Has any one ordered ext cab side window closure bracket parts?
Discussion in '1st Gen Tundras (2000-2006)' started by anupath, Aug 28, 2023.
  1. Aug 28, 2023 at 7:49 PM
    anupath
    anupath [OP] New Member
    Greg
    2002 Tundra SR5
    Saw a metal replacment on youtube of the middle plastic piece, does anyone know where to order this part? Thanks in advance.
  2. Aug 28, 2023 at 7:59 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  3. Aug 28, 2023 at 8:09 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
  4. Aug 29, 2023 at 1:16 AM
    Aerindel
    Aerindel New Member
    Montana
    Yes. I got those exact ones. Be careful with the pins. Squeeze them in with vice grips or something. I broke one side of the bracket trying to tap them in.
  5. Aug 29, 2023 at 5:20 AM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    I pressed the roll pins in with a small "C" clamp and socket.
    GasCamp_Outdoors likes this.
  6. Aug 29, 2023 at 6:49 AM
    This advice is solid. There was nothing wrong with mine, and ... here's what happened to my perfectly healthy latches while replacing the pivot
    I'd add to @Aerindel's advice, and tell you this:
    • If your current latch isn't broke DO NOT replace those arms, there is NO benefit to replacing them (proof the scAmazon part is exact same here, some advertise this as a "wind noise fix" but it IS NOT)
    • If you must replace...
    • Remove the door panel
    • Remove the latch completely
    • Work on the latch OUTSIDE the truck, on a work bench
    • Reinstall
    While I was able to get my passenger side done while in the truck, you clearly see what happened to me on the passenger side. It's just a PITA to get those damn pins in
    If you need to replace your entire assembly, it's actually not too spendy. Here's the part numbers:
    Vent window latch left: 62920-34012-XX
    Vent window latch right: 62910-34012-XX
    Where "XX" refers to your trim color. Like, my interior is charcoal grey, thus "B1" is the color code so my latch assemblieses are 62910-34012-B1 and 62910-34012-B1 respectively. FULL LIST OF PART NUMBERS BY COLOR HERE. And a note, the letter in parenthesis like (L) or (J) after the part number tells you the country of origin.
  7. Sep 1, 2023 at 12:18 PM
    Richid
    Richid New Member
    Same here - lube and press, easy install. Both sides about 15 minutes and done.
    JakeJake[QUOTED] likes this.
