Headlight Adjustment
Discussion in 'General Tundra Discussion' started by LILFEAR1, Sep 17, 2021.
  1. Sep 17, 2021 at 12:11 PM
    LILFEAR1
    LILFEAR1 [OP] New Member
    2015 Black Tundra SR5
    7" BDS lift, 37" tires on 22" rims, S&E Airbox and more
    My 2015 SR5 Tundra has a 7" lift. I know about the switch on the left side of the steering wheel that raises and lowers the lights, but they do not lower it enough...I cannot find the manual adjustment for my Aftermarket headlights...I do not know what kind of lights they are but if you can tell from my photos please let me know how to adjust them.
  2. Sep 17, 2021 at 1:45 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    They're ANZO headlights more than likely or a clone. Back of the headlight should have 2 adjustment screws. the one circled in red should be your up and down adjustment for the projector. You should be able to reach in there with a long Phillips screwdriver and set the adjustment.
    Taco-Spike likes this.
  3. Sep 21, 2021 at 8:15 AM
    LILFEAR1
    OMG thank you so much for this...I looked up the ANZO headlight and this looks like mine...I will try this...also they blink really fast (similar to if a light was out) but no lights are out...ideas?
  4. Sep 21, 2021 at 6:47 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    a few
    no clue what the blinking issue could be honestly. hopefully someone else can chime in on that.
  5. Sep 21, 2021 at 7:00 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    The super blinky is often caused by LED indicator bulbs which do not have the correct resistors to fool the "bulb out" warning built into the truck by toyota.
    Start looking for LED bulbs and replace with nermals to fix.
  6. Sep 21, 2021 at 8:36 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Is it the lo/highbeam hyperflashing? Or just the turn signal? Hyperflash is normally a problem on your LED turns, not your main beams. Can normally be cured with specialized LED bulbs (led + builtin resistor), adding a load resistor, or in somecases I think diodedynamics? sells a specialized relay. Adding a load resistor is the easiest and cheapest method, but requires you to do some wirework. If you aren't comfortable with that, or just don't want to risk damaging your harness, pay the extra $ and buy premade.
  7. Sep 21, 2021 at 9:31 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Get a resistor wired on to each turn signal and it will fix it Amazon eBay even Walmart has them. Super easy to do
  8. Sep 21, 2021 at 9:40 PM
    Diesel_dave
    Diesel_dave New Member
    does the alpharex have the same adjustment? i have them on 0 for the leveling but seems little high
  9. Sep 22, 2021 at 8:35 AM
    LILFEAR1
    do you have any suggestions on what kind, size, or whatever for resistors?
  10. Sep 22, 2021 at 8:43 AM
    LILFEAR1
    Do you have any suggestions on how to get to the adjustment screw... In the picture I marked the yellow...this is all I can see of the back side of the headlight. I can't even reach it with my finger.
  11. Sep 22, 2021 at 8:47 AM
    xtyfighterx
    Ty
    North Idaho
    Brand isn’t an issue really 6ohm should be the one you need. Amazon or eBay is usually least expensive but if you need it now Walmart and most other auto stores carry them
    https://www.amazon.com/Resistors-Si...t=&hvlocphy=9029656&hvtargid=pla-493300861825
  12. Sep 22, 2021 at 9:54 AM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    a few
    I'd try a long screwdriver at an angle, but if that doesn't work might come down to having to remove the headlights. the back of the headlight to get to the adjustment screw is kinda strange honestly. No clue why they didn't stick to the oem style like most other after market headlights.
    For example this is the back of the Alpharex headlights, they have this little channel just like the OEM headlights to guide the screwdriver with to the adjustment
  13. Sep 22, 2021 at 11:20 AM
    LILFEAR1
    I might just buy Alpharex headlights since I have to remove the damn headlight to adjust the headlight...not sure how that is going to work
  14. Sep 22, 2021 at 3:08 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    a few
    might as well upgrade if you can, OEM leds with ihacker harness, morimoto and alpharex are all good options.
    Kgfit85 likes this.
  15. Sep 27, 2021 at 11:06 AM
    LILFEAR1
    If I get the Alpharex LUXX or Nova (they both come with LED) would I have to get the resistors?
  16. Oct 5, 2021 at 12:47 PM
    LILFEAR1
    UPDATE: I got the Alpharex LUXX home and installed...I love these...no hyperflashing blinkers...and even though I can reach the adjustment screw on the physical headlight, I don't need to touch it, just the adjuster on the left side of the dash is fine...and I have a 7" lift....These things are so much brighter than the ANZO headlights. Pictures will come soon.
