Heater blowing cold air
Discussion in '1st Gen Tundras (2000-2006)' started by Karljones692, Oct 18, 2020.
  1. Oct 18, 2020 at 2:45 PM
    Karljones692
    Karljones692 [OP] New Member
    2000 White Tundra LTD TRD
    4 in suspension lift 3 in body lift Dual short piped
    Heater is blowing cold air even with heat on high setting.
    Flushed my heater core and radiator already.
    No leaks or coolant on passenger side and no smell of coolant in the cab.
    Not sure what else can be done aside from doing a heater core replacement.
  2. Oct 18, 2020 at 2:50 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    There is a cable that runs under the glove box, it has to clip into place near the blower motor. Last year I bumped that loose and lost heat. Another member had the same issue. If you look under there you will see it. Try that before replacing the heater core.
    Mustanley likes this.
  3. Oct 18, 2020 at 3:30 PM
    Karljones692
    Yeah I just checked it, it’s plugged in and I can hear it turn on when I turn the heat on...
  4. Oct 18, 2020 at 4:12 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  5. Oct 19, 2020 at 7:55 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    When you switch the temp dial, can you hear the motor moving?
    I have always made it a habit when adjusting temp or vent position to turn the blower motor off. This keeps the blend doors from having to fight the air while changing position.
  6. Oct 19, 2020 at 10:27 AM
    Karljones692
    How do i turn the blower motor off?
  7. Oct 19, 2020 at 10:36 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    You can unplug it but I think he means you just turn the vent to zero so it's not blowing air. Are you sure your blower motor is working? You have air coming out of the vents it's just not hot right?
  8. Oct 19, 2020 at 10:38 AM
    Karljones692
    Yes I can hear my blower motor working. My vents and ac cents are working, it’s just not hot air blowing out.
    I already did a heater core flush and a radiator flush and even emptied and cleaned out my coolant tank.
  9. Oct 19, 2020 at 10:45 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Does the temperature knob feel normal when you turn it? There are little cables back there and I'm just wondering if one broke or came loose. One runs through the firewall and I think you can see it move when you turn the dial. Have you checked that? I'm just going through process of elimination here.
  10. Oct 19, 2020 at 10:45 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  11. Oct 19, 2020 at 11:08 AM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    Check the cable on the heater control valve (red circle) in the picture that @FirstGenVol posted above. The valve is open when the cable is pulled towards the firewall. With the valve open that hose should be hot on both sides.
    If that checks out OK pull the temperature knob from your dash, it just pulls right off. They have been known to crack and it's possible that the temperature knob is just spinning while not actually moving the cable. Amazon has cheap replacement knobs.
    FirstGenVol and N84434 like this.
  12. Oct 19, 2020 at 11:16 AM
    Karljones692
    Yes when i turn from hot to cold I can see it turning the heater control valve on where my inlet hose is at. And I manually turned the heater control valve and it also turned it from hot to cold
  13. Oct 19, 2020 at 11:23 AM
    Lil Steve
    Gilbert, AZ
    Is the hose hot on both ends of the heater control valve? If it is, it sounds like a blend door problem.
    FirstGenVol likes this.
  14. Oct 19, 2020 at 11:43 AM
    Karljones692
    Yes they are both hot
    Blend door? Where is that located?
  15. Oct 19, 2020 at 11:49 AM
    Lil Steve
    Gilbert, AZ
  16. Oct 19, 2020 at 11:55 AM
    Karljones692
    Ok thank you very much everyone!
  17. Oct 19, 2020 at 1:33 PM
    Professional Hand Model
    Hand Protectors
    Wha happen? Fixed?
  18. Oct 19, 2020 at 1:56 PM
    Karljones692
    Haven’t gotten to it yet! Gonna be home later today.
  19. Oct 20, 2020 at 8:21 PM
    mookytx
    mookytx New Member
    Kenny
    Lufkin, Texas
    2006 toyota tundra access cab 4.0 v6 103707 miles
    Make sure there is no air in your Cooling system. The best way to do that is to park on a very steep incline so that the heater core is below the neck of the radiator fill cap and started up and run it. any air in the system should come to the neck and burp out.
    The heater core is the highest point in the cooling system and air will accumulate there preventing hot water from entering.
  20. Oct 20, 2020 at 8:36 PM
    Karljones692
    Ok I’ll have to try this out! So just leave it running for about 5-10min? W
  21. Oct 20, 2020 at 8:42 PM
    mookytx
    mookytx New Member
    Kenny
    Lufkin, Texas
    Run it till it stops bubbling. 5-10 minutes should be enough.
  22. Oct 20, 2020 at 8:57 PM
    Karljones692
    Ok thank you!
  23. Oct 20, 2020 at 9:50 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    My first truck back in the day, 97 Dodge Dakota 5.2 Single Cab 4x4 on 33 all terrains, damn I miss that little truck, started blowing cold air at me for about the entire trip home in the mornings during winter until about 1/4 mile from the house when it would finally start to warm up a tiny bit. Turns out the thermostat had failed and was in the stuck open position as designed. This prevented the engine from heating up quickly so the heater would take a while to blow hot air. Replaced the thermostat and the next day, hot air within minutes. Perhaps a thermostat check is in order.
  24. Oct 20, 2020 at 10:05 PM
    Karljones692
    I’ll look into that as well thank you!
    Just hoping it’s everything but the heater core!
  25. Oct 20, 2020 at 10:10 PM
    artsr2002
    'Yonder
  26. Oct 20, 2020 at 10:11 PM
    artsr2002
    'Yonder
    ChrisFix has lots of videos with very helpful easy to understand information. He has several videos where he discusses things briefly and fast and then he also has a long detailed version of the same procedure.
  27. Oct 20, 2020 at 10:55 PM
    Karljones692
    Yes I’ve done this already as well as a radiator flush.
  28. Nov 11, 2020 at 5:00 PM
    Rdway60
    Rdway60 New Member
    2005 Bluesteel Metalic Tundra
    Any updates Karl?
