Headlight aiming...sorry newb here again....
Discussion in '1st Gen Tundras (2000-2006)' started by AWilliams, Nov 15, 2022.
  1. Nov 15, 2022 at 7:04 PM
    AWilliams
    AWilliams [OP] New Member
    Ok...don't shoot. I'm trying to wade thru all the opinions on easiest way to aim new headlights. I got 1.5" mini projectors with new housings. When shown on my garage door they have a very distinct Z pattern upper cutoff...being lower on the left raising up about 3" to the right, with a blue cutoff line on top. I read that on higher vehicles the cutoff line should be 2" lower than the center dot on the housing @ 25'. Mine sits right about 40" I verified that by "sighting" that dot into the center of the bulb and spotting my tape measure.
    So, the bottom or (lowest part of the Z) at 38" @ 25'?
    Thanks for the help.
  2. Nov 15, 2022 at 7:18 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  3. Nov 15, 2022 at 7:27 PM
    shifty` Neon King Kong standin' on my back
    You'll need a big, long ass screwdriver.
    NewImprovedRon and richsadams like this.
  4. Nov 15, 2022 at 7:38 PM
    AWilliams
    Actually not....only 6".
  5. Nov 15, 2022 at 7:44 PM
    Mine's definitely bigger than 6", more like 8", and it fits in there just about right with a little room to spare.
  6. Nov 15, 2022 at 8:54 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Here is your official headlight adjustment tool. Be sure to keep in the vehicle. Can be used as a sword if needed in emergency situations. headlight.jpg
  7. Nov 15, 2022 at 8:57 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I keep a lighter at the ready when at gas stations in the rougher parts of town. We're all gonna go to heaven, but it's gonna feel like hell for a minute.
  8. Nov 15, 2022 at 9:11 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Toytec Aluma 2.0, Camburg UCA, 5160s and more.
    I thought we were talking about aiming lights but now we are measuring our screwdrivers
  9. Nov 16, 2022 at 5:30 AM
    Oh, we're measuring screwdriver shanks? In that case, the one I use for adjusting my headlights is a #3 and closer to 12". :rofl: (j/k)
    Seriously though, it takes a lot of length to get down in the hole and engage the adjuster. None of the standard-length screwdrivers I had would get down in there.
  10. Nov 16, 2022 at 6:07 AM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    I don't understand why the giant screwdriver is needed. I've never needed anything like that. I just pop out the corner light and use a ratcheting 10mm to adjust up or down.
    artsr2002 and Tundra2 like this.
  11. Nov 16, 2022 at 6:45 AM
    There's a non-obvious hole in the corner of the light fixture. Per the manual, you can stick a long philips head screwdriver down that hole and adjust the aim of the headlight up/down. This is the intended procedure to use for adjusting headlights, at least for my '06. Maybe your earlier year is different. Lemme find a pic of the adjuster hole and procedure, since it doesn't look like Noah's above shows how we later years adjust ours.
  12. Nov 16, 2022 at 8:43 AM
    Work emergency got in the way.
    Here's the updated image from above - doesn't show the insertion hole, but it shows you sticking a long screwdriver into the provisioned hole so you can rotate the little white gear. You don't need to pop off the turn signal housing and wrench on the gear:
    Hole is here on earlier models, I swear it's higher up and way deeper on my '06 AC with DRL:
    Screencap was taken from this video, start at the 1m58s mark, if it doesn't jump there automagically:
    FirstGenVol likes this.
  13. Nov 16, 2022 at 8:50 AM
    Here, for a later-model 1GT, two adjustment holes, note this isn't an OEM headlight:
    NewImprovedRon likes this.
  14. Nov 16, 2022 at 12:13 PM
    FirstGenVol
    East TN
    2002 AC
    I remember that now @shifty` but I honestly think it's easier and faster to use my 10mm ratcheting wrench with the corner light out. I didn't need that comically long screwdriver to do it the way you're showing but it was a lot slower. I've had to adjust my headlights a lot since going to projectors.
    Tundra2 likes this.
  15. Nov 16, 2022 at 12:34 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  16. Nov 16, 2022 at 2:46 PM
    Jack McCarthy
    Jack McCarthy Truck repair enthusiast; Rust Aficionado
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Also good for tearing apart older window ACs to completely clean from top to bottom. At least for the whirlpool units.
  17. Nov 16, 2022 at 2:47 PM
    Jack McCarthy
    Bill
    North of Boston
    Mine’s bigger than yours. :burp:
    805Tundra[QUOTED] likes this.
  18. Nov 16, 2022 at 3:01 PM
    805Tundra
    Ben
    Central Coast
    :rofl::duel:
    All this talk about shafts, holes and screwdrivers….
  19. Nov 16, 2022 at 3:58 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  20. Nov 16, 2022 at 9:21 PM
    artsr2002
    'Yonder
    Yeah, but then you don't have the pointy sword under the seat. :D
  21. Nov 17, 2022 at 8:53 AM
    Teutonics
    Teutonics BestGen Member
    2005 DC SR5 4WD
