Headlight Revolution vs Morimoto LEDs
Discussion in 'Lighting' started by Tuckerman048, Dec 28, 2018.
  1. Dec 28, 2018 at 1:35 PM
    Tuckerman048
    Tuckerman048 [OP] New Member
    Western Pennsylvania
    2014 CM 4x4
    I'm considering upgrading my fog lights on my 14 CM. I'm torn between just replacing the bulbs with led bulbs from Headlight Revolution or putting in merimoto LEDs. Both of these options are right around $200.
    I do love the Baja designs replacements but don't have the extra cash right now to throw at it.
    Any input from those of you with the HR bulbs or the merimoto please chime in with pros and cons you've encountered.
  2. Dec 29, 2018 at 8:01 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Replacing with proper LED projector lenses / reflectors would likely give better focus of light and less glare than just sticking LED bulbs in a housing meant for halogens.
    You should be able to find some morimotos for $100-150 if you shop around and keep your eyes open for someone selling theirs.
    A 3rd and probably your best affordable option is the 2018 OEM LED fog lights. Every now and then a "used" set comes up for $200 here in the for sale threads.
    AxelsHumanDad, tinman10101 and Bob like this.
  3. Dec 30, 2018 at 8:27 AM
    DustinP5
    DustinP5 New Member
    Austin, TX
    2015 Magnetic Grey SR5 Crewcab
    Retrofit Headlights, Heated/Cooled leather seats, Leveled, Pro Grille, Wireless counsel charger, TRD Shif Knob
    Go with the Morimoto projector style fogs, TRS has a 10% off sale right now
  4. Dec 30, 2018 at 10:28 AM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    If you live where it gets really cold; in the negative 20s for weeks, the HR LEDs will flake out.
    Happened to me with two different sets, and I proved it to them with my own photo tests in my freezer.
    Bright bulbs, and they made good on them for me. Unreliable in extreme cold though.
    Pudge likes this.
  5. Jan 1, 2019 at 11:15 AM
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    Advice: Save up for BD or Rigids.
    I don't recommend the TRS LED projector fogs.
    They only lasted 2 years on my Tacoma.
    Summary: The cast metal alloy housing oxidized which flaked the powdercoat. Since the breather port is adhesived to the powdercoat, when the powdercoat fails, The housing is no longer waterproof.
    My Thumb nail is on the breather patch.
    I switched back to OEM housing with Morimoto HIDs.
    The light output from the HID's is far superior to the LED housings.
    Yes, this is frowned upon, but when i need ditch/sidewalk light coverage I use them.
    Be responsible, treat them like high beams. It will be ok.
  6. Jan 1, 2019 at 12:23 PM
    Upgrayedd
    Upgrayedd Toyotaholic
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    I only spent $200 on a set of new OE Toyota LED fogs. They’re nice.
