Headlight Low Beam out 2007 Tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by keefur75, Oct 21, 2019.
  1. Oct 21, 2019 at 10:29 AM
    keefur75
    keefur75 [OP] New Member
    I need help y'all. The low beam is out on my driver's side headlight. Bought replacement bulbs and they did not work. (H11). Checked the fuses, they looked good, but changes it anyway - no go. I hate having one headlight. What am I missing??
  2. Oct 21, 2019 at 5:29 PM
    greghoro
    greghoro New Member
    Greg
    2012 Sequoia Limited
    Process of elimination.
    I would first advise to verify that the old bulb really does not work. Best way would be to remove it and hook it up directly to battery. Same with the new bulb.
    Or use the working side to verify the status of the old and new bulb.
    If they prove out to be what you expect, then the wiring is at fault.
    Do following tests to determine which wire is at fault:
    - Power wire to ground wire for 12v
    - Power wire to chassis ground for 12v
    - Ground wire to chassis ground for continuity
    Since the wires go into a bundle, tracing them back could be a pain.
    Greg
  3. Oct 21, 2019 at 5:59 PM
    Black4X2
    Black4X2 New Member
    Bill
    2007 Black Tundra Limited 4X2
    Look at the plug. Does it look black,burnt,melted.These bulbs get hot.
  4. Oct 21, 2019 at 7:53 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    There's been a few times I swore the fuse looked good and was still intact. After checking everything else, I went back to swapping the fuse and voila. Electricals back on.
  5. Oct 21, 2019 at 8:01 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    I know the tail light on my 07, the prongs in the socket seemed to have gotten weak not making contact with bulb as needed. Had to tweak the prongs some so they would make contact with the bulb conductors as needed.
  6. Oct 22, 2019 at 7:48 AM
    Black4X2
    Black4X2 New Member
    Bill
    I have seen this before. A fuse blown from a short will be all black inside with most of the guts gone. But some times they will just separate with a real fine crack that you can't see very well. Glad that's all it was.
  7. Oct 23, 2019 at 4:08 PM
    Black4X2
    Black4X2 New Member
    Bill
    We had the same exact problem with a tail light on our 2010 4 runner.Had to do the same thing. I read where some one had this problem and the dealer told them they needed a whole new tail light assembly.
