Hella Delay Relay help!
Discussion in 'Electrical' started by TonyNCo, Oct 4, 2022.
  1. Oct 4, 2022 at 11:59 AM
    TonyNCo
    TonyNCo [OP] New Member
    Tony
    2019 VooDoo Blue TRD Pro
    Audio, 11 channels Kenwood HU, Mini DSP Digital Sound Processor 2 Alpine 4 Channel Amps, 3 Alpine Sub Amps approx 4K watts 3 way Focal in dash, front doors. 6 1/2" in door swapped for 8" 10" Focal Sub, front passenger floor, custom sealed box 2 way Focal rear doors 2 JL Audio 12W6 Subs, behind backseat Aux lights, all but ditch on modified bumper light bar (3 Hella Rally 4000) Spot, Fog, and Euro beam. Euro beam has yellow bulb. 4 White Spot beam LED Ditch 4 Yellow Spot beam LED 42" Curved, Yellow/Fog LED light bar 50" Curved, White LED light bar 295/70/18 Falken Wildpeak, Revolver Bed Cover
    Ok, I generally do well enough to add lights etc to my vehicles.
    What I am trying to do.
    Connect the relay to the turn signal. As it flashes, relay powers a different light I am adding to truck.
    With steady power to the added light as turn signal flashes. After turn signal is turned off, no flashing anymore. The power from relay to added light goes off after a short delay. The relay delay is adjustable. I have it wired, the light will only go on or off when set on "0 sec" delay. I can hear the relay clicking.
    The minute I adjust for a power off delay to added light, the light does not turn on.
    HELP! There are pictures of the relay below,
  2. Oct 4, 2022 at 12:23 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    I'll take a stab in the dark and guess that you are wiring up a cornering light that comes on when you hit the turn signal. If that is the case, I think that you have the wrong relay for the job. Yours is a delay ON so when the turn signal flashes the relay never is powered long enough to turn on without being at 0 seconds (as you described). What I think you want is a delay OFF so when the turn signal lights it starts a timer for when the power to your secondary light will be turned off. I found this one with a quick google search but I'm sure there are lots of options https://www.delcity.net/store/Time-Delay-Relays/p_804415.h_804416
    Festerw and 1lowlife like this.
  3. Oct 4, 2022 at 12:31 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    2nd
    I believe this is the Hella version
    https://www.amazon.com/HELLA-996152131-0-900s-Delay-Control/dp/B003C508XO
    APalmTree[QUOTED] likes this.
  4. Oct 5, 2022 at 9:06 PM
    TonyNCo
    Tony
    Thx, I have ordered one, will be in later this week. I have the pieces installed, just waiting for the other relay
  5. Oct 18, 2022 at 10:52 AM
    TonyNCo
    Tony
    Thank you for your help. I got both relays in, works awesomely. Might have to buy a 3rd one, and wire to the radio so I can have a delay there between acc on, and starting. That way, radio won't turn off anymore.
