Headlights keep burning out
Discussion in 'Lighting' started by matthew6055, Oct 24, 2018.
  1. Oct 24, 2018 at 7:40 PM
    matthew6055
    matthew6055 [OP] New Member
    Matthew
    2014 Toyota tundra sr5
    Git the 2014 tundra Just replaced driverside in the spring and passenger side in the summer now the driver side is out again is anyone else having this issue and any advice would be great this is the 1st problem I'm having
  2. Oct 24, 2018 at 8:05 PM
    arisner
    arisner New Member
    Did you wear gloves when installing? You need to keep the oil from your fingers off the bulb or they will cause a hotspot and burn out quick.
    DecalsByDesign and Black Wolf like this.
  3. Oct 24, 2018 at 8:23 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    What bulbs are you running?
    How does the wiring look?
  4. Oct 24, 2018 at 8:24 PM
    Jrfor0
    Jrfor0 New Member
    James
    Are you running aftermarket halogen bulbs? A lot of aftermarket bulbs have a short lifespan from what I have noticed I was lucky to get 7-12 months out of them before they burned out.
  5. Oct 25, 2018 at 1:07 AM
    Gibo244
    Gibo244 New Member
    KG
    Maui
    Test the alternator
