Help, 2008 Tundra! Fuses blowing, stuck in park
Discussion in 'General Tundra Discussion' started by DrBob, Jan 8, 2020.
  1. Jan 8, 2020 at 7:26 PM
    DrBob
    DrBob [OP] New Member
    2008 Toyota Tundra Limited TRD
    My truck keeps blowing 7.5 amp fuses left and right and is stuck in park. I learned the shift override trick and got it home but now I'm trying to repair it. I bought a bunch of fuses and checked all the fuses. Originally had 4 fuses blown. Changed them all out, got it working again. Well 2 days later it happens again. Only fuse blowing is the AM1 fuse, which basically controls the shift lock system and the console, and the dashboard, and power seats, and lights, and turn signals. So at the moment I have none of the above. I changed the fuse again, it blew instantly. Here's the kicker, it's cold today, was warm the last 2 days. I'm thinking I have water somewhere. I checked towing hookups, cleaned them, and sealed with dielectric grease. Still blowing. I bought a brake light switch and replaced that, still blowing. I'm at a loss. Wife is 9 months pregnant, due any day, and we are now down to just her vehicle. Any ideas?
  2. Jan 8, 2020 at 8:02 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    Check wiring for rodent damage
    ZappBrannigan likes this.
  3. Jan 9, 2020 at 6:35 AM
    DrBob
    No obvious wiring damage. Everything looks clean and neat
  4. Jan 9, 2020 at 6:40 AM
    You didn’t do any LED upgrades lately by any chance have you?
  5. Jan 9, 2020 at 12:03 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    There is a short somewhere...something is causing the fuses to blow. Could be a bad ground somewhere. Chase the AM1 fuse/wire circuitry and my guess is you will find something. Could also be chaffing.
  6. Jan 9, 2020 at 12:29 PM
    DrBob
    No on headlights. I have a tiny crack that appears to only be surface level, not all the way through on my taillight, but not fully positive. I'm wondering if it is enough to have let some water in the taillight, we've had some thick fog a few times the past couple of weeks. I wonder if some water found its way inside and is expanding with the cold creating a short in the wire.
  7. Jan 9, 2020 at 1:07 PM
    Crunch527
    Iowa
    I would think it would be more obvious than that to cause the havoc you describe. I am thinking there is a rub or pinch somewhere along the harness that over time is causing a short. Could be anywhere on any of those systems that are on that circuit...seat harnesses, steering column, shifter. Given the constant use of the shifter Id look there first. Neutral safety switch or other assoc harness? Anywhere the harness passes through a metal bulkhead, i.e. firewall could be a possible place creating a short.
    Any aftermarket goodies?
  8. Jan 9, 2020 at 5:29 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    What do you mean by left and right fuses? Tell us what four fuses blew the first time? Are there any modifications to the truck? After you replaced the fuses and it blew the 2nd time what exactly were you doing (moving the shifter)? Has the truck been in and accident and recently repaired? If you only have the one fuse blown and it blows everytime a new fuse is put in this is a good thing, you can find the fault. Start unplugging wiring on the circuit until the fuse stops blowing.
  9. Jan 9, 2020 at 5:42 PM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    Ok let me get this right it’s a 7.5 amp fuse to control all the above mentioned circuits ????? That seems like a large amount on a 7.5 amp fuse. I would think the power seats alone would have at least a 20 amp. You sure that’s the correct amp fuse it should say on the diagram I’d start there first
  10. Jan 15, 2020 at 6:52 AM
    Theyfzman
    Pa
    08 TRD
    Any update ??
  11. Jan 15, 2020 at 6:54 AM
    blizz86
    blizz86 New Member
    Do you have anything plugged in to the trailer wiring harness? Check the plug for debris
  12. Jun 16, 2021 at 6:12 PM
    SteveM
    SteveM New Member
    2014 sr5 crewmax
    Dasaita radio, baha designs lightbar
    Any updates on what was causing this. My 14 crew max is doing the same thing AM1 fuse keeps blowing, windows qont roll up, radio won't come on and I can't shift out of park unless I press the shift release button manually.
  13. Jul 17, 2021 at 5:52 PM
    Its2stroke
    Its2stroke New Member
    James
    2008 Toyota Tundra Crewmax
    None
    Today is July 17 2021. I didn't see any updates so I decided to chime in with what I found. I had the same problem, 7.5 amp fuse blowing and can't shift out of park. I tore the entire interior of my truck out and couldn't figure it out. I got fed up and just put a 30 amp fuse in place of the 7.5 amp fuse and look for the smoke. Smoke came from the steering wheel. Took the center of the steering wheel off (air bag) and found that the bag was pressing against a wire behind it. Pinched wire. Problem fixed. No more short, or blown fuses. Hope this helps.
    2mchfun, Ruggybuggy and snivilous like this.
  14. Jul 18, 2021 at 5:30 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Do you know what the wire powered? You would think if it was shorted to ground there would have been something that wasn't working. What color was it?
  15. Jul 18, 2021 at 10:38 AM
    2mchfun
    He couldn't shift out of park
  16. Jul 18, 2021 at 1:59 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The shift lock solenoid is responsible for it not shifting out of park. One fuse can provide power to other circuits. There is nothing under the airbag that controls the shift solenoid so some other circuit on that fuse was causing the short.
  17. Jul 18, 2021 at 2:04 PM
    2mchfun
    Yes, I get that, but I don't think they drove it to see anything else not function because they couldn't get it out of park to drive. If not driving, not really doing anything with the other components, hope that makes better sense.
  18. Aug 6, 2021 at 5:25 PM
    Rtundra
    Rtundra New Member
    So a couple months ago my wife called me at work and told me she couldn't shift out of park and that there were a bunch of lights on in the cluster and that nothing was working in the interior of the car(radio,ac,interior lights. etc). I came home and found that the AM1 7.5amp fuse blew so I replaced it and everything came back on. Everything seemed ok but after a couple weeks it did it again, I replaced the fuse and it immediately blew again. Replaced it and it was OK, and my research began. I saw that a bunch of people were experiencing the same issue but had no answers. I eventually narrowed it down to the ignition switch after tracing most of the wires and doing a "wiggle" test to try and make the fuse blow. I bought the ignition switch and started the disassemble and moved the group of wires i pointed at and found that one of the wires was rubbing on the bearing looking thing. I taped up the wire and put wire loom around it and so far so good. Don't know if this is a common spot but saw that others were experiencing the same issue and figured I would show what i found. I made a YouTube video to show what I found. Hope this helps and good luck.
    81 TOY, D4x4TRD and Ruggybuggy like this.
  19. Aug 6, 2021 at 5:28 PM
    Rtundra
    Rtundra New Member
    Its labeled "sequoia/tundra 7.5amp fuse keeps blowing"
    D4x4TRD likes this.
  20. Aug 6, 2021 at 9:20 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Nice! Put a link up to your YouTube video.
  21. Aug 7, 2021 at 4:11 AM
    Rtundra
    Rtundra New Member
    Ruggybuggy likes this.
