black aluminum and clamps on with allen bolts.
    Sorry I don't have a pic :oops:
    The stock straps they provided detract from the look imo.
    And look at you embarrassing all those jeeps and domestics :thumbsup:
    :bananadance:
  13. Mar 3, 2022 at 2:24 PM
    king.cong.1119
    this is the link to the master kit
    https://eastcoastgearsupply.com/i-18964353-toyota-tundra-t10-5-master-kit-07-5-7l-rear.html
  14. Mar 3, 2022 at 2:26 PM
    king.cong.1119
    Yea I see top gear on highway, and I daily mine and find it more than enough for my 35s.
    Terndrerrr likes this.
  15. Mar 3, 2022 at 2:32 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Mines going in this weekend with some 5.29s. So pumped!
    Having the third member looks to make everything super easy. Nice job op
    Terndrerrr and Cruzer like this.
  16. Mar 3, 2022 at 2:39 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Excited for you!! Try to avoid full lock turns when you've got the front locker on - that's when shit usually happens.
  17. Mar 3, 2022 at 2:51 PM
    cctxquicksand
    I’m only doing the rear this weekend. I’m waiting on a set of rcv axles, when I get those in I’ll likely look at the front locker. But thanks dude!
    Cruzer[QUOTED] likes this.
  18. Mar 3, 2022 at 3:49 PM
    king.cong.1119
    now that I am trying to get a feel of it engaging and disengaging, I found it engaging pretty quickly but for disengaging, it takes a bit back and forth after turning it off to get physically disengages, is that somewhat normal?
  19. Mar 3, 2022 at 5:33 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    That’s normal. When you’re on the trail just keep rolling forward, it’ll disengage. No need to go back n forth.
    tundra_20 likes this.
  20. Mar 3, 2022 at 6:09 PM
    cctxquicksand
    https://youtu.be/x40WGUtdaLI
    Hey op that’s completely normal, check this video out 15:15-16:40 for an explanation why
    I would try to explain but this video covers it a lot better
  21. Mar 3, 2022 at 6:59 PM
    MaxPower
    MaxPower New Member
    18 Tundra TRD Off road
    Definitely normal for disengaging. Harrops unlock of you roll backwards so be careful about rolling backwards on obstacles or if you are in a sketchy spot.
    One advantage to ARB lockers is they don't unlock going backwards and they engage and disengage very fast.
    Harrops are modified Eaton lockers. Eaton decided to start making Toyota applications so Harrops are becoming less common here in the states.
  22. Mar 3, 2022 at 7:13 PM
    04rktaco
    04rktaco New Member
    Lee
    California City
    2014 SR5 TRD crewmax 4x4
    All-pro rocksliders RCI aluminum skidplates TRD pro suspension TRD pro exhaust coachman 1inch lift shackles cooper tires
    Will be interesting to hear how it works out. Planning on installing one in the front diff on my 1st gen Tacoma
  23. Mar 4, 2022 at 6:35 AM
    king.cong.1119
    I see, thank you!
  24. Mar 4, 2022 at 6:35 AM
    king.cong.1119
    I will check that out, that makes me feel better.
  25. Mar 4, 2022 at 6:38 AM
    king.cong.1119
    Yes, I have seen how that could be unlocked from my research as well, according to Harrop, 90% of the time if the rear diff is under load, it won't come unlock but yes I see how that could be potentially frustrating when you don't have full control of what the locker is doing. For ARB, I am not a fan of the multi-system dependent of their locker, there just could be so much things go wrong on the trails and I don't want to be worry about the longevity of my locker when out exploring. For my kind of offroading, I think Harrop should work just fine.
    MaxPower[QUOTED] likes this.
  26. Mar 4, 2022 at 6:39 AM
    king.cong.1119
    I will keep you posted, I use my youtube channel <4WD is Life> to show case offroad comparisons of varies trucks/4x4s, and I am planning on doing a video demonstrating on how this locker works in the very near future. Please consider subscribe if interested :)
    AZBoatHauler, NoMoreGreen and Cruzer like this.
  27. Mar 4, 2022 at 9:24 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    You’ll soon find out that even if it takes a little longer than usual to disengage you’ll be fine with it. It’s the front locker that will make you worry at times because it is impossible to turn the wheel if you are on a sticky surface, like when you go from dirt to granite and there’s an edge that you don’t want to fall over.
    NoMoreGreen likes this.
  28. Dec 18, 2023 at 12:51 PM
    DenaliLess
    DenaliLess New Member
    rob
    2019 CrewMax 4X4
    46 gallon transfer flow tank
    Does this locker work in 2 wheel drive? I am not a off roader but my right wheel just has too much torque on it. I want both wheel to share the load. Makes nice burn out marks too :)
  29. Dec 18, 2023 at 2:10 PM
    MaxPower
    MaxPower New Member
    They are not controlled by a computer, just a simple wiring harness and switch. They can be switched on and off at any time.
  30. Dec 18, 2023 at 2:33 PM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    This would work in 2wd as long as it is wired up to do so.
    If you are not into anything extreme off road, just get an Eaton TrueTrac. Limited slip, no wiring involved, totally automatic and you never have to worry about it failing.
    The only issue with the helical type diffs is when you lift a tire into the air, they become an open diff. A little bit of brake pressure (even the stock traction control intervening) and it's good to go.
    I've had e-lockers on a number of vehicles now (2 Toyotas, 1 Nissan, 2 Jeeps), they are great off road, but i would have gotten much more real use out of a good limited slip
