Heater has a bad smell
Discussion in '3rd Gen Tundras (2022+)' started by Twinlakes, Nov 18, 2022.
  1. Nov 18, 2022 at 1:08 PM
    Twinlakes
    Twinlakes [OP] New Member
    Burlington Ontario Canada
    2022 Toyota Tundra 1794
    None
    I wonder if it will go away I thought it would burn off the smell any ideas
  2. Nov 18, 2022 at 1:11 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Mouse??? As in deceased?
    Taco-Spike, mmasse and Piney like this.
  3. Nov 18, 2022 at 1:16 PM
    FrostyTundra22
    FrostyTundra22 No longer new member
    2020 Toyota Tundra 1794 Crewmax
    Free taxidermy
  4. Nov 18, 2022 at 1:17 PM
    Black@Blue19
    Ken
    SE Texas
    Find out how to get into the cabin filter and look in there?
  5. Nov 18, 2022 at 1:52 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    change your cabin air filter, you may find more than just the filter in there.
  6. Nov 18, 2022 at 2:16 PM
    Twinlakes
    None
    There is no smell when the AC is running just the heater
  7. Nov 18, 2022 at 2:23 PM
    FrostyTundra22
    how would you describe the smell?
  8. Nov 18, 2022 at 2:24 PM
    Twinlakes
    None
    its like when you start your furnace or space heater the dust burnt smell
  9. Nov 18, 2022 at 2:30 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Smell like low tide? Tundras are panty droppers and mistakes will be made.
    WFD473, NoRcptn, OHwendTrd and 3 others like this.
  10. Nov 18, 2022 at 2:40 PM
    Twinlakes
    None
    Cabin Filter is clean no obstructions
    FrostyTundra22 likes this.
  11. Nov 18, 2022 at 3:03 PM
    FrostyTundra22
    Maybe the heating element or around is dirty. Not sure how you would get to it though
  12. Nov 18, 2022 at 6:43 PM
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    The smell you describe sounds like a dead rodent to me. Take it from a former KY resident with plenty of dead rodent experience :tumbleweed:
  13. Nov 18, 2022 at 7:00 PM
    RingofScars
    RingofScars New Member
    2022 Tundra Limited
    Is the truck brand new? Mine smelled odd when I first got it, went away after a week of using the heater.
  14. Nov 18, 2022 at 9:23 PM
    There’s no “heating element” like a home
    Furnace has. It has a heater core that circulates hot engine coolant through it to warm the air. I’ve seen some posts in here about 2022 models coming with bad heater cores. Worth having a service tech take a look at it.
  15. Nov 19, 2022 at 6:09 AM
    Twinlakes
    None
    Its a 2022 1794 Tundra and has 3000 miles on it
  16. Nov 19, 2022 at 6:34 AM
    frichco228
    Brand new, you should alert you dealer. Let them handle it. I would not be trying to address or fix anything on a brand new 60-70k truck.
    Black@Blue19 and JLS in WA like this.
  17. Nov 19, 2022 at 6:50 AM
    I think people come on here with their issues to be better informed. Don't think they are trying to personally fix their new trucks. I would want to know what was wrong before letting the dealer jerk me around too.
    FrostyTundra22 and 22whatwedo like this.
  18. Nov 19, 2022 at 7:40 AM
    mmasse
    mmasse Digital Forensics Cowboy
    Idaho
    2022 Magnetic Grey Tundra
    Mine was a mouse. Change the filter, check for nests and throw a few bars of Irish Spring in there. Before all that use some gloves, hantavirus is not something to live with.
    bigjuice likes this.
  19. Nov 19, 2022 at 8:15 AM
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Yup…had this issue on my 2015 as well.
    Afew bars of Irish Spring in the engine bay (annoyingly high scent they don’t like) coupled with a few scented laundry softener sheets in the glove compartment helps with that.
    They also sell peppermint and other high scented sprays to douse your engine compartment with.
    mmasse[QUOTED] likes this.
  20. Nov 19, 2022 at 9:22 AM
    FrostyTundra22
    thank you for the info
  21. Nov 27, 2022 at 6:52 PM
    Dave Roni
    Dave Roni New Member
    22 Tundra Limited
    Stock
    Mine builds up moisture when left on “Auto” setting, then eventually will emit som’e musty smell when heat only.
    I started drying it out by putting on the manual fan to speed 4 or ‘above and turning the heat up a little with the AC off. Do that for maybe 3 to 5 minutes at the end of the day’s drive.
    I’ve found this necessary with any machine or vehicle ever operated because AC pulls a lot of moisture out of the air and heater/AC unit needs to dry out.
  22. Nov 28, 2022 at 6:03 AM
    Twinlakes
    None
    I will give it a try thanks appreciate the help.
